Question about Air Tools & Compressors
My air compressor won't restart
My air compressor will start when there is no pressure in tank but when it tries to restart it bogs down, stops and goes off on overload. Any ideas? Thank you
  • cncm392
    cncm392 May 11, 2010
    Bad capacitor on motor or starter points bad or out of adjustment. More details of motor will get the correct diagnosis....
  • 98 Answers
Minimum pressure check valve is bad , does the compressor when it shuts off bleed air out at the pressure switch , if so does it continue till it starts back up , if so the unit is trying to start under a load. You have a bad minimum pressure valve usually located where the air line goes into the tank.
Posted on Jul 28, 2009
THIS SITE IS NOT HELPING AT ALL.
Posted on Jun 14, 2013
BLAH BLAH BLAH.....IT'S THE RESET SWITCH. JUST BY PASS IT.
Posted on May 17, 2013
Compressor runs fills tank but then it wont keep the pressure, won't restart to keep pressure above requested pressure. I have to let it seat for 1/2 hour to restart again
Most likely problem is the tank fill check valve. The most common way a a tank will loose pressure is by leak-back at the check valve. This also makes it hard to start because it leaves the tank pressure on the pump head instead of letting it bleed off. The motor will only restart after the tank pressure is bleed off to a low level, reducing the back pressure the motor will have to overcome. Leaking can be heard at the pressure switch, where the air is normally bleeds off over 10 seconds or so after the motor turns off. A defective check valve will continuously leak down at the pressure switch unloader valve instead of bleeding out in just 10 seconds. The check valve is an assembly that is largely hidden inside the tank. It just looks like a large hex nut where the filler tube from the pump enters the tank. Removal usually means first removing a smaller hex/barb/connector where the smaller relief line ties into the big nut. Inspection of the check valve will easily reveal whether this is the problem.
Oct 20, 2012 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
My 4 gallon 2hp unit will not start on its own and then the circuit breaker goes. I need to assist it to get started. Any ideas?
Check the tank check valve where the pump output line goes into the tank. If it's stuck open the pressure on the head won't be released and the motor will have to fight the tank pressure every time it tries to restart. Another possibility is the start capacitor on the motor may have gone bad. Only way to test it is to replace it.
Sep 19, 2012 | Coleman Powermate 02 - Gallon Air...
Sometimes my compressor fires rite up and runs when i turn it on but more often than not it tries to start but bogs and trips a breaker. what would cause this? my friend broke the cord and replaced it...
Do you bleed down the air pressure from the tank after you use it each time. You should because you will end up wiyh water in the tank from condencation that will rust your tank out. And this will make it much easyer to start because it dosn't have to fight the air pressure that is being stored in the tank
Dec 14, 2010 | Dewalt 2 Hp 4 GAL Air Compressor
Motor "bogs down" at roughly 120 psi...almost stops
You suspect this unit as being a two stage because of the unusually high cut off pressure. It is a single stage and the motor really has a difficult task and is being pushed to the limits. to reach this pressure. We usually reset the pressure to lower setting ~~ say around 140. Your pump probably has a leaking intank check valve (brass fitting at tank) or leaking valve plate in pump. Simple tests : with pressure in tank unplug compressor from outlet and listens for air leak around pressure switch. As you unplug the running compressor from outlet you should hear air leaking from pressure switch for just a moment as air is let out of airline from pump to tank. If air leaks out till zero pressure then change the valve. If tank holds pressure then valve probably ok. Next test, with no air in tank and air filter removed, plug in compressor and feel intake port for strong suction. If the valve plate is bad, suction will decrease as pressure neers the 120 mark till the point of feeling that air is actually blowing out of intake. With good valve plate there will be strong suction untill unit reaches set pressure. If valve plate is bad also change the cylinder and piston ring. Good luck with your repair.
Jul 28, 2010 | Dewalt 2 Hp 4 GAL Air Compressor
Compressor problems when filling tank
There should be a device called an "unloader " connected to the machines own switch. This releases the pressure from the compressor so it can start up without the resistance of the pressure in the tank.There should be a hissing noise when the machine stops, the sound of the air on the compressor side of a non return valve being released.
Jun 03, 2010 | Campbell Hausfeld 13 HP 30Gallon Air...
Ingersoll Rand Air compressor loosing pressure
sounds like you have a problem with the discharge valve on the secondary cylinder, some I.R. pumps rely on the cylinder head valves to hold back tank pressure when the pump comes to a stop. the line down to the crankcase in front of the crank is a unloader valve that dumps the air pressure inside the pump to allow the next restart. I think that once you drain the tank and remove that cylinder head you will find a defective valve in the head.
Mar 24, 2010 | Ingersoll Rand Air Compressor Maintenance...
Craftsman aircompressor bogging down
Yes , the check valve will cause this. The check valve has a flat disk with a spring that holds it down that the air passing past it erodes away till it leaks then the air that the piston pushes into the tank does not stay in the tank but returns right back into the cylinder and puts a load on the piston. Also makes the compressor hard to start back up if it does get pumped up. Some have a dump valve that drains the pressure off the head after they shut off so it can start with no load. So if there is air bleading back and leaking at the pressure swith that will be a for sure sign it is the check valve.
May 18, 2009 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Compressor will not refill itself with air during use
IT SOUNDS LIKE THE PRESSURE SWITCH ISNT WORKING CORRECTLY. IT SHOULD CUT IT OFF AT DESIRED PRESSURE AND RESTART IT AT CUT IN PRESSURE. YOUR BOG DOWN PROBLEM ON RESTART IS PROBABLY DROPCORD TOO SMALL OR THE COMPRESSOR IS NOT UNLOADING WHEN IT SHUTS OFF WHICH IS ALSO CONTROLLED BY THE PRESSURE SWITCH. WHEN YOUR COMPRESSOR SHUTS DOWN YOU SHOULD HEAR A HISS FOR A FEW SECONDS. THE SWITCH IS DRAINING THE AIR FROM THE TOP OF THE PISTON SO IT DOESNT START UNDER A LOAD THE NEXT TIME. HOPE THIS HELPS. JODY
Apr 11, 2009 | Campbell Hausfeld No.FP2028 Gal Pancake...
Air leakage through pressure switch needle
1)Let your unit pump up.
2)Turn it off.
3)Find the supply line from the pump to the tank.
4)Remove the supply line from the pump head.
5a)If you hear air coming from the tank you have a bad check valve.
5b)If you do not hear air coming from the tank, you have a leaky
pressure switch.
Feb 02, 2009 | Campbell Hausfeld 26 - Gallon Air...
Air Tools & Compressors Logo
517 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
