Question about Texas Instruments TI-83 Plus Calculator
The spring has broken off one of the battery connections
    President:
  • 1,124 Answers
Try folding tin foil into a small small square that will fit between the battery and the end where the spring was.. Make the little square thinck enough to put a little tention on the battery - to hold in in there..
Posted on Jul 27, 2009
After the steering knuckle was fixed in my 2007 HHR, they broke the clock spring and almost right away the door locks began to lock and unlock on their own, even while driving.
what else did you have done that would have required the steering wheel removal
there is no connection between a steering knuckle ( ball joint ) and the steering wheel problems you describe
Jun 03, 2016 | 2007 Chevrolet Chevrolet HHR LT
Sonic the Hedgehog no longer talks
Find an old broken device with the same carriage and use the spring connectors from it but be sure to solder them into the exact place they should be or it will not work.
Jan 12, 2013 | Video Game Consoles & Games
Changing battery, went to hook up neg. terminal after positive terminal and sparks flew from battery and starter engaged with key off and bike grounded. What to do?
i'd say make sure you have it connected to the right terminals, and if it is check and change the relay it might be stuck, or the spring is broken inside
Mar 06, 2011 | 1993 BMW K 1100 LT
Door spring broken
You should have one at the bottom corners of the door. Pull the dishwasher out about a foot and you should be able to see the broken spring and the hooks it connects to. Screws under the counter top hold the dishwasher in.
Apr 22, 2010 | KitchenAid 24 in. KUDI01FLSS Stainless...
Garage door take about 20 button pushes to open all the way, what is the spring supposed to look like? Is there one on each side or just one piece that should be connected? I just don't know if my spring...
to find out if your spring is broken wthout knowing you can spray a paint line all across the spring and then when you open the door the paint should go into a swirl if the spring is good if not the spring is broken.
Feb 02, 2010 | liftmaster Chamberlain Garage Door Opener...
My rear end has dropped and looks crazy and will not lift
Do you have:
1. Shocks and Leaf Springs?
If so: the Shocks could be "shot" and/or broken or completely discharged. OR the Leaf Springs Retainers or the Leaf Springs have broken. The Retainers should have two (2) bolts holding braces which hold the multiple leafs of the Leaf Springs together. Check these. Also you have bushings bolted then welded to the frame that will need to be checked.
2. Struts with Coils (Springs)?
If so: the Struts could be "shot, and/or broken or completely discharged. The Coils (Springs) could be broken of dislocated.
3. Coils (Springs) without Struts?
If so: the Coils (Springs) could be broken or dislocated.
4. Independent Bar Suspension?
If so: the independent bars could be bent, broken or dislocated from their frame connections with the frame.
5. Solid Axle?
If so: the Axle could be bent, broken or dislocated from their frame connections with the frame.
Since you cannot lift the vehicle, I am assuming you are using the jack under the axle to lift? This would point to the Axle/Bars being broken.
Was an excessive load (weight) put on the back of the SUV lately?
If you can't lift the rear of the vehicle, jack-up and properly support the front then jack-up and support the middle towars the rear of the vehicle to gain access to the rear of the vehicle for a better look.
However while doing this if the rear starts rising: keep a careful eye on the rear tires to see if they are going lower than what they would normally go when you are jacking-up the rear, especially with a broken Axle or Bars. THIS COULD CAUSE THE BROKEN OR DISLOCATED PARTS TO FURTHER BREAK OR CAUSE OTHER CONNECTING PARTS TO FAIL AND BREAK OR COULD CAUSE DAMAGE TO THE REST OF THE SURROUNDING AREAS OF THE CAR. I have seen an Axle and Bars that were broken "pierce" into the body of the vehicle because they were not carefully watching.
Let me know if this helped, or if you have any additional information, problems, or questions. Feel free to contact me at FixYa.com!
ps...when describing your problem feel free to fully explain in as much detail as you can, including in this case what type of rear suspension system you have, 2WD, 4WD, AWD, your engine size etc. There is no limit to describing your problem. It enables us to get a very precise answer to your very precise problem quicker.
Jan 29, 2010 | 2000 Ford Expedition
I cannot get the tv to come on without the remote control and the spring for the battery is broken and the remote is not working anymore
Try wedging some tinfoil between the broken part of the spring and the battery making sure the battery is secure. This should do the same job as the spring. The spring does two jobs. One is to secure the battery and the other is to complete the battery circuit.
Hope this helps.
Aug 13, 2009 | iLO LCT32HA36 Television
Replacing a broken spring on Roper washing machine
The other end connects to the rear wall.
Mar 22, 2009 | Roper RAS8244LQ Washer
WILL NOT TURN ON
There are generally 2 causes for this symptom.
1. The input connector is usually a 3 terminal device. When the plug is inserted into the device, a spring loaded contact is pushed away from another terminal which effectively disconnects the battery section from the device. This stops any electricity from the plug from being connected to your batteries and causing overload conditions. If this spring loaded terminal has been damaged, when the plug is removed from the device it will not "spring" itself back to its terminal and the battery power will not reach the PC board.
2. The battery case (compartment) has 2 wires going from it (internal to the device) one black and one red. If either of these wires has broken off the battery holder or broken off the PC board within the device, it will not power up.
You can also make sure that all the batteries are inserted in the correct direction. Since the unit works when plugged in, you can cross out anything else having to do with the unit.
Mar 06, 2008 | Radio Shack Pro-97 Handheld Scanner
Batteries contacts
I have damaged battery contacts and ITT no longer handles repairs.
They told me to contact
AE Optics
817-546-0993
Dana Prather
Jan 16, 2008 | ITT Night Mariner 160 Monocular
Texas Instruments TI-83 Plus Calculator Logo
61 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
