Question about Nextar X3-03 Car GPS Receiver
No results when navigation is pressed to operate
When unit is turned on goes directly to main menu from navigation screen and does not respond when pressing navigation icon to enter that mode.Reset button does not correct the problem.
    Brigadier General:
  • 4,090 Answers
There is no map data or it has become corrupted get the maps reinstalled
Posted on Jul 27, 2009
When I turn my Garmin Nuvi 680 on, and the first screen appears about not driving while operating the Garmin, I have to hit "agree" button several times before it goes to main menu, and from that...
Try performing a soft reset.
Disconnect the unit from any external power supply.
Depress the reset button behind the flip up antenna.
Reconnect the unit to the power supply and let it should work normally.
If the soft reset does not work, try performing a hard reset.
Caution: Performing a hard reset will erase all user information including favorites and bookmarks and restore the unit back to factory settings. Be sure to save any information before performing the hard reset.
With the unit off, press and hold the lower right hand corner of the screen while turning the power on until a pop-up appears. Press "Yes" to restore the unit back to factory settings.
Sep 21, 2011 | Garmin Nuvi 680 GPS Receiver
Tip
These tips really doesn't work on my unit (nokia 6110 navigator).i've been...
1- Turn off unit.  2- press and hold the bottom right corner of the screen. 3-While still pressing and holding bottom right corner, press and hold power button and continue holding both until a white screen appears with a black dot. 4- follow the on screen directions and your unit will be back to the day you first got it.
on Feb 09, 2009 | Garmin StreetPilot C330 GPS Receiver
Cracked screen will not allow me to move from screen to screen. I can get to main menu but screen will not allow me to press and move to next screen/menu.
This unit can be repair only by the manufacture or a 3rd party that repairs them, They will put in a new touch screen the cost may be more then you can get a new unit for due to GPS pricing going way down.
thanks for your free question
Rulds2008
Apr 29, 2009 | Garmin nuvi 200W GPS
Sansa 260 Won't Let Me Navigate Back to Main Menu
The power button is also the Menu button - click and release once while the player is on, and see if it gets you back to the main menu. Or press the left arrow key and see if it will get you back to hte previous menu.
-Tha Mp3 Doctor
Feb 21, 2009 | SanDisk Sansa e260 MP3 Player
R66_ AUSTRALIA .gOES STRAIGHT TOM MAIN MENU will not navigate
My best suggestion is to contact the manufacturer so that you can get the proper software for your gps system.
Jan 28, 2009 | Route 66 MINI Handheld GPS Receiver
Nav system
Installing the DVD Map Disc Your dealer/retailer may have installed the map DVD. If the map DVD was not installed, do the following to load it:
Read the following steps completely.
  1. Turn the ignition on. The vehicle must be in P (Park) to perform this operation.
  2. Press (power) to turn the navigation system on.
  3. Press the NAV hard key.
  4. Touch the Insert Map Disc screen button. The screen opens to access the map DVD slot.
  5. Load the map DVD partway into the slot. The system pulls it in. The screen cannot be closed until a double beep is heard.
    Notice: Pressing directly on the navigation screen may cause damage. Repairs would not be covered by the vehicle's warranty. Do not press directly on the navigation screen.
  6. To close the screen, slightly push up on the two outer corners until the screen is in position. Then push the screen in by pushing on the four outer corners until a click is heard.
  7. Set the search area. See "Setting the Search Area" earlier in this section.
Ejecting the DVD Map Disc The navigation portion of the system cannot be used if the DVD map disc is not loaded.
  1. Press the MENU key to enter the Menu options, then press the MENU key repeatedly until Nav is selected or touch the Nav screen button.
  2. Touch the Map Database Information screen button.
  3. Touch the Eject Map Disc screen button. The screen tilts, exposing the map DVD slot.
  4. Press the eject button, located next to the DVD map disc slot, and the disc ejects. Pull the disc out. The screen cannot be closed until a double beep is heard.
  5. To close the screen, slightly push up on the two outer corners until the screen is in position. Then push the screen in by pushing on the four outer corners until a click is heard.
Oct 07, 2008 | 2007 GMC Acadia SLE
Flicker and very slow
turn off your PSP ,then switch on again.. when the screen are in black condition "press R button" and change the CPU speed
Aug 23, 2008 | Sony PlayStation Portable (PSP) Console
PSP SCREEN FLICKERS AND GOES SLOW IN MAIN MENU
Go to psp recovery menu and set the CPU speed in XMD to default, it should work
No active voice
Is the volume turned up? Press the bottom of the screen while the unit is navigating, and the volume control should appear. Make sure it is turned up. Or you can do the same thing by pressing the main screen and searching the menu for Volume Control.
Aug 05, 2008 | Tomtom GO 300 GPS Receiver
I have a nuvi 200 that wont run when it is hooked up to a power supply
Vehicle Power Cable to the nüvi and connect the otchapin.screen1.jpgher end to your computer, your nüvi does not operate as a GPS unit - it goes into some sort of charging mode. However, if you FIRST turn on the nüvi in the battery mode then go into the test mode (press the battery icon for about 8-9 seconds) from the main screen, THEN PLUG in the USB cable, and finally exit the test screen, your nüvi will restart chapin.screen2.jpg(reboot) and it will operate just like it was plugged into the cradle connection in your vehicle.
This mode will charge the battery
AND operate as a GPS.
It works with my computer USB cable, my cell phone charger and my car charger for my cell phone.
Don't forget to turn off the nüvi before unplugging."
Mar 01, 2008 | GPS
Nextar X3-03 Car GPS Receiver Logo
342 people viewed this question
Top Nextar GPS Experts
Are you a Nextar GPS Expert? Answer questions, earn points and help others
