Question about GE Spacemaker JVM1640SJ Microwave Oven
Ge spacemaker microwave when i plug it in comes up with PF on the screen and does not work at all,it has power and the light inside is on,i can press the 3 minute button and the microwave will wor but that is the only button you can make work
  • 67 Answers
Ther should be instrustions manual sound like mocro is working suspect control panel it needs 2 be reset how read manul panosonic push stop 1 at same time menu comes up push reset this is a minor problem hopes this help u
Posted on Jul 27, 2009
GE Spacemaker XL 1800 turns on for 1 second and then resets. The display shows PRESS CLOCK.
Sounds like your losing power, have you tried it on a completely Different circuit??? Either that or bad fuse or connections inside of microwave.
Sep 08, 2017 | GE Microwave Ovens
WHY MICROWAVE OVEN IS DEAD ,2000 MODEL bajaj
there could be many reasons for your microwave to be dead. First did you check if it has power coming to it? Is the plug out of the socket? Sometimes the power plug is behind the microwave and it is hard to see unless you slide it out and look. When you say dead, is the display light up? If so does it indicate PF (Power Failure)
Sometimes the internal fuse blows out because of a short, usually caused by the diodes being shorted or even the transformer or the magnatron tube itself. If you have any of these problems except for the fuse then I would recommend that you replace the microwave with a new one because yours probably wouldn't pay to fix.
Good luck,
Marty
Jun 04, 2014 | GE Spacemaker JVM1640SJ Microwave Oven
One day the microwave just showed PF on the screen, unplugged and plugged in tried to use it, worked for 30 seconds, stopped and showed PF again. Any ideas? It is only a few years old and used in our...
PF is Power Failure. Check and see if the Oven has a reset switch or power button. Try and hook up an extension cord, plug one end into a usable output (wall plate) and the other into the 110VA line plug attached to the Oven. Turn on....if it works then the problem is a circuit breaker or wall interface. If it fails with the extension, then it is an electrical problem with the microwave device itself. If there are no Reset features on the oven, an internal fuse may blow, or other shorts are occurring. The cost to fix is more than a new unit. Lowes has them as low as $150.00.
Dec 18, 2013 | GE Spacemaker JVM1640SJ Microwave Oven
Power failure on ge wes1130
Power being interuppted could be anything from a bad fuse , bad fuse holder, bad solder connections on the main board. Bad breaker in your panel. Start by plugging it into an outlet you know is on a different breaker than the on it is on now. See if it does the same thing. If it works ok, then problem with power to the other outlet. If it does the same thing problem inside of unit. PF is Power Failure, now we have to figure out why.
Oct 15, 2017 | GE Spacemaker JVM1640SJ Microwave Oven
My GE Spacemaker 2.0 over the counter microwave just died. No lights or anything.
Hi, It sounds like the internal fuse blew. To get to it, the case has to come off the unit and its located close to where the power cord ties in. With any and all microwaves, It is a good idea to put a surge protector on the plug to plug microwave into. Hope this helps.
Jan 18, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Got code PF and control keypads not working?
Hello :
PF indicates power failure . Displays this message after it has been unplugged or if there has in fact been a power failure .
good luck .
please rate !
Apr 02, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
221 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
