Question about Maytag MMV5207 Microwave Oven
I need to know the size of the lightbulb for lighting the work surface below the microwave; they have them at my local hardware (Canadian Tire) but there are a lot of different sizes, I could not see the size on the parts drawing. model is MMV5207
  • 5,911 Answers
The bulb is a halogen (part number 53001905). You can view the bulb at searspartsdirect.com. Type in your model number and look under the "Base/Latch Board Assembly" heading for item 6. Although it does not list the size, it does list the type and part number. Your hardware store may be able to cross this number for you and find the bulb you need.
PS There is a better view of the bulb at appliancepartspros.com. Just type in the part number above and you will see a photograph. Are you in Canada? If so, you may enquire one of these sites also to see if they will ship to Canada.
Posted on Jul 27, 2009
I have a Kenmore microwave mounted above my stove. The light that lights my stove is blown and I can't find the right replacement bulb. It has two little prongs that should fit into the unders
Are these little spot lights? About the size of 1/2 dollar round and maybe 1.5 -2 inches long? 2 prongs about 1/2 inch apart? Take one of those lights and show it to a local hardware dealer like "Lowes". There are may types and some are 12V some are 110V. Thats why I suggest showing to the local hardware guy.
Jan 12, 2015 | Microwave Ovens
I need to change the lightbulb on my em-s5002w Sanyo Microwave. What screwdriver size & style do I need for lower star-shaped screws
The star-shaped screws are called TORX and range in size from T-1 [small] to T-50[ quite large]. a set of inexpensive bits that fit a driver handle can be found at a hardware or auto supply.
Jan 24, 2013 | Sanyo EM-S5002W Microwave Oven
Frigidaire microwave oven
Hello - This may or may not be specifically for your model, however these are generics instructions that I found.
To replace the light bulb to the over the range microwave you will need to follow the steps below:
1. To replace light bulb, first disconnect power to the microwave oven at the circuit breaker panel or by unplugging.
2. Remove the vent grill mounting screws.
3. Pull the vent grill away from the unit.
4. Remove the charcoal filter by pushing it inwards, then turn and pull it away from the unit.
5. Open light cover located behind filter mounting by carefully pulling up on the front edge.
6. Remove old light bulb and replace only with equivalent 30 watt bulb available from part distributor. Bulbs are also available at most hardware stores or lighting centers.
7. Replacing the microwave oven light cover by carefully pushing into place. Replace the charcoal filter. Push the vent grill back into place (engaging both the bottom and top tabs) and replace the vent grill mounting screws.
Note: DO NOT USE BULB LARGER THAN 30 WATTS.
Oct 27, 2012 | Frigidaire FMV152K Microwave Oven
I need to replace the light bulb under my advantium 120 but my wife threw the lighbulb away I need to find out what size lightbulb I would need
I would think that you can find that info either in the owners manual or right in the area where the light resides. Usually there is a sticker there with the info you need. Best wishes!
Jul 29, 2009 | GE Advantium 120 Convection/Microwave Oven
Surface and night light bulbs
If the model number you have this listed under is correct, the bulb you need is part #AP2029997, made by GE. You can also purchase these bulbs at any hardware store. They are the half sized small base, 40 watt bulbs. If you can't find 40 watt, make sure you use a lower wattage rating. If you have questions, or if the model number is incorrect, please let me know. I hope this helps you.
May 04, 2009 | GE JVM1650 1000 Watts Microwave Oven
Light no longer working
Most microwave ovens I have worked on the procedure is...
UNPLUG the microwave.
Remove the screws (along the bottom sides and the back of the oven) holding the the outer cover to the unit.
Remove the outer cover and the lightbulb will be visible.
Unscrew the bulb and head to the hardware store for a replacement.
Reverse above procedures.
Hope this helps.
Apr 06, 2009 | Frigidaire FMV145K Microwave Oven
NEED TO KNOW SIZE OF SURFACE LIGHT BULBS.
went to the store a got a new one
Jan 15, 2009 | Microwave Ovens
GE Profile Spacemaker Microwave
Absolutely. That's why they make shop bulbs to use in one's portable garage work light and garage door opener.
Slamming the door of a microwave is never good idea!
Another factor is touching the new bulb with your bare skin, as the oils will shorten the bulb life.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Jul 26, 2008 | GE Advantium 120 Convection/Microwave Oven
Maytag MMV5207 Microwave Oven Logo
157 people viewed this question
Top Maytag Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Maytag Microwave Oven Expert? Answer questions, earn points and help others
