By 2Pansy - usenet poster
Hello Ed,
My opinion is that the teams are pretty well balanced in ATC.
Not only does each country seem to attract the same amount of
players, but I find that I get shot down easily in any plane
from any country. I honestly feel that VR-1 has done a great job
with balance.
I am I_am_Ned
Got questions? Get answers over the phone at Keen.com.
Up to 100 minutes free!
http://www.keen.com
Solution #1
posted on Aug 09, 2005
Pasty - usenet poster
Rank:
Apprentice
Rating: 0%, 0 votes
I would believe that they would determine RoC by means of that aircrafts
normal Takeoff Speed. Going beyond that speed or below it would definitly
'taint' the results.
<u @downed.com>
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
maartenw - usenet poster
Rank:
Apprentice
Rating: 0%, 0 votes
Solution #3
Janice - usenet poster
Rank:
Apprentice
Rating: 0%, 0 votes
I would just like to point this little fact out as well, while I still may.
Spit14 Time to Climb to 16000ft: 3m 57s. Yak-3 Time to Climb to 16400ft: 4m
5s. If you extrapolate it out, the Spit14 will get to 16400ft in 4m 3s, a
mear 2 seconds faster than the Yak-3. For climbing 16000ft, that 2 seconds
means next to no difference about 120ft or so. The fact of the matter the
Spit14 leaps off the ground faster than the Yak-3 but, from 5k to about 15
or 16k the Yak-3 would have a RoC that is better than the Spit14, and while
the Spit14 would be higher than the Yak-3 initial, the Yak-3 would be
gaining alt closing the 400ft alt advantage the Spit14 would have down low
after the first minute to only a 100ft advantage by the time they got to
16000ft.
The Yak-3 does NOT have this kind of climb rate modeled in 2.0, nor anything
CLOSE to the RoC.
Solution #4
Hart - usenet poster
Rank:
Apprentice
Rating: 0%, 0 votes
Thanks Pav, I didnt know that. I'm surprised though, because depending
on circumstances, sometimes I will lift off at 80 mph and other times,
for whatever reason, I would rather have a lot of speed built up
before lifting off at up to 160mph. And in ATC some planes just don't
rotate by themselves at a given speed (suprisingly). This would give
noticeably different times though, wouldn't it?
The Smoo
On 28 Jun 2000 09:20:49 GMT, "Pavlov_72nd/MangyDog"
Solution #5
Cato - usenet poster
Rank:
Apprentice
Rating: 0%, 0 votes
You are right, but arguing over the real data instead of arguing over
somebody suspicious is far more constructive form of arguing :) Seriously,
who knows, one can prove something then. Different ball game, really.
And I agree about "Advanced" 100%.
Later\
Oooo man, that's a can of worms. Kind of damned if you do, damned if you
don't. If you post the real data, then everyone will argue over the real
data instead of arguing over their suspicions. Not sure if there would be
less argument or not, but it would take away the counter-argument of "aha,
you just THINK the QB-112 spoofighter turns better than the A14 Matilda."
Bottom line, I don't pay attention to anyone who doesn't fly extensively in
ATC. If you aren't willing to put up with realistic physics, you really
can't expect to have realistic performance.
Solution #6
kioner - usenet poster
Rank:
Apprentice
Rating: 0%, 0 votes
"...since we're talking about cruising and climb speed and not turning radius none of those factors even come into play..." ["PTR_Goldberg"]
Sorry, of course they do come into play!
...and modeling could very easily be done in the ITC rooms (which is
ATC w/o stall spins, engine torque and back blast) and since we're talking
in ATC. If you aren't willing to put up with realistic physics, you really
Solution #7
Joey2 - usenet poster
Rank:
Apprentice
Rating: 0%, 0 votes
Ahhh don't show that to the Jerries, they'll be pissed.
Solution #8
jessie25 - usenet poster
Rank:
Apprentice
Rating: 0%, 0 votes
Sir Soul,
Hang in there just a bit longer Bro. All is not yet lost...
You've been the voice of reason many times, and a champion for the 190s
every time.
The times, they may be a changin'...
Wit
Solution #9
Rank:
Apprentice
Rating: 0%, 0 votes
Alas, I have been defeated in The Battle of the Books. I give up. I will
submit gracefully to my Limey masters. This is not a happy day for the
Luftwaffe. Total capitulation can't be far off.
Soul
Solution #10
Cornish - usenet poster
Rank:
Apprentice
Rating: 0%, 0 votes
Ok, I read my post, and maybe it is harsher than I meant it to be. But
still basically true.
I flew the D12 today for a little while, just to get a taste. Strikes me as
a fine plane. Good power, fast, especially with WEP. Much better fuel
endurance than the Spit, and if you don't believe that makes a difference in
ATC, yer wrong.
I got in a couple of scraps. Won a few HtH, lost a turn fight. Duh, big
surprise there, especially when I engaged a Corsair that had alt on me.
One thing I did notice. The D12 is extremely stable at high speed. This is
very important in ATC for firing, and especially for HtH. The combination
of stability and huge guns makes it a great BnZ fighter. I vaporized a
couple of La-7s at the merge.
Seems to me that as long as you don't go trying to out-turn other planes,
the 190-D12 is a fantastic plane. Just like the pony.
Solution #11
Peter1 - usenet poster
Rank:
Apprentice
Rating: 0%, 0 votes
Not a question of cheating, or integrity, but if you want to make this topic
just as emotional as you possibly can for yourself, go right ahead.
More a question of bias, which will be reflected in results, and selective
reporting. You focus on the areas that support your arguments, and ignore
those that don't. It's human nature. The only way to escape it is to get
the data and comparisons from those that have no ax to grind. Get someone
who flies ALL the planes equally to do the testing and comparisons.
Solution #12
Rank:
Apprentice
Rating: 0%, 0 votes
Dang Pav.. thats almost the exact number I got during testing... hmmm...
def
Solution #13
Perkins - usenet poster
Rank:
Apprentice
Rating: 0%, 0 votes
then why do you bother reading the NG? only a handful of pilots fly ATC as
it is...and modeling could very easily be done in the ITC rooms (which is
even come into play
Goldy
Solution #14
Rank:
Apprentice
Rating: 0%, 0 votes
i love to see real facts about other countries planes...gives me a better
idea what i should be able to do when facing them in combat...
PTR_Goldberg
Solution #15
Rank:
Apprentice
Rating: 0%, 0 votes
LOL sure ya would...all you'd have to do would be start turning and the 190
would lose all of it's E so fast it would plummet to the virtual dirt as you
filled it full of lead =)
Goldy
Solution #16
Horner - usenet poster
Rank:
Apprentice
Rating: 0%, 0 votes
funny how realistic is nothing like the real thing...ever fly Aces High? now
that game is hard!! LOL
PTR_Goldberg
Solution #17
Gary10 - usenet poster
Rank:
Apprentice
Rating: 0%, 0 votes
he only talks about the German planes because that is what he flys...listen
to people like Pavlov if you want to hear about the SU planes..and the rest
of the pilots posting in here about the other countries..
PTR_Goldberg
Solution #18
LiZzIe - usenet poster
Rank:
Apprentice
Rating: 0%, 0 votes
What about a Brown Nosed Yak-3? Nope, never seen one of them either.
Solution #19
Duke - usenet poster
Rank:
Apprentice
Rating: 0%, 0 votes
glitches are glitches m8...no matter how big...they all need to be fixed and
this is the forum to state them in =)
Goldy
Solution #20
Ranny - usenet poster
Rank:
Apprentice
Rating: 0%, 0 votes
i believe they made it brown for all the trigger mashers to fly in the
dirt..hehehehehe
Goldy
Solution #21
Brad - usenet poster
Rank:
Apprentice
Rating: 0%, 0 votes
what about SOME kind of paint job on the 109k? it's just dull steel
colored..LOL they need to give it Hartmann's paintjob with the black roses
Goldy
<u @downed.com>
Solution #22
Bomber - usenet poster
Rank:
Apprentice
Rating: 0%, 0 votes
could that be because they don't know what they are either?
Goldy
Solution #23
kcw573 - usenet poster
Rank:
Apprentice
Rating: 0%, 0 votes
Well then, you don't pay attention to 75-85% of the people that play
fighterace. Yes, it's very realistic to have no high speed stall and AUTO
trim isn't it? I appreciate when you told me how to recover from spins in
advanced, but this holier than thou attitude of yours about advanced is
tiring.
Soul
Solution #24
paulrmc - usenet poster
Rank:
Apprentice
Rating: 0%, 0 votes
Yer constant whining is tiring too, Soul. Boo hoo hoo, the German planes
aren't as good as we want them to be. You have the right to say what you
want, sure, but after a while the "VR-1 hates Germany" stuff just gets old.
I have NEVER heard anyone in ATC complain about the modeling of the German
planes. Never. Wonder why that is? And there are always plenty of GE
flyers in there. Funny how that works.
