Question about HP LaserJet 4345mfp Printer
I need a manual for document feeder kit hp laserjet 4345mfp or a quick solution
    Problem Solver:
  • 9 Answers
  • 73 Answers
The HP.com site has all that stuff.
Posted on Jul 27, 2009
Hp laserjet 1536 dnf MFP. How can I repair document feeder?
how to fix and repair the adf doc feeder Q5997A hp laserjet ...
? 1:36
https://www.youtube.com/watch?v=lpTj4jiLaY8
Dec 12, 2011 - Uploaded by BrokenPrinter1
Parts Available @ BrokenPrinter.com how to fix and replace the rollers on a hp laserjet 4345 mfp and color ...
Fixing Paper Pick-Up Issues - HP LaserJet Pro M1212nf ...
? 5:40
https://www.youtube.com/watch?v=ZXtAhSDYqyU
Jan 23, 2013 - Uploaded by HP Printer Support
Learn what to do if your HP printer does not pick up or feed paper from the ADF when you do have paper loaded, and a Doc feedermispick error message display... ... FIX YOUR PRINTER: ERROR: Printer Does not Grab Paper fromTray ... Kit m3027 mfp- Kit Hp m3027 mfp - Kit Mantenimiento m3027 mfp ...
'Document feeder mispick' Message Displays on the Control ...
Dec 13, 2015 | HP Office Equipment & Supplies
Hp 4345
Check ADF unit (automatic document feeder) working condition.
For diagnoses : Insert few paper(ex:10papers) in ADF unit & do copying, if UR succeed in copying, ADF is working well.. If not check the fault.
HP M4345 facilitated with digital sending option., for configuring digital sending U need to create shared folder with fully permissions in system. Better visit hp site or google to know about how to create folder.. You can do multiple scanning once configuration completed successfully..for more info visit:
http://h20565.www2.hp.com/portal/site/hpsc/template.PAGE/public/kb/docDisplay?javax.portlet.begCacheTok=com.vignette.cachetoken&javax.portlet.endCacheTok=com.vignette.cachetoken&javax.portlet.prp_ba847bafb2a2d782fcbb0710b053ce01=wsrp-navigationalState%3DdocId%253Demr_na-c02720194-2%257CdocLocale%253D%257CcalledBy%253D&javax.portlet.tpst=ba847bafb2a2d782fcbb0710b053ce01&ac.admitted=1409945500358.876444892.492883150
Sep 04, 2014 | HP LaserJet 4345mfp Printer
Document feeder mispick.reload
Clean rollers in the ADF (automatic document feeder) with methylated alcohol for quick fix or replace the roller assembly
PN: 5851-2559 and seperation pad PN: Q2665-60125
Dec 24, 2013 | HP LaserJet 3055 All-In-One Printer
What should i do, my printer is requesting me to replace document feeder kit and i dont know what to do. help me out please. MIKE
Never mind, I noticed the model in the subject. Sorry, it is Monday morning. Ideally you need to order a new ADF Maintenance Kit and replace the parts in it to maintain optimal performance of your printer. It comes with a pickup roller, separation pad, mylar sheet and instructions. After you replace the kit, or if you just want to reset the message and ignore it for another 90k copies, do this:
1) Turn the machine off and back on. 2) When XXXMB appears on the control panel display, press and hold the 6 button until all three LEDs flash once and then stay on. (This could take about 20 secs to happen) 3) Release the 6 button and then press the 3 button twice. 4) Press the 6 button to select NEW DOCUMENT FEEDER KIT.
After doing this, the MFP will complete its initialization sequence and the counter will be automatically reset.
The part number for the maintenance kit is: Q5997A, Amazon has it for about $91
Hopefully that helps.
Feb 21, 2011 | HP LaserJet 4345mfp Printer
Where is the maintenance kit on hplaserjet 4345mfp
The maintenance kit usually consists of a fuser which is on the left side just below where the paper comes out, a roller, which is on the right side inside of the manual feed tray, and about 6 new paper feed rollers, which are in the paper tray at the bottom.
the HP model is Q5998A, and they'll run you around $275 for an HP branded one. It has complete instructions on how to replace the parts with the maintenance kit.
May 14, 2010 | HP LaserJet 4345mfp Printer
Reset the usage page on a 4345mfp
The only way to reset the total page count back to zero is from the service mode. Link for service code.
http://www.printertechs.com/tech/pin-servicemenu.php
Link for user guide, menu map under contol panel will show where service mode is.
http://www2.bvu.edu/departments/businessservices/infoservices/2fix/documents/manuals/lj4345userguide.pdf
Oct 14, 2009 | HP LaserJet 4345mfp Printer
Not scanning or copying when using the ADF on HP laserjet 3055
Based on the assumption it's mechanically ok, check the cable connection between the document feeder and the base, if damaged or worked look it can cause errors. If it is a sensor error, check for a small bit of paper or even a staple from a prior jam.
Jun 18, 2009 | HP LaserJet 3055 All-In-One Printer
HP 4345 Dark Line in Middle of Scanned Image
The correct answer is to clean or replace the mylar sheet on the bottom of the adf
Mar 13, 2009 | HP LaserJet 4345mfp Printer
Pale print on PDF files
It sounds like a driver problem. Try replacing the driver for this printer on the printers folder, using the HP LaserJet Series II. With this driver, try again the PDF file and see if it prints correctly.
Jul 25, 2007 | HP LaserJet 4345mfp Printer
HP LaserJet 4345mfp Printer Logo
152 people viewed this question
Seeker5211
Seeker5211
