There are re-trace lines across the CRT. - Televison & Video
  • 10,594 Answers
If screen is high bright with retrace lines on CRT then check cathode volt supply, approx 200 volt DC
and if CRT has only retrace lines and there is not high bright problem then reduce G2 (Screen) volts, Screen volt control usually located on either Flyback or on PCB mounted at base of CRT.
Let me know further query, if any.
Thanks.
Posted on Jul 27, 2009
Blue lines on screen
Go to a unused video input and examine the screen----if you see blue with slightly curved trace lines the blue screen control for the set is set just a bit too high.
Dec 03, 2012 | Samsung PCL5415R TV
Vertical Lines on my Mitsubishi WS-65819
This sounds like a bad connection or a bad capacitor in the 220 volt source that supplies the voltage for the CRT boards. You will need to get a schematic and trace out this voltage from the PM board to the CRT driver boards when the set acts up. it could even be a connection on one of the plugs from the PM board to the CRT boards. Sorry but not a real easy repair. Might take some time to trace unless a component is failing. Good Luck
Jun 29, 2007 | Mitsubishi WS-65819 TV
White straight line across the tv
This is a faiure of the vertical section in the TV of the deleflection circuit.
Look for DRY SOLDER JOINTS in the vertical IC- trace the leads of the deflection coil to find the vertical IC, normally an IN -LINE IC mounted with an heat sink.
Solder , check the voltage , if not there is fusible resistor from the LOT that would have failed.
Also check the delfection coils, capacitors in the vertical section.
Aug 09, 2011 | Zenith SY3238MK/RK TV
My tv died last night no power at all no stand by light or sound It is a Samsung Tantus Model number TXN3298HF CRT
check first power ac cord by removing back cover trace if ac line voltage found, check for possible burn fuse. make a record after that scenario trace and log voltage trace from power supply ckt area.
Mar 26, 2010 | Samsung TXN3298HF 32" TV
No video but sound works. white line across center
easy way is 4 wires will come from yoke coil(around pic/tube) green &yellow wires commonly used for verical deflection ..will be connected to soket. trace tracks from that connector points..on bootomside of pcboard..that tracks will lead you to vertical ic..commonly standing type ic..replace ic..check supply25v for the ic will come from l,o,transformer via a resister..good luck...
Mar 16, 2010 | Televison & Video
JVC AV-36D502: Input #3 doesn't work
Good day sir, its a different issue, about the capacitor, for as long as your replacement part is correct, it will work, now, there are several things you should check, the I/O device that controls the inputs of the TV, usually an IC, check your schematic diagram to trace the fault. check also the line from the input 3 to the controller IC on your diagram. Measure the voltage across the IC Vcc to ground if the IC is getting the right power, Low voltage can be cause by faulty capacitors, on the power supply line, or the IC itself is faulty, Circuit analysis and voltage measurements are needed to trace the faulty part. hope this helps thanks.
Oct 23, 2009 | JVC AV-36D502 36" TV
I have a toshiba tv 27 with a line across the middle of the scree
Definitely not. You have the symptom called 'field collapse' . What happens is a beam of excited electrons is traced across the screen and when it reaches the end the beam flys back and traces the next line down. Because you have a line across then the beam is scanning across but the field circuit isnt making the beam move down as it traces across a new line. The fault lies either in your field deflection driver chip or...the power supplying it has disappeared at around 27 volts..or the booster or voltage doubler circuit connected to the chip has goe faulty.. Another fault could be the yoke connection b roken but hardly likely unless youve dropped the tv at some point :)
Aug 03, 2009 | Toshiba Televison & Video
Re trace lines in 14'' CRT
this monitor will unfortunately have to be replaced. the repair parts will take some time to order. try the troubleshooting charts on the LG website.
Jan 28, 2009 | LG Studioworks 45 14" CRT Monitor
White horizontal, zig-zagging lines
It sounds to me like you're describing the re-trace of the unit. It is repairable, and more so the sooner you get it to the repair facility.
Nov 21, 2007 | Sony FD Trinitron WEGA KV-27FS120 27" TV
Televison & Video Logo
157 people viewed this question
Top Televison & Video Experts
