Question about IBM Wheelwriter 30 Typewriter
Wheel writer II will not print - replaced with new ribbon
And will not print still after replacing ribbon and correction tape.
  • IBM Master
  • 3,594 Answers
We sell the cap with installation instructions for 20.00 including shipping.
DickyO
Cleveland Business Mach.
216-241-0027
Posted on Aug 06, 2009
    President:
  • 2,306 Answers
There's a small cap on the solenoid that pushes the hammer, this cap wears out and the solenoid cannot push anymore. Cheap part, always wears out, new ones are teflon and last lots longer.
Posted on Jul 27, 2009
I put in a new wheel and new ribbon with correction tape; was working fine but all of a sudden, it won't print correctly. It prints on the very top edge of the ribbon and the letters do not print...
On the older WW's there is a large black plastic gear on the R. side of the printer they do get tooth for tooth. try wiggling it to free it up, with the power off it should move easily.
DickyO
Oct 13, 2010 | IBM Wheelwriter 6 Typewriter
How to change the correction tape?
Changing the Correction Tape
1) Move the print carrier to the center of the platen using the SPACE or BS key.
2) To replace the correction tape, lift out the typing ribbon cassette (see Changing The Ribbon Cassette) and remove the two spools of the lift off tape by pulling them outwards.
3) Place the empty spool of new tape on the left pin so that the tape winds clockwise. Place the tape around the left guide. Pull the tape around the right
guide and place the loaded spool on the right pin so that the tape unwinds counter-clockwise.
Note: Make sure the sticky side of the tape is facing the platen.
4) Manually turn the left-hand spool in the clockwise direction, tightening the tape until resistance is felt.
5) Replace the typing ribbon cassette.
6) Press the CODE + = (SETTING) key.
Changing the Ribbon Cassette
2) Hold the ribbon cassette on both sides and lift up the front portion (where the ribbon is exposed) to remove the cassette.
3) To insert a new cassette, place the back end of the cassette on the cassette
holder on the carrier and gently press down on the front of the cassette unit it clicks into place.
4) Turn the ribbon feed knob counter-clockwise again to take up any slack in the ribbon.
5) Presss the CODE + = (SETTING) key.
Good Luck!
Oct 13, 2010 | Smith Corona Wordsmith 100 Typewriter
IBM wheel writer 5
If it is printing just the tops the platen may not be fully seated in the side frames, press down firmly on both ends of the platen.
If it is just printing poorly the print solenoid cap is cracked or the ribbon may not be feeding properly.
DickyO
Dec 10, 2009 | Lexmark Wheelwriter 6 Series II Typewriter
Installed new ribbon. appears correctly installed.
There is probably a fold in the ribbon usually the bottom, reinstall it and be vsure it is flat between the guides.
DickyO
Oct 02, 2009 | Lexmark Wheelwriter 15 Series II...
Replacement of correction tape
The correction tape cartridge "piggybacks" under the ribbon cartridge. Flip your black ribbon over, line up the front dges of the two ribbons and gently press down on the correction ribbon 'till the two wing tabs at the top are attached to the slots at the top of the black ribbon. Be sure to take up any slack in the ribbons BEFORE re- installing.
GL
Jul 06, 2009 | Lexmark Wheelwriter 15 Series II...
IBM Correcting Selectric II; correction ribbon frozen in front of typing ribbon.
Move the grey lever on the R. side of the carrier to the R. and remove correction tape, try the machine, if it seems to work OK install a new correction tape.
DickyO
May 28, 2009 | IBM Wheelwriter 30 Typewriter
TYPING II IN PLACE OF LETTERS
the mark you are seeing is the print hammer hitting the paper. remove the ribbon. corr. tape & print wheel. turn on the typewriter. close cover let it home it's self. open cover put in print wheel. close cover let it nome. put in ribbon close cover. try typing if marks are still ther. you will need a new print wheel. if working then put in corr. tape or if you are better at spelling then me you will not need it
Jan 21, 2009 | Smith Corona Wordsmith 200 Typewriter
No Characters Typing
could be the ribbon is not lifting, do you see an image on the ribbon, also may be twisted inside the cartridge the shiny side has to be facing the keyboard.
Jul 09, 2008 | Brother EM-630 Typewriter
Correction tape problem IBM Selectric II
Take off the ribbon, just inside the rt. side frame of the printer is the mech. for L/O feeding. There is an arm that moves back and allows the feed to ****, that mech. is probably gummy, lube with some WD40 on both sides of the printer (the left side sets up correction lifting.
DickyO
May 19, 2008 | Lexmark Wheelwriter 15 Series II...
Replaced Part No. 1337765 and 1380999, but there is still no ink coming out
It sounds like th4e plastic cap on the print solenoid plunger is broken. The part is avail. but a little tricky to replace.
DickyO
May 16, 2008 | Office Equipment & Supplies
IBM Wheelwriter 30 Typewriter Logo
182 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
CheckitRight
CheckitRight
Jim Keysor
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
