Question about Intel Motherboard
Drivers howto download inteld945gcl motherboard drivers
  • 385 Answers
Go to this website:
http://downloadcenter.intel.com/filter_results.aspx?strTypes=all&ProductID=2613&OSFullName=Windows*+XP+Professional&lang=eng&strOSs=44&submit=Go%21
When you are there, select the specific driver you are looking for and save to your computer.
Thanks,
Lolita
Posted on Nov 22, 2007
How to downlaod audio drivers mercury PI945GCM drivers
Hi madhukar009,
The easiest thing that you can do now is to do a system restore, using the System Restore utility.
Here's a link about how to use the system restore utility on Windows XP:
http://www.microsoft.com/windowsxp/using...
Here's a link about how to use system restore from Windows Vista:
http://www.howtogeek.com/howto/windows-v...
Here's the easy way to get or update your sound drivers:
You could try to use this driver scanning tool, which scans the computer for needed drivers and has an option to automatically retrieve them for you.
You can download this free tool from here: http://xpdrivers.com/index.cfm
OR http://driversdownloaddriver.com/tag/mx46-800m-driver
Once on that page, select your preferred language, and the operating system you are using. You will then be able to download the driver you need
Dec 23, 2010 | Mercury P4VM800M7 Motherboard
Tip
FREE Printer Drivers for Lost Driver Installation Discs
Download Drivers,...
Download Drivers, Software and Manuals for free from the manufacturer website.
Epson Stylus Multifunction Printer/ Copier/ Scanner InkJet
HP Multifunction Printer/ Copier/ Scanner InkJet
Canon Multifunction Printer/ Copier/ Scanner InkJet
Brother Multifunction Printer/ Copier/ Scanner InkJet
Lexmark Multifunction Printer/ Copier/ Scanner InkJet
Remove and Install the Printer Driver for your product:
DRIVER REMOVAL
1. Turn off the printer and disconnect the USB cable.
2. Click the Start button and select Programs or All Programs.
3. Locate and select Printer Software Uninstall.
4. Restart your computer !
INSTALLATION
1. Go to the support website.
2. Select your model and download the printer driver for your Windows operating system.
3. Double-click the downloaded file and follow the on-screen instructions.
4. When prompted, connect the USB cable and turn on the printer. Installation should complete automatically.
Do not reconnect the USB cable until the point in the printer driver installation where you are prompted to check that the unit is on and connected to the computer.
on Jan 01, 2009 | Epson Stylus Multifunction Inkjet Printer/...
SOUND CARD DRIVER FOR INTEL P4 2.4 GHZ
Hello someone_sanj
  1. your motherboard has a packaged CD containing all the drivers needed. after installation of OS (operating system), put the driver CD in your CDROM/DVDROM device. The CD should autorun itself, if not then explore the CD then find "Setup". double click it. if prompted with menus, select best one relating to "Audio"...restart computer after installation and play sound file formats.
After you have downloaded the above file, double-click on it and follow the simple steps to install it. Then, when it asks if you want to run it, just answer yes. This is easier than manually searching, downloading and installing the drivers.
If none of the above methods worked PLEASE go to near computer shop.
Hope that helps,
Regards,
Pankaj
Dec 22, 2010 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
Upgrade my system then audio drivers is not instal showing error
Try updating the drivers instructions here:-
http://www.howtofixanything.co.uk/howto-266.html
If no luck then turn power off and take out the sound card if it's sound straight from the motherboard then post make and model of the PC here and I will locate the drivers for you, thanks.
Jan 14, 2009 | Intel DG31PR Motherboard
Driver intel 82801GB/GR
Intel(R) 82801GB/GR (ICH7 Family) LPC Interface Controller - 27B8 error in windows 7 ultimate 32 bit can i now howto solve the problem of this type
Oct 06, 2008 | Computers & Internet
Scanner
scanner umax astra 4100 driver downloding in free
Aug 29, 2008 | Office Equipment & Supplies
Vista software download
http://www.p4c.philips.com/files/s/spc700nc_37/spc700nc_37_dwv_eng.exe
Sergio
Todo: Check USB port
Howto:
061027085005_16154.png Refit the USB cable into the port.
061027085005_16154.png Plug the webcam into another USB port.
061027085005_16154.png Use an external powered USB-Hub. Some USB ports on computers do not have enough power to feed USB devices (this mostly occurs with laptops).
061027085005_16154.png Try to install the webcam on another computer.
Todo: Update your computer
HowTo: Update the USB driver in Windows
USB driver update in
WindowsXP
061027085005_16154.png Click Start -> Control Panel -> System
061027085005_16154.png Click the tab Hardware and then click on Device manager
061027085005_16154.png Click at the bottom of the tree on the + sign before Universal Serial Bus controllers
061027085005_16154.png Select the first entry, right mouse click and click on Update driver...
061027085005_16154.png Follow the steps to update the USB driver
Windows2000
061027085005_16154.png Click Start -> Settings -> Control Panel -> System
061027085005_16154.png At the bottom of the tree click on the + sign before Universal Serial Bus controllers
061027085005_16154.png Click on General USB Hub, right mouse click and click on Properties
061027085005_16154.png Click on the tab Driver and click on the button Update Driver.
Todo: (re)install the latest driver
HowTo:
061027085005_16154.png Deinstall any webcam driver (Philips drivers or webcam drivers from other brands you might have installed in the past)
061027085005_16154.png Cleanup the computer with for instance CCleaner (select Issues (1) and click Scan for Issues(2). Fix issues if necessary)
061027085005_16154.png Download and install the latest driver.
Apr 12, 2008 | Philips SPC700NC Webcam
How to download its sound driver from internet free of cost?
how to download sound driver of Intel D845 GVSR Motherboard free from internet? I got its CD misplaced.
Mar 29, 2008 | Intel D845GVSR Motherboard
Intel Motherboard Logo
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
