Question about Hayward 2HP Pool Pump Motor A O Smith Electric Pool Motor for 56J Frame
Installing new 2hp hayward motor, wireds to motor are 1- red, 1-blue and one green. I know when the green one goes but not sure about the red & blue ones. The hayward motor has two leads to connect to and are maredk 1 & 2. WEhich one gets the red wire?
  • Anonymous Mar 18, 2014
    when I start the motor it wants to start but then clicks and shuts down then starts again then shuts down ? there is 5 wires and the orange wire is not connected to any post could this be the problem
    President:
  • Hayward Master
  • 1,378 Answers
It won't matter. Put the red on one line and the blue on the other. Motor rotation is fixed and reversing those wires makes no difference.
Posted on Jul 28, 2009
Replacing Pool pump motor
Which control panel?
White can be Com, and Black Lo, and Red/Blue Hi
But this is guessing without knowing control panel wiring.
For example T106 timer. Wires can be any color.
http://waterheatertimer.org/images/T-106-control-208-277V-4-40.jpg
High connects to terminal 4
Low connects to terminal 1
Com connects to terminal A
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Apr 16, 2013 | Pool & Spa
Need wiring diagram for a hayward eletricic pool pump
MOST OF THESE ARE 230V ONLY, SO GROUND GOES ON THE GREEN SCREW ABOUT 2 O-CLOCK ON THE MOTOR AND THE OTHER 2 WIRES GO ETHER WAY ON THE 2 SCREWS . REMEMBER TO VOTE FOR YOUR FAVORITE FIXIT GUY ! THANKS JAY
Jun 28, 2010 | Hayward 2HP Pool Pump Motor A O Smith...
I have a Hayward 1 HP pool pump. I have to
hi ...the two yellow go on one side of the cap and the red /white go on the other.. like two on the negative side of a battery and one on the pos .. your pool pump repair guy longwood fl
Apr 01, 2010 | Hayward 2HP Pool Pump Motor A O Smith...
1/2hp Hayward Pump for existing inground pool
you will be fine with the 1/2hp. The Hayward will move quite a bit of water as well. It may not move as much water as the 3/4hp but it's very close and the 1/2hp will cost a little less to operate so if anything, you may just have to run it for one additional hour per day to compensate. You will be surprised how much water a 1/2hp will move. The only issue with smaller pumps is if you have pop-up cleaner heads or a suction driven automatic cleaner such as a kreepy krauly, however, if a 3/4hp will run it, a 1/2hp will run it as well. You can install a larger motor on the super pump but it will not move more water unless you upgrade the impeller as well. Just make sure you don't use a bigger impeller than what the motor is rated for because it will strain the motor and cause it to overheat. Hope this helps.
Feb 20, 2010 | Hayward SAND FILTER, PRO SERIES
Does it matter which wire, red, black goes on l1, l2?
"new wire", brown, blue, green, brown is what we call
HOT, that goes to the fuse, "old wire", red, black, green,
red is what we call hot, that goes to fuse, and green in both are earth.
Dec 06, 2009 | Hayward 1.5 Hp Northstar High Performance...
I am installing a new pump on my asko dishwasher pump but not sure which wire goes where
there should only be two or three wires main wires brown & blue or red & black. green or green with yellow stripes is earth wire main wires connect to pump motor earth connects to earth point hope this helps
Nov 14, 2009 | Asko 1385 Dishwasher
Irrigation sprinkler pump, flotec, 230VAC wiring
green to srcew on the motor. this is ground.,
Black on T1
Red on T2
If the rotation is going the wrong way, simply switch the black to T2
Red to T1.
Check this before you couple it to the pump..
Jun 01, 2009 | AO Smith 1 1/2 HP 115/230V 56C Replacement...
Hayward 2HP Pool Pump Motor A O Smith Electric Pool Motor  for 56J Frame Logo
266 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
