SOURCE: samsung d900i music files
first you connect your samsung d900i in your computer usb port then you start your samsung pc studio . when the pc studio is start you can seen a title bar on your pc studio screen . First you can seen (file) in the upper line in your pc studio . when you click the file then you seen connection .you click connectio . when connection is open you can select usb connection . you can seen your phone model in the pc studio . you can click the phone explorer .when you can seen your phone explorer you menimize your pc studio . when your phone explore is open you can go to (pc) word then you can scroll your mouse and go to my computer and select your music, image foder . when you go to your music file you can select a music and right click your mouse and you seen a menu . you can select( to phone) spelling . when your phone memory will be full then you dis connect your phone . when you can dis connect your phone you can go to my files and then you go to music . you can select a songs whose was download from your pc . you go to option and then you go to move to card select . you can seen (all ) . when you can select your all songs and click the move botton a list will be seen in front of you . this type of menu you can seen (with caller id item , with ring tone item etc) and you can seen aloso a tic mark . you can prss the (i) botton to diss miss the tic mark . you can scroll your phone scroll keys to dismiss the tick mark. when you can diss miss the tick mark you can select the move botton you can seen the memory card folders in your phone . Then you can go to your music folders and click the (option) botton .when you can click the option botton you can seen a list . you can select the (move in) spelling . this way you can move your songs to your phone memory card . i hope you can enjoy with your samsug d900i .
SOURCE: File/Folder Permission Message in Pinnacle Studio 11 Plus
Hello welcome to FIxya!
Here you can check this procedure on how to open your files again.
"1) Check your Recycle Bin
2) Do a Folder/File Search for each of the Grey Folder Project
names. This will display all Folders & Files with that Project
Name. You are looking for an .stx File. If it's there, right-Click on
Project Name / Open Containing Folder & Copy it to your My Projects
Folder. Then you should have both the Grey Folder & .stx File for
the same Project name, showing in your My Projects Folder.
If the Search doesn't display a .stx File, you can create a new one,
by Opening a New empty Project, which will create a My Movie Grey
Folder & a My Movie .stx File, Save to your My Projects Folder.
Delete the My Movie Grey Folder & Rename the My Movie .stx File to
the same name as your original Grey Folder."
So ...after finding my "lost" movie file, with its file name, under
Documents\Pinnacle Studio\My Projects i then went through the following
procedures using your great advice Colour;
SOURCE: pinnacle studio 12 .stx fil
Hi and welcome to Fix yah,
I would suggest to you to finished edit your project and after that click on make movie tab or the number 3 tab of your Studio then do this procedure.
Disc Type : DVD
Audio Compression : PCM
Video Quality : Automatic
Use Progressive Encoding : NOT checked
Always Re-encode Entire Movie: Checked
Burn Options: Create Disc Content and then burn.
Current Media : Should show what DVD Disc should be used.
Target Media: DVD 4.7 GB
Copies : 1
Write Speed: lowest possible
Let me know what happen.
SOURCE: pinnacle studio program file has stopped working
mine too. June 2010. I suspect that Avid have disabled sound after a certain time of use in win 7, no support available.
SOURCE: I can't make movie or
Hi and Welcome,
Click on set up>video and audio preferences>unchecked background rendering>click on "used this codec for background rendering>click and choose MPEG2 for best output to disc. Now click on project preferences>click on delete button and then choose delete auxiliary files for all project and then click okay.
Try that one and let me know what happen.
Regards,
