Question about Kitchen Ranges
Oven wont regulate temp
My magic chef kitchen stove ( model number 318a-7 ) is causing me grief. when we turn the oven on it doesnt stop heating up. it will continually run until it is turned off. we sometimes have to keep turning on and off to get it to work on its own. any assistance in solving this problem without contacting repair man greatly appreciated. thank you
  • 3 more comments
  • amc320 Nov 22, 2007
    knob controls temp
    already tried that one--twice
    according to testers---wires are making connections. no shorts registering anywhere. ive put 2 new thermostats in to this thing.
    i give up. wife calling serviceman to come out and look at it. thank you for trying to help me. have a great turkey day my
    friend
  • dwetter Apr 03, 2008
    I've got a GE Spectra whose thermostat works very erratically. Takes forever to get to 350. If you want to get it to 350, you have to set it to 425 to get it up to 350. Sometimes it heats up to 450+, even though you set the therm to 350...makes baking extremely difficult...and makes me swear like a sailor? I hate to call Sears try to fix this. Seems it should be something we can fix/replace. Suggestions?
  • 213 Answers
Is your temp control operated by a knob or push button?
Posted on Nov 22, 2007
  • 1 more comment
  • chris hooper Nov 22, 2007
    the thermostat needs to be replaced. it cant tell what the temp is so it will just keep going.
    if youve already replaced the thermostat and that didnt fix it you need to look for shorts to ground. the bake elent has one line going to it that is always powered. the other side of that power comes from the thermostat. so it has to be a wiring problem or a bad thermostat
    ive been in the appliance repair business for 20 years. the only thing that tells that element to cycle on and off is the thermostat. when you replaced it did you do it wire by wire? if not did you double check the wiring diagram to make sure all wires are in the correct place? only other rare possability is does you oven have a seperate selector switch or is it all built into the thermostat? if there is a seperate selector switch then you might have a problem there but like i said thats rare
HOW DO I REMOVE THE LOWER ELEMENT OF A MAGIC CHEF STOVE OVEN
What is the complete model number of your unit? Look inside the door area.
Nov 28, 2012 | Magic Chef Kitchen Ranges
My magic chef stove model#31100paw oven will not heat up but all four stove burners are working just fin.what is going on?
This oven and range work from two separate regulators and it sounds like the one for the oven has failed. Have it replaced and that should get you going again. Hope this helps. Good luck.
Mar 15, 2010 | Magic Chef 31000 Gas Kitchen Range
When I turn on the stove an F3 message comes on
Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok.
Nov 26, 2009 | Magic Chef 31000 Gas Kitchen Range
Oven wont work after disconnecting the power
clock going out. need to check to see if your igniter is glowing. it could be glowing but still be to weak to open valve
Jun 22, 2009 | Maytag MGR5751AD Gas Kitchen Range
Magic Chef oven & broiler do not work
you know i am thinking more towards a bad temp probe.
May 28, 2009 | Magic Chef 31000 Gas Kitchen Range
Ovens not lighting magic chef
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
wwt
Dec 30, 2008 | Magic Chef 31000 Gas Kitchen Range
Magic Chef freestanding gas oven/stove - oven won't ignite and heat, stove works fine.
most common problem with gas stoves is a bad oven ignitor, doesyour oven usually "click" start?? or use a glow style ignitor?? do you have the model number??
Mar 17, 2008 | Kitchen Ranges
Magic chef stove
If the oven is working but the control does not light up then you will have to replace the control.  If the oven doesn't work then will have to check and see if you have power to the control.  If power is there then the control is bad.
Oct 25, 2007 | Magic Chef CER3725AA Electric Kitchen...
Kitchen Ranges Logo
199 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
