Question about Tomtom ONE GPS Receiver
Tom Tom sound only works after 30 minutes
My Tom Tom one V2 has a sound problem. The sound does not work until the unit has been switched on for 30 40 minutes. After that it will work fine until the next time it is used.
    Brigadier General:
  • 4,090 Answers
Could be many things, but my guess is a damaged track. The heat causes expansion and closes the gap. A kludgey test would be to pre heat it close to a warm source and then turn it on to see if the sound is relatively instant.
Finding the break without experinece and a very large magnifying flass may also be difficult. If you do find the break a very fine needle point soldering iron and solder is needed.
Posted on Jul 27, 2009
    Brigadier General:
  • 3,513 Answers
The reason for your Tom-tom V2 not to have sound is due to a bad connection to the speaker. I am sure you have tried to reset the set. If yes please try to do the bellow mentioned steps.
Now it’s risky to take the back off as it is easy to damage screw poles if screws are tight. There is no guarantee that the problem will be fixed by tapping it with the back off, you can tap the back of the case where the speaker is anyway.
Lots of tom-toms have sound problems and it’s the cheap and nasty speakers they put in them in the first place.
Better to take it to a service centre and if its warranty make a claim
You need to unscrew 4 torx crews and pop out the back cover slowly. Remove the speaker's wire connector and check speaker resistance 3-4 ohm. Next reattach connector firmly and did a speaker test in volume preferences menu
Thank You for using Fixya.com
My ps3 slim keeps turning off after 30-40 minutes? After I leave it for a while it works again for 30 - 40 minutes until it happens again.
Hi.
It sounds like the console is overheating. Turn the console off and check the air vents for any build up of dust and clean them. Also make sure the console is in a well ventilated area.
Regards.
Jul 16, 2011 | Sony Playstation 3 (PS3) Console
No sound from the unit. No voice annoucements etc
hi go tomtom.com, sel support, search sound, check if preferences are right. try soft reset, good luck.
Feb 19, 2010 | Tomtom One Europe v2 GPS Receiver
No driving sounds on Tom 520
I removed the SD Memory card & re-booted the Tom Tom now working again
Jul 06, 2009 | Tomtom One Europe v2 GPS Receiver
No signal
I have a Tom Tom One and sometimes it behaves as if there are no satellites no matter how long it is switched on for but I now just drive off and within a few seconds (30 seconds at most) is it suddenly acquires the satellites and it's OK. It just seems to be a quirk of the device and it doesn't do it all the time.
If it still does not acquire satellites on the move then it is probably faulty and needs to be repaired.
HTH
Peter
Feb 06, 2009 | Tomtom One Europe v2 GPS Receiver
Tom tom one switch on
with tomtom turned on, remove SD card and press RESET, turn off tomtom and insert SD card and start tomtom, problem solved :))
Dec 06, 2007 | Tomtom One Europe v2 GPS Receiver
New tom tom device
Try resetting the device: -Charge it until it is full. -remove the SD card -press the reset button (with a pen) for 15 seconds -Hold the on/off button for at least 15 seconds -reinsert the SD card
Aug 12, 2007 | Tomtom One Europe v2 GPS Receiver
No sound
First try plugging in headphones and seeing if that works. If it does, your speaking is history and you need to contact TomTom tech. support. They will replace the speaker for you once you send your model to them. If that does not work either, you will still need to contact TomTom, but the problem will be very different. There is a slight chance the sound board for it has gone bad. I am not sure what they will do for that problem, but they should replace the unit for you. Contact them at http://www.tomtom.com/support/support.php?ID=2
Jun 28, 2007 | Tomtom One Europe v2 GPS Receiver
Tomtom ONE GPS Receiver Logo
112 people viewed this question
Top Tomtom GPS Experts
LP
k24674
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
