Question about Bausch and Lomb Bausch&Lomb Classic Metal Eyeglass Loupes w/ Free UPS
I have an old pair of Air Force issued prescription dark glasses.
One of the wires which goes around one's ear broke close to the hinge. I'm looking for a replacement.
    Sniper:
  • 73 Answers
If these are the same as the Bausch & Lomb 'Aviator' style. Contact Luxotica. They purchased Bausch & Lombs Sunglasses division. I personally prefer the hooked wires to the standard arms and have purchased the hooked arms to replace the standard ones for other B&L sunglasses.
Another option could be to buy a cheap pair of dubious origin 'genuine' Raybans on the auction site and take the hooked arms off.
Posted on Jul 31, 2009
Is there a way to reduce glare on a pair of plastic prescription glasses
My wife wears some sunglasses over the top of her prescription glasses .
Apr 23, 2015 | Clothing Accessories
Do you need to have a proper eye test to find out what number reading glasses you need?
- No - reading glasses are literally to help correct problems with reading that come with age. It's a separate issue to near and far sightedness. You can just try on pairs of reading glasses in the shop and try reading until you find the correct number for you.
- As they are not proper prescription glasses they should be a lot cheaper than real glasses.
Feb 13, 2013 | Health & Beauty
Can you put prescription lenses into sunglasses frames? I have to get my eyes checked in about two weeks and I've gotten the use out of my current pair of glasses so I'm pushing to get new glasses. My...
Yes it is possible.. Oakley makes RX lenses specifically for some of the frames. the previous poster makes some invalid points in terms of what you are talking about. Oakley makes many more frames than just "sporty" frames that fit tight to your head. Oakley glasses are held onto your head by the shape AND by the hydrophilic rubber pieces (called Unobatnium) in glasses that are less wrapped. You mentioned that these looked like Rx Frames / regular glasses frames. Please note, Oakley makes RX frames, as well.
If you go to Oakley's website and look under Rx Sunglasses, you'll see which can be made with prescription lenses, AND ones that you can have an Optometrist cut regular lenses to fit.
However, please note, many Opticians, have lab do their cutting work and some labs will NOT cut for an Oakley frame. If your eye doc allows you to take him a frame, then he should be able to have it cut. It depends on the lab. It may be easier to find a Optometrist with his won lab on site. Those are places that will custom cut.
Of course, if you, as the previous poster stated, do go with a very sunsglasses / sport model, you'll need to stick with the Oakley specific sport sunglasses lens as the lense curvature may be hard to match.
Nov 07, 2010 | Clothing Accessories
Double oven top door will not close
you need to change you oven hinges, change them as a pair cost around £40.00 to buy, not a hard job to do
Apr 07, 2010 | GE Profile JTP56 Electric Double Oven
ACER Aspire 9140 LCD hinge and/or LCD frame
Contact a local computer shop or a TV repair shop. Best bet is eBay, look for a completely trashed laptop just for a frame and hinge.
As far as mail-order/online, try this site:
http://www.excelcomputerinc.com/html/xlsearchmodel.htm#acer
Hope this helps
Apr 22, 2009 | Acer Aspire 9410 Notebook
Jenn-Air electric wall oven door opens slightly when in bake mode
you either have a bent door hinge or a broken door spring.
check the hinges by opening the door and see if it opens past 90 degrees. if it leans towards the floor then the hinges are bent.
if not then your door springs are broken off. you can check this by seeing if the door "feels" heavy when opening.
either way the door should close tight against the frame when up and the light should not come on without opening the door.
Jan 22, 2009 | Jenn-Air 27 in. Electric Single Wall Oven...
Broken ear hook
you can order it by pack of five directy to the producer
http://www.natcellusa.com/
Nov 26, 2008 | Southern Telecom Emerson Bluetooth Headset...
Access Door won't close. Used some force and both hinges broke !
not really..that's a service level repair that takes around 1.5 hours with the right tools
Aug 01, 2008 | HP Photosmart 3310 Printer
KITCHEN AID KEBC107KSS03 DOOR. REMOVE INNER PANEL. CLEAN GLASS
LOOK WHERE THE HINGE METS THE OVEN DOOR FACING..you will see on the hinge a tab with the door open pull these forward this will lock the hinges do this on both sides then closed the door slightly and lift up the door will come off then you can unscrew the bottom scres to access glass
Feb 22, 2008 | KitchenAid Architect Series KEBC107KSS...
KESC307 Oven Door
Hi Mcrae...
Generally, the procedure is a straightforward mechanical one.
First, check below the door for screws and remove them. Next, open the door and find the screws on the side and inside of the door. Remove them. Careful...when the door panel comes off, the door will be much lighter and will slam closed if not restrained. The panel should 'fall away' from the door. Have someone assist you here! At each stage, take a digital picture of the disassembly so you can assist yourself in putting it back. Clean the glass with a blue cleaner and buff out. Use a scrubby or very fine steel wool to gently remove any stains from the old glass you're reusing. Do this on a bedding of newspaper. Always handle glass by the edges.
When installing the glass, it should generally be apparent which way it goes in. Some glasses have patterns on them which correspond to the door opening...if it is the outer which is being replaced. Note them. There may be an up or down as as a result. Any foils or patterns are positioned to the direction you won't have access to later.
You'll likely need a second pair of hands to put it all back together. Take your time. Don't force anything. Tighten screws evenly.
Nov 18, 2007 | KitchenAid KESC307 Electric Kitchen Range
Optics Logo
83 people viewed this question
Top Bausch and Lomb Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Piyal Perera
Piyal Perera
Andrew Taylor
Andrew Taylor
Are you a Bausch and Lomb Optic Expert? Answer questions, earn points and help others
