Question about Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher
Fisher & Paykel DD603 model Upper Dishdrawer has F3 fault code. cycke starts, then stops within minutes. Water in tub after stopping is not hot. Temp sensor bad? Could you please send pdf of servie manula for dd603 please? Thanks cincyr1@yahoo.com
  • 77 Answers
F3 means your dishwasher water is too hot. Go to the link below and it will show you how to determine what is causing the error.
http://www.appliancerepairlesson.com/category/dishwasher-common-issues-repair/
Good luck
Posted on Mar 05, 2011
  • 205 Answers
Hi- sounds like the controller is not sensing the right temp or possibly the heater plate is bad. I'd get a Tech out to take a look. The controller is not cheap unfortunately. These units should not be taken apart unless you really know what your doing. I've had to repair a few that other untrained Techs have damaged... Good luck.
Posted on Sep 23, 2010
    Sniper:
  • 81 Answers
Below is the link. Although it is for the DD601v2 the DD603 follows the same principle.
http://www.scribd.com/doc/6462163/DD601V2-Manual
Mat
Please rate me
Posted on Sep 24, 2009
My Fisher and Paykel dishwasher serial # starts with 88445 ERM - What year was it manufactured? 1995? 2005?
ERM was manufactured June 2005 according to this serial number. The product code (on the model/serial tag) would further refine the dishdrawer details.
Oct 31, 2016 | Fisher and Paykel Dishwashers
Errors and restarts
will need a description of the problem. Some of the common fault codes are F1, F2 and F3.
All these fault codes stop the dishwasher and will not go away until the cause is removed. Please indicate the problem you are experiencing.
Jan 02, 2013 | Fisher Paykel Fisher & Paykel DishDrawer...
DD603 gives me an F3 and stops before wash ends, then beeps.
Hi- The F3 fault is related to the water temperature. Probable cause is the controller not sensing the correct water temp. It is also possible the the heater plate is faulty. Hope this helps.
Sep 09, 2010 | Fisher and Paykel 23 in. DD-603 Built-in...
F3 error showing
F3 means the Dishwasher thinks it's water temperature in the tub is over 80oC. So when the unit stops see how hot the water is. The unit has a temp sensor which is part of the element which maybe faulty, the element maybe faulty or the Motor controller module is faulty. I'd try the Motor Controller module first as replacing the element can be a tricky job if you haven't done one before. If you have a double dishdrawer you can swap over the Motor Controller modules (main computers in the front of each drawer) as the top and bottom are the same part, inturn you will prove 100% if this is the fault or not without buying a new controller. Cheers
May 31, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher and paykel DD605SS
I can talk you through finding the fault on live chat. cheers
Mar 15, 2009 | Fisher and Paykel 24 in. DD603H W Built-in...
My f & p dishdrawer model DD603 has fault code F1:
Yes, you need to gain access to the inside bottom panel of the dishdrawer and drain/dry the water in the bottom panel. When all of the water is gone the polystyrene block will lower and turn off the flood system. You then need to find the reason the unit flooded and rectify it or the unit will just do the same thing again.
Mar 15, 2009 | Fisher and Paykel 23 in. DD-603 Built-in...
Fisher paykel DD603 top drawer starts cycle then stops and beeps and doesn't go thru cycle
When it stops and beeps can you tell me all lights that are on when you open the drawer cheers. also check to see if the water in the tub is hot if not you have a heating issue. either a faulty element or Mtr Controller module. try swapping the Mtr Controller module (computer board) from the top drawer to the bottom drawer and see if that moves the fault. cheers
Mar 07, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher and Paykel DD603 service manual
Check to see if the Child lock is on...Check your email
Aug 28, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher-Paykel DD603 DishDrawer shows F1 fault code. The Flood Switch has been activated. I need instructions on how to re-set the flood switch. I have two drawers that are possitioned one above the...
Fisher-Paykel DD603 DishDrawer shows F1 fault code. The Flood Switch has been activated. I need instructions on how to re-set the flood switch. I have two drawers that are possitioned one above the other and the are both giving the error of the activated flood switch. Any advice or instruction is greatly appreciated.
Jul 22, 2008 | Dishwashers
Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher Logo
718 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
