I'm also having a problem with my Oasis washing machine giving me a "dL" error code. The manual says that means the door is not locking properly, but I can't figure out why. It's always worked before. When I turn the washer on, it begins to fill with water. Normally I hear a "click" indicating the door is locking, but I'm not hearing that now. Then, the washer just stops and begins a "beep beep (pause) beep beep" alert. What's up? How can I get it to lock, and why has it stopped? Nothing is wrong with the latch that I can see...
Hi. this is a door lock mechanism failure code. these mechanisms will become unstable overtime. simply replacing this damaged door lock assembly will fix this issue.
If you are uncomfortable with disassembling thsi unit, i recommend calling a service tech for this procedure. he will simply replace the door lock mechanism(assembly)
