Dishwashers
Problem for Dishwashers
Generic problem for all Dishwashers
The dishwasher will not drain all the way...
By mebromddubay on Jul 27, 2009
The dishwasher will not drain all the way it is a DU810SWLQO
Solution #1
posted on Jul 27, 2009
Not Rated)
localwonder
Rank: Guru
Rating: 92%, 3130 votes
HI. check the following areas for faults.
1. Air gap / Drain hoses
If there is an air gap (located in the sink, near the faucet), check to see if it is clogged. Unscrew the top cap and see if there is anything blocking inside. Note: If there is no air gap installed, the dishwasher might not drain properly.
If the drain hose is clogged, the dishwasher would not drain. If there is an air gap installed, it is very common that a hose going from the air gap into the garbage disposer is clogged. Remove and clean the hose. Make sure to reattach the hose before starting the dishwasher.
Note: If you recently had a garbage disposer installed, it is common to overlook removing the drain plug.
2. Broken belt
Some dishwasher models use a belt to drive the pump. Replace the belt if found broken.
Note: Sometimes the belt would just come off the pump. Even though it might not be broken, it is recommended that you replace the belt, because it is probably too stretched out.
3. Pump
Some models have two impellers inside the pump - one, wash impeller, takes care of the wash cycles, the other, drain impeller, drains the water out. If the drain impeller is broken (broken blades, shaft), the dishwasher would not drain. Replace any broken pump components.
4. Drain solenoid
Some models (for example most GE dishwashers) use a drain solenoid to drain water out. Sometimes the solenoid gets stuck, preventing the water from draining out. Try to free up the solenoid. If unsuccessful, you might have to replace the pump assembly.
5. Motor
If the motor is stuck, it is sometimes possible to free it up by manually spinning the motor.
Replace the motor if defective.
6. Timer
Replace if defective (note: uncommon problem).
Was this helpful?
Yes
No
Popular Solutions for Dishwashers
Questions and Unsolved Problems for Dishwashers
Answer
kitchen aid model number kudco31vbs is it good
Answer
we are about to buy new dishdrawer lookin fisher and paykel
Answer
hotpoint dishwasher red light keeps flashing no water getting through help please... (More)
Answer
Plastic button on switch was replaced 18 months ago and switch sometimes works and sometimes won't,... (More)
Answer
after couple of minutes operation cuts out house fusebox
Describe your Dishwashers problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Dishwasher Experts
Top Dishwasher Repairmen
in , IL
(423) 303-3783
Dishwasher parts delivered overnight nationwide....
 Appliance Parts Pros.com
(800) 905-9505
A&E Factory Service is a nationwide leader in...
A&E factory service
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
