Question about IBM ThinkPad X31 Notebook
IBM Thinkpad x31 stuck on dock station
Lever might be broken--kind of loose. Has anyone come up with a solution?
Where is docking station release lever on ThinkPad X31 (P/N 91P9024)? Please advise.
should be top right corner. push down.
make sure the key is not in lock position.
Jun 12, 2011 | IBM Computers & Internet
Cant remove ibm thinkpad x31 from docking station
Press the "release" button/lever, to allow the ThinkPad to be "unlocked" and released from the docking station.
Jan 27, 2011 | IBM ThinkPad X31 Notebook
Can't remove x31 from docking station
You asked this question a year ago, and did not get any help.
So, it's time to take a chain-saw to the docking-station, to "sacrifice" it,
and then purchase (on eBay?) a replacement docking-station.
Sep 30, 2009 | IBM ThinkPad X31 Notebook
2nd Hard drive not recognized
If your using IDE hard drives i would try to put them both on the same cable on the primary IDE controller. Then set you main hard drives jumpers and the second hard drive to cable select not slave. Try to boot if the boot fails your goiong to need a Windows 98 boot floppy with FDISK. You need to start up the 98 boot disk with out CD support then when it reaches a command prompt start fdisk. ONce fdisk is up format and partition the second drive. Now it should work. :) Check that the harddrive is detected in the BIOS, it may have become disconnected, it should also be the master drive on the primary IDE. If the drive is not detected in BIOS there is little chance of it working
Thank you....
Jan 29, 2009 | IBM ThinkPad X31 2672 Notebook
My printer has a parallel plug and my new docking station...
You can buy a cable that goes on your old printer cable to convert to USB most computer shop will hav these or can get one
Jan 25, 2009 | IBM (250410U) Docking Station for ThinkPad
IBM ThinkPad X31 Notebook Logo
451 people viewed this question
Top IBM Computers & Internet Experts
Computer Links
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
