Question about Cell Phones
I can't get it to ''ring'', I went into the ''general'' section to check it and it is not checked, but the icon shows it as vibrate, how do I get this to ring?
Why does the screen show a bell icon with a backslash through it?
On my phone it means silent or vibrate. There will be a menu under settings, calls, general, or something very similar where you can change it to the normal ringing mode. If you have trouble finding the menu, access the manufacturer website.
Jun 05, 2015 | Bell Lands Phones
When somebody rings sometimes it only rings once then goes silent
Go to Settings > Sounds > Change the settings to Ring+Vibrate or Ring Only or Vibrate Only
I guess you have by mistake changed the settings right now to Ring Only Once and hence it rings just once and then vibrates. If there is not settings icon and no sounds option you can check if you have Profile as option as you can change it accordingly in the profile you are using. Hope this helps. Good Luck
Mar 08, 2013 | Motorola Mobility Defy Cell Phone
My nokia 5230 wont notify me whenever i get a message? it doesn't show the icon, and it doesn't ring or vibrate i checked the settings and it has vibrate and ring on
Check your phone for outside or meeting settings somtimes these override the main settings for your message indicator.
Apr 12, 2010 | Nokia 5230 Cell Phone
My iphone keeps buzzing and shows an icon of the ringer with a slash thru it it wont actually ring, just vibrates altho the ringer is on
"An icon of the ringer with a slash through it"?....Usually that means that the ringer is OFF.If you're sure that the ringer is in fact ON , then check your profile.If it's in the Silent or Meeting profile, the ringer is switched off by default and it goes to vibrate.
Jan 09, 2010 | Cell Phones
How to get my blackberry to ring and vibrate
  • You need to check the profile.
  • Go to main screen
  • you will find options
  • under options icon you find profiles. Here you can set vibrate and ring tone
Oct 24, 2009 | RIM BlackBerry Curve 8310 Smartphone
Can't find volume or ringtones
Ring tone volume is found in user profiles. When you customize the ring profile( general, outdoor, meeting) you have the option of setting the volume. you can also set it to vibrate in this section.
Jun 03, 2009 | Dual Cell Phones
My phone has no song at all
Hi Kathnicks2
Have you checked your profile if its in silent mode? Also check the settings and in that check if you have selected the incoming call alert as ringing or vibrate. You can also check if your mobile is ok by trying to listen to ring tones in general. So, if you are not able to just listen to ring tones, then you will have to meet a service person who can get it right for you.
Nov 19, 2008 | Nokia 1100
No ring on incoming call
i had the same problem and went searching on line till i found the answer, press the # button it takes the mute off or puts it on.
regards patty
Nov 08, 2008 | Samsung SGH-D900 Cellular Phone
Alltel pantech camera cell phone pn-218
Check user customizable profile. Whether it is set Vibrator mode in General mode. Even by key press mistake it might happens. Check profiles section. if you feel Risky Contact authorised mobile service stations. thank you !
Dec 23, 2007 | Nokia 1100
Cell Phones Logo
21 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
