My 2001 VW jetta VR6 heating and cooling are not working. Sometimes if I turn the AC on I will get a little bit of cool air but it wont blow hard, but most of the time it doesnt work the heating is the same way.
  • 49 Answers
SOURCE: goodman ac / heat pump
Goodman energizes it reversing valve in the cooling mode. Usually in the "o" circuit of the thermostat wiring.You may have that wired hot somehow.
Posted on Nov 28, 2007
  • 86 Answers
SOURCE: Stand alone AC blows cool air but does not cool the room
send tank capacity.model mail me mintex007@yahoo.com
Posted on Mar 17, 2008
  • 77 Answers
SOURCE: ac BLOWING HOT AIR INSTEAD OF COLD
Check to see if your outside unit is running. If not, check the breaker. If it is running you may have an issue with the reversing valve. It looks like three lines coming out of the top and one on the bottom. Trace the wires back to see that they are tight and secure. Of course, TURN OFF THE POWER first. good luck.
Posted on Apr 18, 2009
  • 2976 Answers
SOURCE: my frigidaire window AC is not cooling anymore
Does it get cold? You can try cleaning the fins-both inside and outside, with windex. Smoling & cooking will create a sticky deposit that will make dist that gets through the filter stick and it won't cool properly.
If it doesn.t get cold any more, try replacing the starting capacitor. About $5. If that doesn't take care of it, just replace the unit. They are cheap enough these days, that you can replace a unit with a more energy efficient unit for the same cost or less as a repair would cost.
Posted on May 25, 2009
  • 16 Answers
SOURCE: window ac unit is not blowing cold air
When the unit is running, go outside and put your hand near the condenser fins, this air that comes out should be slightly warmer than the ambient temp. If it is not you will need to take the unit out of the window and out of its outer case and clean the condenser fins from the inside, this is no easy task as it is very hard to reach. You will want to get a small (toothbrushed sized) brass bristled brush with a long handle. Make sure the evaporator coil (in the front) recieves the same attention and wash the mesh filter that goes in front of the evaporator. Re- assemble and enjoy the cold air.
Posted on Jun 07, 2009
Unit not working correctly. The unit worked for the winter, few days ago I turn on the AC and noticed that it wasn't cooling like it should.
It's could be the board or a heat relay. See if you have 24 volts on "x2" im assuming, emergency heat when in cool mode if so it's the board. Or unhook black or x2 or your emergency heat from board and run unit in cool. If heat stays on its a relay
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Jun 02, 2016 | Heating & Cooling
My AC some times blows cool air with good pressure but most of the time blows air with low pressure. I have checked the AC pipe also. Its cool.
I'm wondering if it's NOT the AC but the blower fan, how does the heat side blow? if it's good on all blower settings then, it's more than likely your blender door is not opening and closing all the way. When the blender door stays open a little bit it'll let warmer outside air mix with the cold AC air causing it not to be as cold as it should.
Sep 19, 2015 | 2005 Toyota Corolla LE
2000 vw Jetta ac not cooling, ac compressor is on, freon level good, with ac manifold gauges high and low side fluctuates from 50-60 psi on low side.
try to throw cool water on the condencer front of the engine radiator and see whether any cool air comes in the car. If so see whether the pressure valve is working okey or not because might the pressure is not sufficient.
Sep 05, 2012 | 2000 Volkswagen Jetta TDI
A/c doesnt work.it hardly blows any air at all.sometimes for a little while,it'll blow cool air.but most of the time it doesnt work.
If it works a little a bit sometimes then not much at others the 134A freon probably needs a recharge.
Jun 09, 2010 | 2000 Pontiac Sunfire
Heater smell when AC comes on...
The fan that blows the air blows through the heater coils before it blows through the A/C.As long as the heater doesn't come on, there is not much that can be done. ZCooking the attic room will be a problem because it is the heat rises thing, and on top(literally) of it all, the roof is radiating heat.
Sep 21, 2009 | LG Heat cool Window Air Conditioner
I live in a very hot climate, Yuma AZ. In the
It may be getting low on freon sometimes they leak out
Sep 10, 2009 | 2005 Dodge Durango
2002 New VW Beetle is only blowing hot air out of vents even when set on cool. I was driving and I made a turn at an intersection and all of a sudden the cool vent air turned to hot air like I had the heat...
On the bottom of the air unit is the lever that changes temps. It likes to fall out of place.I propped mine back with a piece of half-inch copper pipe a couple of years ago.Remove glove box then panel on front side of console to access.
Apr 09, 2009 | 2003 Nissan Altima
2001 jetta ac blowing hot air
Nothing is hard if you have patience and some tools or maybe even a friend to help.
Does the air go cool when moving down the road?
Does the vent air blow?
The fans for these are the same.
It is located under the hood, passenger side, right up against the firewall. They usually come out from the front.
Locate the fan motor - disconnect the wires - jumper to the battery with some clip leads, see if the fan runs. If it does, then not the fan and probably a fuse which is on the drivers side underneath the hood. It could also be the switching mechanism at that point, that's why try the heat and vent to see if anything changes.
If not replace the motor.
Let me know if there are any more fact to relay.
Aug 01, 2008 | 2001 Volkswagen Jetta TDI
Heating & Cooling Logo
164 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
