Question about Refrigerators
Frosting up of freezer fan/fan runs continuously
Fan in freezer of 2 yr old GE frig (no icemaker), keeps frosting up & runs continuously with a very load 'roaring' noise. Frig temp is o.k - (around 40 degrees F) turning it to less cold helped only temporarily.
  • 76 Answers
Clean and check the seals around the doors, the unit is trying to compensate for temperature loss.
Posted on Jul 27, 2009
I have a Kenmore Elite model no is 59673502201 and it stop cooling in both the frig and freezer i replaced the condenser fan motor and it worked so i replaced the back and the unit will STILL NOT GET
Do you hear your evaporator fan running in the freezer drawer area?
If not, then that's the fan you should have replaced.
If your compressor is running and both the compressor fan and the evaporator fan are running, check the back wall of your freezer compartment. If it is frosted up, then you have a defrost problem.
If it's not frosting up, disassemble your freezer drawer section and remove the back panel in the freezer to look at your evaporator coil.
If it's partially frosted at the top, or bottom, but the rest of it is dry looking, then you've got a leaking sealed system.
If it's lightly frosted all over, then you have good coolant flow and you need to start looking at your thermostat and damper up in the fresh foods section.
Nov 10, 2014 | Kenmore Refrigerators
Ice cream melted in freezer
Hello, There should be a temp adjustment for fridge & freezer adjust for colder setting. Check door sealant/gasket for cracks & seating. Next is bad news-call a BBB repair service. Good Luck.
May 12, 2010 | GE 18.2 Cu. Ft. Frost-Free Top-Mount...
Fridge side not cooling. freezer works. 6 yr old side by side
There is a little fan that blows air from the freezer side to cool the fridge side. Pull the plug on the refridgerator for over night, long enough to give it time to defrost if there is any, then plug it back in and see ifthe fan is running. If not then it probably needs to be replaced. If it keeps frosting up and stopping the fan then the defrost timer is probably bad and will need to be replaced.
Nov 14, 2009 | Frigidaire FRS26R4A Side by Side...
Evap fan stops running/low cooling, Unplug Frig Evap fan runs
Is there anything obstructing the fan area, ice build up ? It is normal for your freezer to get warm if evap fan is not working, it is essential for it to work :) A defrost cycle should kick on a timer or as needed (adaptive) and there should not be excessive frost buildup that it blocks your evap fan. I would have suggested you unplug your refrigerator for about 10 minutes and see if that resets your control board - if not, then you will need service - either replacing motor assembly or a faulty control board.
Aug 22, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE GSS25KGSA.... the freezer is no longer freezing regardless of temperature setting. It gets cold but no freezing. There used to be more noise during cycles, but that has stopped also.
The fan that circulates air in the freezer compartment is frozen & not circulating air - resulting in a freezer compartment that is cool but not cold. The reason is that the “heater & bracket” that warms & defrosts the evaporator coil & the fan above it has died & w/no defrosting, the coil & the fan load up with frost & ice & stop working.
Temporary Solution:
1) Unplug the frig.
2) Take all the food & shelves out of the freezer. Put it ALL in one cardboard box; this will keep it from defrosting while you get the freezer working.
3) Take out the ice maker storage bin (the thing that's full of ice cubes) & dump the ice cubes. (if you leave them in the freezer, they will melt & refreeze & make a disaster).
4) There is a metal panel below the lights & it should have frost & ice built on it.
5) Get two (not one) hair driers, set them on high heat & melt all the frost & ice & keep on melting & defrosting for about 10 minutes.
4) Plug the frig back in.
5) The freezer fan should be turning.
6) Put the shelf & food back in & close the door.
7) Expect this problem to reoccur in one to four months...
Solution:
1) Get a “heater & bracket” GE part number WR51X10055, about $30 w/shipping on eBay. This is for a GSS25KGSA GE side by side (the last two letters WW, BB, & CC are colors). If you have a different GE side by side, the correct part number can easily be found at www.searspartsdirect.com. Nice drawings.
2) Unplug the frig.
3) Take all the food & shelves out of the freezer. Put it ALL in one cardboard box; this will keep it from defrosting while you get the freezer working.
4) Take out the ice maker storage bin (the thing that's full of ice cubes) & dump the ice cubes.
5) Take out the light cover. One Philips screw on top & two press-to-release plastic things on the bottom.
6) Unscrew the light bulbs.
7) Take out the metal panel below the lights. Four ¼” screws. It is held in by two tabs at the top, so swing the bottom out & pull it down. Be careful not to bend it.
8) Get two (not one) hair driers, set them on high hot & melt all the frost & ice on the evaporator coil. Do NOT touch it.
9) Remove the “Heater & Bracket” by unscrewing the two Phillips screws and then unplugging the red & blue wires.
10) Install the new “Heater & Bracket” by plugging in the red & blue wires & replacing the two screws. Be careful not to get it backwards when plugging the wires; only goes one way.
11) Put the back panel back in & secure it with the 4 ¼” screws.
12) Reinstall the lights & cover.
13) Plug the frig back in.
14) Put the shelves & food back in & close the door.
15) Expect this problem to reoccur every 3-4 years; great designs fail after the warranty is up, and keep the repairmen & parts people employed …
p.s. about once a year, you should vacuum all the accumulated dust off the condenser coils. They are hidden behind a metal cover at the bottom back of the refrig. If you don't, expect the dust eventually block all airflow & the compressor will burn up & you will be buying a new frig.
Generic GE Side by Side Refrigerators GSS25KGSA, GSS25KGSAWW, GSS25KGSABB, GSS25KGSACC.
Jul 08, 2009 | GE Refrigerators
GE TFX22CR Ice Piling up in Back of Freezer
You either have icing that you didn't clear or the unit is low on gas.  You might also try cleaning the condenser coils.  This is a big problem in cooling.
To check low gas:  After cleaning the condenser (!), clean around the piping to the compressor in the back of the unit.  Wait at least an hour with the unit shut off.  Restart.  The larger pipe should begin to frost up.  If after about 15 minutes the frosting gives way to: ice, wetness or drying out...the gas level is likely okay.  If it stays frosted, you'll need a gas recharge.
Nov 04, 2008 | GE GSS20IEP Side by Side Refrigerator
8 yr. old GE Refrigerator/Freezer has started becoming too warm -milk spoiling
hi. thanks for the question. look at the freezer, is there frost build up on the freezer wall . is the fan running in the freezer. also pull fridge away from the wall ,clean all coils thanks the appliance doc
Oct 05, 2008 | GE Refrigerators
Multiple Ongoing Problems w/ Samsung RS2630SH
noise from the back .. outside ? would be the fan motor DC ver-speed motors.. frosting over is likely a drain problem
Aug 31, 2008 | Samsung RS2630SH Side by Side Refrigerator
HSS25IFMDWW- freezer frosting up but working
sounds like the defrost thermostat or you may have a crack in the water line causing the freezing.
Jun 10, 2008 | Hotpoint HSS25IFMCC / HSS25IFMWW Side by...
Refrigerators Logo
139 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
