I am trying to connect a Sony Trinitron TV and HP Pavillon laptop through the S-video cable. I press FCN F4 and the image appears in the TV, but it only lasts for 1 second, then it disappears..As if the Tv couldn´t handle the image. Do I have to make changes in my computer resolution?
    Brigadier General:
  • 4,090 Answers
Yes lower the resolution. it would also depend on the age of the TV and whst vresolution it can handle Some of the newer ntv's can be varied to accept sevral resolutions so as to be able to play games etc.
Posted on Jul 27, 2009
I want to connect my sony tritron tv to my hp laptop
If you Sony TV has a VGA video input socket then connect a VGA video cable to the TV and the other end of the VGA cable to the VGA video connector on your laptop.
Power up the TV and go to the Input selection Menu and select PC connector then boot up your laptop and the Windows video data will automatically to the TV.
You can toggle between the TV the LCD or both by pressing Fn key plus F4 key.
May 29, 2012 | HEWLETT-PACKARD G71340US Laptop
Broken Laptop screen, trying to connect to tv.
OK, you have to hit the FN (Function Key) + the F4 key to get the image to display on the TV. Press and hold the FN key then hit the F4 key and the image should appear on the tv if you have a VGA cable connected to the TV and to the HP Netbook.
Once you see your desktop on the tv you can get your files off my purchasing a USB Flash Drive of at least 8GB or 16GB (Just depends on how big your My Documents folde is). Then put the usb flash drive in the usb port and copy whatever files you want. Most of the things you want will probably be your documents, music, pictures and videos. These are normally found in the My Documents, My Pictures, My Music, My Videos folders. There is no need copying things like programs or other stuff because they will not work. They have to be installed thru the normal process to update the windows folders, settings and registry.
Mar 21, 2012 | HP Mini 1000 Netbook
When i connect my notebook to LCD TV with hdmi port, screen goes black but on TV "No signal" message appear and can`t view the monitor on TV. I have windows XP sp3 on the netbook HP 425
From page 47 of the user manual for the HP 425, "Press fn+f4 to switch the image between the display devices connected to the computer."
Press and hold the "fn" key on the keyboard of the laptop while pressing the F4 key to toggle the image between the laptop screen and the external monitor.
Thanks for using FixYa
Apr 23, 2011 | HEWLETT-PACKARD HP 425 WZ266UT Notebook
I cant get picture when i connect my pc to sony trinitron i need help
Connect your PC to the TV, select the correct TV input, on the PC press the fn + f4 key until the PC displays on the TV
Jun 26, 2010 | HP Pavilion dv6000z Notebook
Tried projector no work
Connect your projector to your laptop using a VGA cable. Now turn ON your projector and your laptop.
To make your screen projected, look at your function keys (F1 to F12). Look for the icon which looks like a laptop LCD and a TV. It should appear like LCD icon/TV icon. In some model it is in F4 while F3 in Lenovo. Example, you found the icon in F4, just press and hold down the FN key and press F4 to send your desktop image to the projector. This combination is called the "dual monitor" setup which in your case, the second monitor is a digital projector.
Jun 23, 2010 | Everex StepNote NC1500 Notebook
Laptop to tv
Your model laptop has S-Video out capabilities. Depending on what model TV you are connecting to, you would then need an S-Video to (whatever input connection your TV supports: S-Video, VGA, RCA, HDMI) cable. Once you have the cable connected, set your TV to the input method for the cable used, and press Fn + F4 on your laptop Keyboard to project the image over. May need tp press more than once depending if you wish to only display on one screen or both. S-Video is only a video out cable, so you will alos need to run an audio connector cable from your laptop to TV as well, or just use a pair of external laptop speakers for your sound.
Jan 12, 2010 | Computers & Internet
I have an Acer Aspire 8930G trying to connect to my TV with HDMI
After you connected the HDMI Cable to the TV...Did you press the FN + F4 Key on the keyboard... The first screen you will see is the notebook screen is blank and the TV has got the desktop on top of it...The second time you press the FN + F4 then you will see thedesktop on the notebook and as well as the TV...The third time you press the FN+F4 you will see the desktop on the Notebook...
Aug 15, 2009 | Computers & Internet
"no signal" message when laptop is plugged into projector
There is a key on the keyboard that has blue text on it. Something to the effect of LCD or CRT. With the monitor connected and turned on, press and hold the FCN KEY as well as the LCD/CRT key. While holding the FCN key keep hitting the CRT key until the image transfers to the external monitor
Apr 17, 2009 | HP Pavilion ze2000 Notebook
HDMI HP Labtop to Mitsubishi HDMI not working
Easy...first connect the hdmi cable between laptop and tv. Press and hold the 'fn' key on the laptop keyboard - bottom left corner. while holding the fn key, press and release the F4 key. This will toggle the laptop between its multiple display capabilities.
Press and holfn - press and release F4 until you get an image on the big screen.
Enjoy :)
Dec 22, 2008 | HP Pavilion dv7-1130us laptop
Hooking up my hp laptop to a sony trinitron tv
Let me explain on how to connect the TV to HP notebook.
There are two ways to connect the TV to the notebook. One is with the S-Video cable and another one is HDMI cable. (If you computer had HDMI port)
Connecting notebook and TV with S-video cable:
You need to get the Svideo cable and connect it to the notebook Svideo port to TV Svideo port and press Fn+ F4 to get the notebook display on the TV.
For the first time pressing the Fn+F4 keys, you will get the display on the TV and there will be no display on the Notebook.
If you press the Fn+F4 for second time, you will get display back to the notebook and Tv screen becomes blank.
By pressing the same keys again will show the display on both the screen.
Samething connecting with the HDMI cable, if your computer had HDMI port.
If you won't get the display on the external screen even after following the correct process, then once you need to reinstall the display driver.
If the issue persists, then you have to check with another cable.
Note: No need to install any software on the notebook to connect the TV to the notebook.
Aug 01, 2008 | HP Pavilion dv6000z Notebook
Computers & Internet Logo
52 people viewed this question
David Payne
David Payne
