Question about Maytag Dishwashers
Dishwasher wont run - Maytag Dishwashers
    Brigadier General:
  • 3,513 Answers
The major four reasons for your dishwasher is not working at all are as follows:
Power Supply: Your dishwasher may not be receiving any power. It is somewhat difficult to check for power at the plug outlet because the plug for a dishwasher is usually behind the unit. You should make sure all the circuit breakers of your circuit breaker panel are in the correct positions, or check to make sure no fuses of your house fuse panel are blown.
Door Switch: A properly functioning door switch will shut your dishwasher off when the door is opened. A defective door switch may not allow your dishwasher to operate at all. Examine the door switch and test it. If it is inoperable, it will have to be replaced.
Cycle Selector Switch: It isn't very common, but it is still possible that your dishwasher's cycle selector switch has become defective. Test the switch to determine if it is the cause of your problem. Replace it with a new one if it is.
Timer Motor: Your dishwasher timer will not function if its motor is defective. And if your timer is not functioning properly, then the dishwasher itself will not function properly. Test your dishwasher's timer motor, and if it is broken, you can replace either the entire timer assembly or just the timer motor.
Would appreciate if you mentioned the model or make of your dishwasher.
Thank you for contacting www.Fixya.com
Posted on Jul 27, 2009
Maytag dishwasher wont run
Make sure the door is closed tight and the lock leaver is fully lock.
Sep 27, 2016 | Maytag MDB7749AWW Builtin Dishwasher
Brand new dishwasher wont run
Because it doesn't have legs??? Seriously, I need a little more information. Make/model, new unit or replacement? I presume you installed it because an installer can't leave until it works. Is this dishwasher replacing an old one or a new install? Is the electrical tied in correctly? Is the water hooked up and running? Info, info, info!
Oct 19, 2013 | Whirlpool Dishwashers
My Maytag Dishwasher wont run
check to see if your float is work properly. the float is the little dome that sits in the front lefthand corner at the bottom. lift it up a couple on time gently and make sure there is no debris such as a spoon preventing the float bob from going all the way down.
Apr 17, 2012 | Maytag MDB6759AW Dishwasher
Dishwasher wont run water or turn off
This sounds like the float switch is stuck or bad. You might be able to wiggle the float or float rod around to free it up. Otherwise you will need to check the float switch itself and replace. This is easy and inexpensive. This link will walk you thru checking and replacing the float switch. It may be a different model but the process will be the same. If you need a diagram or illustration of your specific model enter your model # there. http://appliancehelponline.com/dishfloatwaterinletvideo.html
Jun 28, 2010 | Whirlpool 24 in. GU980SCG Built-in...
When i turn my dishwasher on it runs it wont change cycles and wont wash stays in the same cycle
This sounds like a bad timer.
It could also be a defective thermostat. This problem will become apparent with the water heat option selected. Check by running the dishwasher with this option de-selected and see if it proceeds normally through the cycle.
Hope this helps.
Sep 10, 2009 | GE Nautilus 24" Built-in Dishwasher
Dishwasher wont run
Stuck Key Pad.
Jul 29, 2009 | Dishwashers
Dishwasher wont take water
Make sure you get water to the dishwasher. Check to see if the water shut-off valve (located under the sink) is open. If you get water to the dishwasher, but there is still no water inside during the fill cycle, the problem might be with a faulty water valve (located at the bottom of the dishwasher, behind the kick panel, on either side), in which case replace the water valve.
Jun 12, 2009 | Kenmore 24 in. 15252 / 15254 / 15259...
Haier dishwasher wont run and shows a code OP
Did you every get your this problem solved? I am having the exact same problem
Jun 10, 2009 | Haier ESD400 Stainless Steel 24 in....
My Bosch SHX46A06UC just runs and runs and wont stop.
The control board is not turning on the water heater due to bad control board, heater or limiting fuse.
May 10, 2009 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Kenmore dishwasher 587.15159400
to whom it may conern:
about six month ago I purchese the dishwasher, But It just stopped working, the green clean light just blinks all day and night, but wont start it's, when I push the red start button comes on but turns off about 5 seconds later turns of, and wont run and clean my dishes. Could you please help me get strat the dishwasher to start up and run again. Thank you patrick c smith
patrick c smtih
phon 951 805 5187
19050 rockman street
lake elsinore, ca., 92530
actt, 5049 9485 2176 1660
Aug 13, 2008 | Kenmore 15769 Built-in Dishwasher
Dishwashers Logo
269 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
