Not sure if I need the power supply panel or the main panel. I have seen two different part numbers for the power supply panel 934C409003 or 934C409002 not sure which number is correct. Mitsubishi was no help. Thank You
SOURCE: 2wire HomePortal - green power light blinking
disconnect the power adapter. Reinsert the power adapter directly into the wall socket. Remove any power strips or surge protectors temporarily to ensure that these items are not preventing the 2wire's proper operation. make sure you are using the power adapter that came with the modem. Plug the power adapter into a different wall socket in another room.
SOURCE: Power light blinking red
The tv is NOT in standby mode... it does not have a standby mode !!! But what is happening is.. your tv is getting lamp errors. this can be caused by voltage drops and spikes while the tv is on... and a factory reset can correct this. OR it can be one of two problems.. Bad Power supply or defective lcd panel.
SOURCE: I have a crib model number 4920-1 manufactured
Due to the numerous recalls involving Delta cribs Products America is not able to supply any parts for their cribs. I suggest you first going to the CPSC's website at www.cpsc.gov and making sure that the crib you are using is not part of the recalled units. If it is, you should be able to find details on how to go about replacing the crib from the CPSC website as well.
SOURCE: TI89 Titanium--main board replaced,must get its serial number
I am not sure if the number on the case is the one required. The TI89 Titanium and other recent TI machines have a unique ID. To get it, turn the calculator ON, Press F1 select 3: About.
On the subsequent screen, one finds various bits of information among which is a product ID and a 14 digit hexadecimal number ID ( a number in base 16, with Arabic digits 0 to 9, plus and A, B,C,D,E, and F)
The same number can be revealed by TIConnect software:
After machine is recognized, click TI Device Info. The Device ID is returned under General Information Tab or ID list tab.
This device ID could be the one needed for the Calculus Made Esay. software
