Question about Panasonic TX-26LXD1 26 in. LCD Television
Will not store bbc1 dvb channel
Since i re-tuned the dvb channels to add new channels i cannot get bbc1, the tv only seems to store a maximum of 95 channels. If I re-tune using an inferior aerial that will not pick up some other channels then bbc1 will tune in.
I have contacted Panasonic, they are aware of the problem and will post you an update card to correct the fault.
Posted on Oct 27, 2009
How can I get channels in sequence eg bbc1bbc2
Depending on your model, select channel 1 and tune for BBC1 and then 'store'. do the same for channel 2, tune for BBC2 and store again. Just repeat with each channel in turn
Jul 01, 2014 | Televison & Video
Hi, I live in a flat in London with a shared rooftop aerial (no idea of spec). I have a Sony KDL-46X2000. The built-in freeview tuner doesn't seem to recieve any HD channels. Is the built-in tuner the...
Make sure you have a good connection from antenna to TV. Check antenna and cable and cable connection to TV. Select DIGITAL button on TV remote when wanting HD channels. Remember HD channels are always digital. Also, any given TV station may not be broadcasting in HD at a given time. They can broadcast in digital but in standard definition sometimes. Your TV has a built-in DVB-T tuner. Try executing a channel scan to pick up all available channels. On-screen menus go to Digital Setup, then Digital Tuning, you can auto-tune or manual tune channels. The TV should take a few min. to scan thru available channels and store the channels its finds. Check with anyone in your area to see if they get HD channels (it is possible to be outside of the range of some TV stations) Your TV is a 2006 model and should still be compatible with local digital TV broadcasts but keep in mind digital signals could change in the near future (DVB-T2) and you may need a tuner/converter box to make the TV compatible.
May 01, 2011 | Sony Bravia KDL-46X2000 46 in. HD-Ready...
Does a samsung dv3 tv have freeview
Yes, it does.
DV3 is actually DVB meaning Digital Video Broadcasting. The stylised design of the DVB symbol makes it look more like DV3. If the TV has the DVB symbol, then it has a digital tuner and can receive digital channels, i.e. Freeview.
If you need assistance with tuning the Freeview channels or have further questions, please let me know the model number of the TV. This can be found on a label on the back of the TV.
Regards,
BElectric
Apr 24, 2011 | Televison & Video
Every time the machine is switshed on it indicates that a new DVB service has been found. This suggests it is not storing this info when it does receive it - any suggestions?
Unles you add the new channel(s) each time, it will flash the message. Go into the tuning menu and either add new channels or retune completly.
Mar 21, 2010 | Televison & Video
Samsung LE32R7 in DTV mode stays on BBC1
Updating the Channel List Automatically You can update the channel list when the broadcaster adds new Services or if you move the TV to a new location.
1. Press the MENU button to display the menu. Press the ▲ or ▼ button to select "Digital Menu", then press the ENTER button.
2. Press the ▲ or ▼ button to select "Channel", then press the ENTER button.
3. Press the ENTER button again, to select "Country".
4. Select the appropriate country by pressing the ▲ or ▼ button. Press the ENTER button to confirm your choice. Even though you have changed the country setting in this menu, the country setting for Analogue TV is not changed. (Refer to page 11 of the user guide)
5. Press the ▲ or ▼ button again, to select "Auto Store". Press the ENTER button. When it has finished, the number of scanned services will be displayed. The existing favourite channel list will not be deleted when the channel list is updated. To stop the scan before it has finished, press the ENTER button with "STOP" selected.
6. Press the EXIT button to exit. If the signal status is poor, the "No Service found! Check the aerial connection" message is displayed. Check the aerial connection and the try the procedure again.
If the channel icon is greyed out and you cannot tune the channels press the TV/DTV button on the remote control unit so that the icon is visible again and not greyed out. This will allow you to tune the TV.
Sep 30, 2009 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
Ferguson DV3 set-top box not finding BBC channels
I have solved the problem by selecting Manual Tune in the Menu. This means selecting each channel one at a time beginning at 21. The indicator shows the Signal Strength and Quality for each channel. If both show a green bar (strong on both counts) give it time to identify the new programs on each channel and add them. It will show how many found and added if you wait a few minutes. When each channel is done, move on to the next one. The last channel is 65 I believe but there is not much up the top end.
When I had finished going through this routine I found it had indeed added all channels I needed including BBC1 and BBC2
Aug 21, 2009 | Televison & Video
Maxim 11-54 26 inch lcd tv switch mode power supply blown up need new one
I have a Maxim 15" Portable LCD TV with built in DVB-T Tuner.
It has worked well for 2 years.
Now when you switch it on set to DTV
Starts to reload the channels
Once it has found 90 channels it moves to Add and will not add any.
There are no stored channels from the built in freeview.
However we still have the normal 4 on ATV.
Any advice.
Aug 10, 2009 | Televison & Video
UNABLE TO VIEW ITV CHANNEL 4 OR SKY SPORTS NEWS ON MATSUI TV
try tuning tv in another room, if it works it is then your cable or socket, try the cable next. If it wont tune its a faulty set.
May 26, 2009 | One For All URC-3445 Remote Control
Panasonic TX-26LXD1 26 in. LCD Television Logo
513 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
