Question about Dishwashers
Normal and Cancel lights are simultaneously flashing. Replaced control board but problem persists
  • 1 more comment
  • mwinniman Jul 27, 2009
    It is a Kitchenaid KUDS02FRss0
    So I closed the door and diabled the power. Then I re-connected the power and the flashing lights went out but the cancel light is illuminated(solid) and the pump starts to drain the unit for a few seconds. Then it stops and the normal light starts flashing again and the system is once again locked. I should note that this whole problem began immediately after one of the dorr spring cables broke.
  • mwinniman Jul 30, 2009
    Hi again,
    Checked the door latch and it looks fine, the switch works and has continuity at the correct positions. The capacitor has no continuity when tested with a continuity tester and reads 0 with an ohm meter. Please advise.
    President:
  • 1,776 Answers
Could you give me the model number and make of your machine, please?
Posted on Jul 27, 2009
  • 2 more comments
  • Bruce Canfield
    Bruce Canfield Jul 27, 2009
    Thanks for the Model number. I have been working diligently trying to figure out an answer for you, but haven't come up with much yet. I don't suppose the machine could be locked in diagnostic mode from where the new control board was installed, but try this, make sure the door to the machine is closed, and hit pots/pans heavy or anti-bacteria/cookware button to see if the machine advances through the diagnostic mode, if it is in one. It's worth a try. The door must be closed before the diagnostic test will run. Likewise, the door must be closed after each rapid advance selection of the appropriate key for the control to advance to the next interval of the dianostics or currently running cycle. If this is the problem, you will need to figure out which key on your machine (pot/pan heavy, anti-bacterial/cookware, or start button) advances the diagnostic mode.
    Hope this helps, but I have my doubts. Please let me know what happens. Best wishes.
  • Bruce Canfield
    Check the door latch switch. Test it for continuity to see if the switch is faulty. Also, check the strike plate and door closure. A loose door latch can cause these type problems. I am thinking about the fact that the pump tries to run and then freezes the cycle up. This condition could also indicate a faulty motor start capacitor. This can also be checked for continutiy to see if the component has an open circuit. These are some of the things that I would look at. This is a difficult situation to figure out, especially in light of the fact that the control board was just replaced. Just some ideas that you might want to check out. Best wishes and sorry for your delimma. Keep me posted. Thanks.
  • Bruce Canfield
    I was leaning toward a damaged door switch, since there is the possiblilty that it was damaged when the door cable broke. Keep me posted, Good luck.
  • Bruce Canfield
    Bruce Canfield Jul 30, 2009
    I think you found the problem. It sounds like the motor start capacitor is faulty. If it has no continuity, it indicates that it is stuck open. Sure hope this helped and good luck.
What does E61 service call on my frigidaire affinity mean???
read the whole manual no code e61 ?
READING ERROR CODES
1. Rotate cycle selector knob to the 3 O'clock position.
2. Press and hold the Select and Pause Cancel buttons simultaneously for six seconds.
3. Immediately after, press and hold the START and Pause Cancel buttons simultaneously for 4 seconds.
4. Rotate the cycle selector knob to the 2 O'clock position. The four indicator lights of Drying, Cool Down, Wrinkle Rid
(Press Saver), and Clean Lint Filter will flash the number of times for the first digit of the code and the START indicator
light will flash the number of times for the second digit. Take separate counts of each indicator light, then repeat to
confirm in order to be accurate in identifying the proper error code. The code is obtained by counting the number of times
the lights flash. Example E24: The four indicator lights would flash twice indicating the 2 and the START indicator light
will flash four times indicating the 4. The four indicator lights and the START indicator light start flashing at the same
time. The control will pause for 2 seconds, then repeat the code.
NOTE: A letter appearing in the code stands for a number higher than nine. A = 10 B = 11 C = 12 D = 13 E = 14 F = 15
Example Code E4A: the first digit would be 4 and the second digit would be 10. The four indicator lights would blink four
times and the START indicator light would blink ten times. Troubleshoot the problem by using the chart below.
To move on to the next code, press the OPTIONS button.
To clear code, press the Select button. Code will be cleared when mode is exited.
To exit this mode, simultaneously press and hold the Select and Pause Cancel buttons for six seconds.
Error Code Label Description Solution
E10 General EEPROM
Fault
Problem with communication
between EEPROM and the
microprocessor.
Clear code, exit mode and start dryer. If problem persists, replace electronic
control.
E11 Checksum Error Problem with communications or
memory did not check, one has
become corrupted.
control.
E12 Non fatal R/W
error
Problem reading or writing to the
memory or input/output.
control.
E24 Control NTC Short
Circuit
Control thermistor or its wiring is
shorted.
Remove wires from control thermistor. Measure resistance of thermistor. If
reading is not 50 K (± 10%), replace thermistor. If reading is within 50 K (±
10%), check wiring between thermistor and electronic control. If good,
replace electronic control.
E25 Control NTC Open
Circuit
open.
E4A Program Timeout
Fault
The drying time has exceeded
program time for that cycle.
Press Pause Cancel and SELECT buttons for 6 seconds to exit test modes.
Position cycle selector to NORMAL, temperature selector to HIGH HEAT
and touch START. Check for anything that would extend dry times such as:
no heat, restricted vent, blower fan blade broken or loose, dryer installed in
closet with solid door, or bad connection in moisture sensor bar circuit or
dirty bars. If dryer operates normally but code returns, replace electronic
control.
E5B Heater Fault (no
heating)
Temperature reading of control
thermistor has not changed in a
certain amount of time.
and touch START. Measure voltage across terminals on relay RL2 (heater
relay) on electronic control. If meter reads 240V on electric models and
120V on gas models, replace electronic control. If meter reads zero, remove
power from dryer. Disconnect wire going to NO terminal on the relay RL2.
Reconnect power and measure voltage drop between terminal COM on
relay RL2 and neutral. If meter reads zero, wire between incoming line and
relay RL2 is open. If meter reads 120V, check the rest of the heater circuit.
E68 Key (button) Struck
Fault
One of the keys (buttons) is stuck
closed (active).
Enter function test mode and perform key (button) test to determine which
button is at fault. Carefully free the and perform the test again. If button is
free but the key struck code still exists, replace electronic control.
E8C Too many trips in a
period of time.
The safety (high limit) thermostat
has tripped too many times within
a certain period of program time.
Check for blocked lint filter, blocked exhaust, air leaks around air duct,
broken blower fan blades, worn or loose drum seals, dryer installed in closet
with solid doors or door seal not correctly seated.
EAF Watch Dog Reset Microcontroller has been reset by
internal Watchdog timer.
Jun 14, 2014 | Frigidaire Electric Dryer
What does E6 error code mean
here is basic error codes for your dryer (and how to get them out)
READING ERROR CODES
E10 General EEPROM
Fault
microprocessor.
control.
become corrupted.
control.
E12 Non fatal R/W
error
control.
Circuit
shorted.
Circuit
open.
E4A Program Timeout
Fault
control.
heating)
Fault
closed (active).
period of time.
Jun 04, 2014 | Frigidaire Dryers
WHY DOES MY DRYER KEEP SHUTTING OFF WITH BLINKING LIGHTS
sure is heres how to get the fault codes
READING ERROR CODES
E10 General EEPROM
Fault
microprocessor.
control.
become corrupted.
control.
E12 Non fatal R/W
error
control.
Circuit
shorted.
Circuit
open.
E4A Program Timeout
Fault
control.
heating)
Fault
closed (active).
period of time.
May 09, 2014 | Frigidaire Dryers
Frigidaire affinity dryer yes code
heres how to get them :
READING ERROR CODES
E10 General EEPROM
Fault
microprocessor.
control.
become corrupted.
control.
E12 Non fatal R/W
error
control.
Circuit
shorted.
Circuit
open.
E4A Program Timeout
Fault
control.
heating)
Fault
closed (active).
period of time.
May 06, 2014 | Frigidaire Affinity 5.8 Cu. Ft. Gas Dryer
I can't turn on my KitchenAid Superba dishwasher. I pushed Normal and Start, and the Normal light started flashing, but didn't turn on. Pushed Cancel and now both the Normal and Cancel are...
Did you try turning off the power and then connecting it again?
If still problem is there open the door. Press the following sequence of buttons HI Temp Scrub, Energy Saver Dry,HI Temp Scrub, Energy Saver Dry. Now close the dishwasher door and latch it too and press the cancel button. This must reset the dishwasher.
Aug 13, 2011 | KitchenAid 24 in. KUDU02FR Built-in...
I have a frigidaire affinity dryer that will dry for a few minutes then turn off and say e68 wich means one of the buttons are stuck i took the panel of the front and checked the buttons and they all seem...
Run the service diagnostic mode to determine which button is stuck. Start by pressing and holding the Select and Cancel buttons simultaneously for 6 seconds to reset the control.
Rotate the cycle selector knob 5 turns counterclockwise to the second position from the bottom immediately after the buzzer sounds.
Press and hold the Options and Cancel buttons simultaneously for 2 seconds. The control enters the test mode and the buzzer will sound 3 times with all of the LEDs flashing.
Rotate the cycle selector knob 4 turns clockwise to the second position from the top and the dryer motor runs with the heating element off. The buttons can now be tested to determine which is stuck.
Press each button and all corresponding LEDs should light. If the LEDs corresponding to a certain button lights up without pressing the button or if the LEDs do not light up when the button is pressed, that button must be stuck or not making any contact when pressed.
Replace the control board if the stuck button cannot be unstuck or if there's no button that's apparently stuck but the fault code persists. Let us know if you need further advice.
Feb 01, 2011 | Frigidaire Dryers
My GU2475XTVY0 built-in dishwasher has the "Normal" light flushing since yesterday morning. We pressed "Cancel" button, other buttons, and finally turned the power off and on, but it didn't do anything. Do...
Hello- The touch control pad is failing and must be replaced. If unit is under warranty, get it serviced. This control is about 125$. Let me know if this info helps. Thanks-Ed
Mar 08, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
Flashing clean light
press:
heated dry
normal
heated dry
normal
then cancel..... wait until 2 minute cycle is done.
Then push start to run another cycle. Saw this on another post by a guy named rhinostack and it worked. They said that if it did not reset then either the latch has a bad connection or the heater for the water is bad.. it must register that the door is closed in order to actually start the heater for the water. I hope this helps you as well as it helped me.
Jan 15, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Green light on kenmore dishwasher is flashing
I actually had to change the steps a little and this is what I did:
press heated dry
press normal wash
press heated dry again
press normal wash again
wait a few seconds
all the lights should come on
press cancel (should hear pump)
hit cancel again
Started a cycle and began washing.....Thx
Dec 31, 2008 | Kenmore 24 in. 16039 Built-in Dishwasher
Error code e10
Communication failure =E10
1. Rotate the CYCLE SELECT KNOB to the 3 O’clock
position.
buttons simultaneously for (6) seconds.
Pause Cancel
buttons simultaneously for (4)
seconds.
4. Rotate the CYCLE SELECT KNOB to the 2 O’clock
position.
The STATUS indicator lights will flash the number of
the lights flash. Example E24: the STATUS indicator
indicator light will flash four times indicating the 4. The
STATUS indicator lights and the START indicator light
will start flashing at the same time. The control will then
Troubleshoot the problem by using the chart on next
page.
To move to the next code, press the OPTIONS button.
To clear code, press the Select botton.
Select and Pause Cancel buttons for (6) seconds to
reset.
if this does not work need to replace control
Sep 07, 2008 | Frigidaire Washing Machines
Dishwashers Logo
69 people viewed this question
Top Dishwashers Experts
