I have sansung 42 hlf of the screen is distorted line and see
I have sansung 42'' HPR4252 Bottom part of the screen about half way down use to be black out for a few second then it was ok. but now I have a bunch of lines that I can not see any clear picture it is distorted picture. Tv repair guy said it need to change 2 boards on the back . is this make any sense ? if yes appro. any idea of the costof fixing it ?
  • 67 Answers
Ask the repair man which boards needs replacing and what he thinks the problem ?
If its just the power supply board then just a few components (like capacitiors) needs replacing not the entire board.
The cost of 2 boards would be approx £175 maybe more just for the parts not including labour.
I recommend getting a second opinion if you feel this person may be ripping you off.
My TVs power board cost £89 to replace..luckily i discovered the problem with the board it needed new 6 capacitors (which had blown out) and got it repaired for £50 including parts and labour.
Posted on Jul 27, 2009
Why does picture have lines of different colors?
Common easy LCD TV fix: bad picture screen rainbow colors
? 4:04
https://www.youtube.com/watch?v=KWIWeESmXC0
Aug 10, 2014 - Uploaded by Tampatec
Common easy lcd tv service repair fix, TV's distorted rainbowpicture screen fixed by ... Common easy LCD TV fix: bad picture screen rainbow colors ... Need to report the video? ... Sanyo LCD with Distorted Half Picture Lines Waves Distortion Distorted ...Duration: 11:36. by Do It With Dave 316,733 views.
LCD Display Symptoms and causes. - YouTube
? 2:01
https://www.youtube.com/watch?v=DedJvyNm_s4
Mar 1, 2011 - Uploaded by Grants Pass TV Repair
With LCD TVs you can have the same display problems fordifferent ... Fix for Samsung lcd TV colour display problem - Duration: 1:26. by alwaysafix 462,823 views. 1:26. Sanyo LCD with Distorted Half Picture Lines Waves Distortion ... HOW TO FIX LED TV VERTICAL LINES ON SCREEN 55" MODEL LG ...
How To Fix A Broken Flat Screen LCD LED TV With Lines or ...
Dec 11, 2015 | Sharp Televison & Video
My samsung hpr4252 has had horizontal red lines from top to bottom for a while now, but the screen just went out today. there is no picture at all, i'm wondering whats wrong with it, whats the cost to...
As you describe the problem, it can be properly the problem in the LCD screen, that needs to change. The cost could be around 250USD, plus the replacing.
May 15, 2011 | Samsung HP-R4252 42 in. Plasma HDTV
I have a samsung 42 picture lines top and bottom of screen
DAve1645 is correct!
This is a common problem. Its called a convergence failure.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Video may look distorted
You can see some examples here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Nov 28, 2009 | Samsung HCM4215W 42" Rear Projection...
My RCA F36648 36" TV has only the bottom half of my picture working. The top half has horizontal lines that distorte the picture. It looks like when you pull a rake through the sand the lines that are left...
You have vertical output problems.There is distortion at the top because of a faulty vert. output i.c. or a faulty electrolytic capacitor.It's possible there may be a problem at your yoke also.It needs a professional repair.
Sep 29, 2009 | RCA F36648 36" TV
Bottom left corner of my toshiba 65h83 is blurred with color distortion mainly magenta and green. Distortion Is a half moon shape with the open end facing the edge of the set. Total distortion takes up...
Have you tried the "Magic Focus" Button/Option in the Menu Setup Screen? If you have and it still is there, You Have a Burned out Color Tube. It is Cheaper to Throw it away and Buy a New one.
Good Luck..
May 12, 2009 | Toshiba 42H81 42" Rear Projection...
Vertical lines on sansung hln5065w tv
Bring up the on screen menu if you see the lines in front of the menu replace the DMD board.
Feb 19, 2008 | Samsung HLR5067WX 50" Rear Projection HDTV
Flat panel displays half screen, mirrored on bottom half of screen
Have several problems with either a bad LVDS cable from Main unit to the LCD controll bd. Sometimes the cable is just not connected properly. If you reseat this cable and the problem still exists you most likely have a bad LCD control bd.
Jan 20, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
My picture looks like cartoon characters from new commercials
I had recently noticed the same thing happening with mine.Then the left half of the screen turned black and has various red, green, and blue vertical lines. The right half of the screen shows has the picture just fine. It's exactly right down the middle of the screen.
Nov 18, 2007 | LG DU-42PX12XC 42 in. Plasma HDTV
Philips 42 inch Plasma television
I habve seen this issue with this sets and if the vertical lines are in the menu as well and there are more than one line the panel would need to be replace. Contact a tech in your area to see if then can put the set in white screen mode and leave it there for a couple of hours and see if the lines go away. If not then the set would need a panel.
Sep 27, 2007 | Philips 42PF9630A 42 in. Plasma Television
Televison & Video Logo
207 people viewed this question
Top Televison & Video Experts
Electro Med Services...
