Question about Siemens (120-5830-001) Modem
Forwarding from seimens 5830 how to get access
Port config and forwarding
  • 21 Answers
You havent suggested what site you are wanting to forward one of your routers ports too, most people make this request for torrent download and/or gaming experience/improvement. Either way you need to know what port the software you are wanting to open a port for is currently using so you can tell your router which port to allow unchecked access.
I use this very informative support website for port resource info, click this link and choose your router type, in your case select Speedstream-5450 which will be the same setup as the 5830
http://www.portforward.com/english/routers/port_forwarding/routerindex.htm
That should take you to this page
http://www.portforward.com/english/routers/port_forwarding/Siemens/Speedstream-5450/Speedstream-5450index.htm
Then select the software you are wanting to open the port for.IE: Utorrent or world of warcraft Etc... That will then open a detailed walkthrough on setting up rules for your routers port activity. You will need to follow the guide for each port you open, if the guide is not listed for the exact software you are using just read through the one supplied for Utorrent and change the port numbers to the ones you are using.
The software you are using should show you what port is in use at the time you are using it, some software may use a different port everytime you open the software or allow you to allocate a port permanently (which is not recommended safe internet practice especially if your ISP supplies your connection via a STATIC IP address, most use a DHCP allocated IP address)
Failing that you can find the port currently in use information using the command prompt- for winXP and Vista type c:/netstat-b for win2000 type c:/netstat-p Look for the software you are using it will be on the left hand side and look something like [Utorrent.exe] follow the line of info too the right and look for the 4-5 digit port number.
Wheeeew, Good Luck :0)
Posted on Nov 14, 2008
How can i configure aip w505 for att elevate internet, in order to view my qc dvr
You need to enable the virtual server settings on the AIPW505
You also need to allocate a static address to the DVR within the range of the DHCP address range.
Virtual Server Settings - Selects between enabling or disabling port
forwarding the virtual server. (Default: Disable)
? IP Address - Specifies the IP address on the local network to allow external access.
? Port Range - Specifies the port range through which traffic is
forwarded.
? Protocol - Specifies a protocol to use for port forwarding, either TCP,UDP or TCP&UDP.
? Comment - Enter a useful comment to help identify the forwarded
port service on the network..
The manual can be obtained from here
ALFA NETWORK Inc
Oct 21, 2012 | ADVANCE Alfa AIP-W505 802.11n/b/g Wireless...
How do I open ports 500, 4500, 53, and 52428 on Dell TrueMobile 2300 wireless router. Need to open them for Verizon Network Extender
1.Open the router interface by checking the default gateway
2.Under FIREWALL, you can find an option that would say "Virtual Servers"
3.Enable these ports, along with their types(TCP/UDP/Both) and assign an IP address that your Verizon Network Extender is going get( you to set that manually on the verizon device)
Save the changes and the ports will get forwarded!
**Note: In this case, DMZ under FIREWALL will NOT work!
Jan 18, 2010 | Dell Wireless 2350 Router
I would like to configure port fowarding on the Cisco 857 router using the http interface rather than via any coding. Is it possible and what do I need to do? In my scenario, the router must be configured...
It is possible to configure your router via a web browser. Although it’s disabled by default, your router has its own mini HTTP server built in. This provides another way to gain access to the router for the purpose of issuing commands. To enable the HTTP server, you have to use the command "ip http server" from the global configuration mode.
cisco(config)#ip http server
cisco(config)#
Then open a web browser and point it to one of your router’s IP addresses. The interface is not really nice, but you can issue commands using hyperlinks.
For security reasons I still suggest that you keep the HTTP server turned off, since it offers just another point of access for potential hacking.
What is so bad about the command line? Configuring port forwarding is actually pretty easy, once you know the commands.
Type show ip interface to find the name of the interface you want to set port forwarding for.
The show ip nat translations command shows you the current port forwards on Router.
Type configure to enter the configuration mode
The command for port forwarding is: ip nat inside source static (TCPorUDP) (YourComputersIP) (PortToForward) interface (name)(PortToForward)
in you case:
ip nat inside source static tcp 192.168.0.1 5900 interface (name) 5900
and
ip nat inside source static tcp 192.168.0.2 5901 interface (name) 5901
replace (name) with the interface name you got from the first command.
Then press CTRL-Z to end the Configure Session
Type copy run start once you tested your settings and press ENTER for the question Destination filename [startup-config]?
I have heard of some commercial tools that let you configure your router via web interface, but they are very expensive (around 1400$).
You can try it out for 14 days. Go here.
If you want to play with a free one, go to Cisco (link) and check it out. (You have to be a member though.)
If you have any more questions, just come back here and leave a comment - I'm happy to help.
Oct 24, 2009 | Cisco 857 Router (CISCO857K9)
Attempting to PortForward on a Seimens SpeedStream 2614
It may be due to the Antivirus software installed in your system or may be due to Windows defender firewall. Disable the antivirus and windows defender for time being and try again. If you are successfull, then provide proper exceptions to the PFPortChecker program in your antivirus and windows firewall after you enable then to run. I hope this will help you.
Aug 25, 2009 | Siemens SpeedStream 2614 Router (ss2614)
How do I open a port using a Siemens Gigaset 204A modem
you cant open a port on this modem because there is no firewall integrated check your router
or your windows firewall config
plz rate
Jul 08, 2009 | Siemens (120-5830-001) Modem
Port Forwarding with Kaspersky Internet Security 2009
Anti Hacker -> Settings -> Enable Firewall -> Low Security -> Settings ->
Rules For Applications -> Add -> Torrent
Edit Rules -> Add -> Rule Name -> utorrent
Properties -> Remote port (selected)
properties -> Local Port (selected)
Rule description -> Remote Port - >(enter the port) -> DEPENDS YOUR CONFIG
Rule description -> Local Port - >(enter the port) -> DEPENDS YOUR CONFIG
Allow Inbound and Outbound TCP connection, where :
Remote Port: DEPENDS YOUR CONFIG
Local Port : DEPENDS YOUR CONFIG
May 25, 2009 | U.S. Robotics MAXg(USR9108) Wireless...
Portforwarding: Incoming connections on port 80 not possible
try using DMZ plus mode to open all ports to be accessible for that particular application, or specify the application name with the corresponding port on the 2wire modems firewall settings
Nov 22, 2008 | 2wire Wireless-G 802.11g ADSL Gateway
Port forwading
http://portforward.com/
this site may be of some assistance
Jun 19, 2008 | Computers & Internet
ST585v6 router -how to set it up to allow forwarding of ports 5198 5199 & 5200 ? Trying to use it for a ham radio system called EchoLink. Thanks
ra config
Configure remote access parameters.
SYNTAX:
ra config [port = <number]>
[mode = <Permanent]>
I found the above command relating to port numbers in the reference manual for your access point. You can try this. If it does not work, below is a link to the Thomson website where you can view the pdf file for your access point's reference manual where you will find many other commands.
http://www.thomsontelecompartner.com/dsl-modems-gateways/products/product-detail.php?id=104
May 02, 2008 | Computers & Internet
Port Forwarding
there is a way for you to port forward to anything that you would want, the only thing that you would need is the port numbers in order for this to work. Using terms.
1.) In your address bar, type in, "192.168.0.1". And by default, your username should be blank, and your password is, "admin".
2.) Once onto the mainpage, look up at the top of the page, and go into advance.
3.) And then look on the left hand side, and click into a tab that says, "Forwarding".
4.) Fill in you information/chart.
a.) Easiest way to find your ip address is to go to, "Start"(bottom left of your screen), click "Run", and then type in, "ipconfig/all".
b.) Enter in your Start and Exits ports like I said in the beginning.
c.) TPC/USP
d.) And then click "Enable" box, and click, "Apply" at the bottom, and your done!
Jul 27, 2007 | RCA Cable Modem DCM315R (11603540)
Siemens (120-5830-001) Modem Logo
507 people viewed this question
Top Siemens Computers & Internet Experts
Prashant M
Prashant M
john smith
Are you a Siemens Computer and Internet Expert? Answer questions, earn points and help others
