Question about HP LaserJet 4100 Printer
Display says toner out even with new cart. Setting new cart message in resets menu to yes does not work, selection reverts back to no. Customer is using reman carts.
  • 73 Answers
A number of companies use a fuse that blows when the cartridge is low. If the fuse is not replaced, it will still say "toner out". The reman should have replaced it.
Posted on Jul 27, 2009
How to clear the usage counter?
From Samsung site:
1. Press MENU # 1 9 3 4 in sequence rapidly. The LCD panel should now display TECH.
2. Press MENU, and then press ENTER. The LCD panel will display Tech Mode.
3. Press the left arrow (<) button once. The operator panel will display NEW CARTRIDGE.
4. Press ENTER. The operator panel will display [YES].
5. Press ENTER. The toner warning message should be gone.
6. To exit TECH MODE, press MENU # 1 9 3 4 in rapid succession, as if you were dialing a phone number. The operator panel should no longer display TECH.
Oct 18, 2014 | Samsung 5pk - Scx-4521 Scx-4321 Scx-4521d3...
It says drum error but the cart and drum is replaced with new and still can't get past the drum error message.
Hi There!
What you can do to clear the Drum Error message is to clean the corona wire.
  • Open front cover of the machine and remove the drum & toner cartridge assembly.
  • Remove the toner from the drum and gently shake the toner cartridge from side to side put it on a piece of paper to avoid scattering the toner.
  • Theres a blue tab on the upper left side of the drum, slide it from left to right, right to left about 5-6 times don't forget to put the blue tab back to it's home position(where the arrow is).
  • Put the toner back into the drum make sure it will click into place.
  • Reinstall the drum and toner assembly back into the machine and close the front cover.
  • LCD should display the date & time.
If you continue to receive the message try resetting the drum counter by doing the following:
  • Open the front cover
  • Press the Options key on the control panel. The display will show "REPLACE DRUM - 1.YES 2.NO".
  • Press 1 to reset the drum count.
  • Close the front cover
Hope this helps!
Vikroks
Mar 23, 2011 | Brother IntelliFax-2820 Laser Fax
Toner not reset
Mar 01, 2011 | Samsung SCX 4521F All-In-One Laser Printer
How do you change (where is it) the drum in the Okifax 5650?
rwhen you replace the toner youare putting it in the drum cartridge.the whole black unit gets replaced.lift it up to remove.when you replace it also install a new toner cartridge the drum resevoir will be empty when
new it will need a new toner cart. to fill it now you need to reset the drum counter.push select function
button,to the right number 8 or 9 says counter display
push it,screen will will say drum count reset? push yes arrow screen will say are you sure? push yes
tada! if it now says replace toner open the white cover
over the drum then reclose it a motor will run for about 30 seconds its adding the new toner to the
resevoir you may need to do this about 3 times or until add toner message goes away
Apr 20, 2010 | OKIFAX 5650 Plain Paper LED Fax
How to reset the scx 4521
6. To exit TECH MODE, press MENU # 1 9 3 4 in rapid succession, as if you were dialing a phone number. The operator panel should no longer display TECH. www.nakshatraworld.com
Dec 08, 2009 | Samsung SCX-4521 All-In-One Laser Printer
ERROR: INSTALL TONER
Toner Empty Message If a Toner Empty Message is Still Displayed After a New Print Cartridge Has Been Installed, Enter the Tech Mode and Perform a Manual Reset CAUTION: Make sure to follow this solution carefully as incorrect settings made in the Tech mode can cause the machine to become inoperable. The Tech mode is intended to be used by service and support personnel only.
Before performing this solution, make sure a new Xerox PE220 SmartKit Print Cartridge has been installed into the machine. Other print cartridges are not compatible with the machine and a manual reset should not be attempted.
If necessary, see the Related Items below for additional information on ordering supplies, consumables, and parts.
To enter the Tech mode and perform a manual reset:
  1. Enter the Tech mode:
    1. Press the [Menu] button on the Control Panel.
    2. Press [#], [1], [9], [3], [4] using the numeric keypad. 'Tech' will be displayed on the Display Screen.
  2. Press the [Menu] button until 'Data Setup' is displayed.
  3. Press the [Enter] button on the Control Panel.
  4. Press the [Left] or [Right] arrow button on the Control Panel until 'Clear Counts' is displayed.
  5. Press the [Enter] button.
  6. Press [1], [9], [3], [4] using the numeric keypad.
  7. Press the [Enter] button.
  8. Press the [Left] or [Right] arrow button until 'Used Toner Cnt' is displayed.
  9. Press the [Enter] button.
  10. Power OFF the printer using the power switch on the rear, right side of the printer.
  11. Wait 30 seconds and then power ON the printer
Aug 28, 2008 | Xerox Phaser 3200MFP/N Laser Printer
Printer
You will need to manually reset the toner cartridge.
If the Toner Low or Toner Empty message does not automatically clear after a new cartridge is installed, do the following to clear the message manually:
  7. If problem persists, there may actually be a problem with either the toner cartridge or the SCX-4216F.
Jul 14, 2008 | Samsung SCX-4216F All-In-One Laser Printer
Toner life end message flashes
did you reset the toner life?
open the front cover, press the option button, on the screen will display ''reset toner life 1 yes 2 no ''
press 1 and close the cover.
toner life reseted
May 06, 2008 | Brother MFC-7820N Laser Printer
Printing and copying almost blank pages
Ussally drum/toner would fix, will not be fuser, I would suspect Hi voltage board or laser unit, In australia these machines carry a 2 year return to base warranty.
Try reseting the drum counter, this also resets Bias voltage, might be your problem. open front cover with power on and press set, arrow to change drom and select yes.
Otherwise it would be a high voltage board problem, possibility alsoexist that it could be laser unit
Check status page for "71" errors, menu * 2 8 6 4 very very fast, machine will beep "maintence displays" then 77 to print out status page, 99 to return to normal.
Nov 26, 2007 | Brother MFC-8440 All-In-One Laser Printer
83 PHOTODEV CART MISSING
To specify which supply has been replaced:
  1. Make sure the printer is on and the Ready message is displayed.
  2. Press and release Menu until you see Supplies Menu, and then press Select.
  3. Press and release Menu until you see Replace Supplies, and then press Select.
  4. Press and release Menu until you see the relevant item:
      • Yellow Toner
      • Magenta Toner
      • Cyan Toner
      • Black Toner
      • Photodev Cart
      • Fuser
  5. Make sure the item you replaced is on the second line of the operator panel. Press Select.
  6. Press and release Menu until you see Replaced, and then press Select. The Saved message appears.
  7. Press and release Return until the printer returns to the Ready state.
Oct 15, 2007 | Lexmark C510 Laser Printer
HP LaserJet 4100 Printer Logo
189 people viewed this question
Seeker5211
Seeker5211
