Question about Nokia 5800 XpressMusic Smartphone
I cant answer a call using the touch screen
When i have an incoming call i have to use the green key to answer the call.
I cannot slide open my LG phone. I hear my Messages but can't open the phone, no matter what
What is your phone model?
These answers were given assuming that you're using a LG smartphone with a touch screen :
Scenario 1 : Can you see the screen lights up and any sort of graphical image when you hear incoming message ?
A : If you can, and still you cannot slide unlock, your touch screen has gone. Get a replacement touch.
Scenario 2 : You cannot see anything on the screen. It stays dark when you hear incoming messages/calls
A : Your LCD has gone. A replacement LCD or a Touch/LCD combo would fix the issue.
I hope you saved your back by either way.
May 29, 2017 | LG Cell Phones
I bought yesterday my Samsung GalaxyS. It had no user manual. When I receive an incoming phone call - I press the green phone handset and it keeps on ringing. I cannot answer any phone calls.
Open the menu bar, cliq on settings, then cliq on call settings then check if it is on any key answer, then choose the key you want use in answering your calls.Thank you for using Fixya.
Sep 10, 2011 | Samsung Captivate Cell Phone
How do i use call waiting for samsung fascniate for verzion
If you don't see an option on the screen to answer the second incoming call, simply press the call button (green phone key) to switch between calls.
Jul 15, 2011 | Cell Phones
When i touch the screen nothing happens , i cant open home or answer my incomming calls.
problem with touch screen
your mobile needs one of tow : -re install the mobile firmware if it doesnt work that means your touch screen needs to be changed
May 10, 2011 | LG Rumor Touch
Htc touch phone locked up, can answer and redial by using green key, touch screen is in-op
You may have to do a hard reset, remove battery and memory card, replace battery, hold down on/off button & green & red buttons all at the same time. This will fully reset the phone but you will loose all stored data, which is why you remove memory card first.
Dan.
Nov 25, 2009 | HTC Touch Cellular Phone
Cant touch ringing phone without cutting off the connection!
Go to this menu in your phone, Settings and Tools, Call Settings, In Call Setup, Answer Options,
Now, turn Multi Key to Off and then select Open To Answer and set it to On.
Press CLR to back your way out and you should be good to go. Just remember one of these keys on the side is Speaker Phone On/Off and many men hit this by mistake very often.
If you have any question on this please use the comment box below to request clarification.
Regards,
Worldvet
Jun 11, 2008 | Motorola Mobility RAZR V3
Nokia 5800 XpressMusic Smartphone Logo
135 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
