Question about Whirlpool Dryers
The flame goes on at first but then turns off and does not come back on, the dryer turns but does not heat up.
  • jbreyer Jul 27, 2009
    Nothing blocking and the glow bar goes on but then goes out.
  • steve
    steve May 11, 2010
    Make certain the exhaust vent is totally clear. No obstructions.Make sure the glow bar ignitor glows brightly. Check these things and report back.
  • Whirlpool Master
  • 3,361 Answers
Replace the gas valve coils.
Posted on Jul 28, 2009
Whirlpool dryer heating sporadically?
Remove the lower front panel and turn dryer on. The ignitor should glow bright orange first. After Ignitor glows brightly the next thing will be the flame lighting as the gas valve opens with a click. All this should happen within about a minute or so.
If flame comes on but goes off quickly It's likely one of the Gas valve coils is opening a break in the coil as the coil heats up. This coil will shrink when cool and be able to run again. The coils are purchased as a kit.
If ignitor goes off and no flame comes on the coil kit is likely needed because one coil is fully broken inside its case. If flame goes on but shuts off shortly the problem is as described above and the kit is needed.
There is a flame safety assembly on the can above the burner. If the airflow is poor. the flame tip may activate that safety and turn the flame off. Or the flame switch may be open and not allow the flame to come on at all.
The Flame switch can be tested for continuity with an ohmeter but the valves may ONLY show bad with power applied and can not be tested with a meter as they will test good.. Good Luck
Nov 18, 2015 | Whirlpool Dryer. Gas Dryer. 7.0 cu. ft. in...
On my Kenmore Soft Heat Heavy duty gas dryer I am having problems with the the fire lighting and going off intermentently . The fact that it ignites and then goes out makes me think that it isn't...
Hello Jerry,
It is working like its supposed to when the flame goes off, the way all dryers work is the flame(heat element on electric heated dryers) comes on and when the drum exhaust temp reachs a maximum of 155degrees and the flame goes off, the air temp will cool off to 120degrees and the flame comes back on and cuts off once again the 155 degrees has been reached..much more that 155 degrees the clothing is very likely to combust and catch on fire.
Please reply and let me know if your having a dryability issue with your dryer or where you just concerned since the flame went off??
GENE
Sep 05, 2011 | Kenmore Dryers
Heats but wont stay heated
If the flame come on to start with, but then goes out and won't come back on I would suspect you have a bad coil on the gas valve.
If you see the flame cycle on and off, but the flame does come back on again this is normal. The flame needs to cycle on and off and not be on steady or the dryer would get to hot.
If the flame is cycling ok and the cloths just don't get dry then you need to check your dryer and vent for lint build up.
Aug 02, 2011 | Roper RGX4634KQ Gas Dryer
When my mdg 6000bww is turn on heating element glows, flame ignites, then flames goes off within 5 minutes. After waiting approximately 15 to 20 minutes, until it seems to cool down can restart and goes...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Aug 23, 2010 | Maytag Neptune MDG5500AW Gas Dryer
My dryer flame lights then goes out after a little while. It does this on timed as well as amount dried cycles. Drum still turns but heat goes out. I can usually get it going by starting the dryer again....
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 12, 2010 | Frigidaire FGQ332ES Gas Dryer
Mdg 4000aww turns on and heats when started. runs for 5 five minutes then flame goes out. ignitor glows but no flame. one minute later dryer still running ignitor glows, no flame. this repaets until turned...
Either the venting needs cleaned or the coils on the gas valve are bad. Unhook the venting from the back of the unit and run. If works ok then clean venting. If you still have the problem, replace the two coils on top of the gas valve.
Sep 29, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Inglis gas dryer heat loss
Replace these solenoids on the gas valve. Feel them if you can. They get hot and quit.d910ca8.jpg
Feb 04, 2009 | Dryers
Whirlpool gas dryer heat goes on then off then on again
should have electronic igniter that light gas after turned on.
Jan 03, 2009 | Kenmore 73952 Gas Dryer
Intermitten Heat up
make sure that your vent is not plug up can you go outside your house and feel good air coming out the vent when the dryer is turn on if so the only other things it could be is the coils that sit on the ignotor assmebly or the high limit termistat is not working properly the coils are little black circle coils that sit in the ignitor assmly should have a metal braket across the top of them holding them in you can check resistance on these coils if you have an meter
Mar 22, 2008 | Kenmore 72802 Gas Dryer
Dryers Logo
61 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
