Question about Garden
When I let up the clutch the engine sputers and dies
    Top Expert:
  • Garden Master
  • 76,691 Answers
The number one cause if this is fuel flow, the most common is dirt is plugging the carburetor main fuel jet, also make sure the tank is clean and the fuel line to carb has free flow of gas, if i does pull the carb off, very easy just remove the air cleaner and linkage and then a few retaining nuts or bolts and carb comes right off, remove the bowl of the carb and clean it, then blow the jets of the carb out with compressed air, this is the only way to clean it, so if you don't have access to compressed air try to find a source. If u are very carefuel u won't need a new carburetor bowl gasket.
Posted on Jul 27, 2009
Car ran fine shut it off came back it didn't want to start. started went about half a mile sputered an died wouldn't start back up 1991 subaru loyal wagon
Hi sounds like the typical fuel pump or filter problem with these cars, best way to tell is take top fuel hose off on fuel filter under hood, turn key on ignition (not start) and fuel should pump out, if not its your pump, just beware of doing when engine is hot
Apr 22, 2012 | 1991 Subaru Loyale
Engine dies when the clutch is let out on riding mower
check the safety switch on the clutch/brake pedal
Apr 10, 2012 | Garden
01 gsxr 1000 acting funny
This is an interesting problem, firstly did it start doing it after fill-up? if so you could have got a dose of bad fuel, simple drain and refill should have it going OK, don't forget to drain the whole fuel system. Secondly check to see if any vacuum lines have come off, if this is the case listen for any light hissing noises and chase it out. Thirdly Check you spark plugs for fouling and any cracks in the insulators, it could also be a coil breaking down.
Nov 24, 2009 | 2001 Suzuki GSX-R 1000
Starting problems
It will likely be the crank sensor, usually fitted next to or behind the bottom engine pulley. A common failure is for the sensor to stop sending a signal when hot, and the engine will stall immediately. After a time, it re-starts but will cut out again when the sensor gets hot again. These sensors are easy to find and replace, and not usually expensive.
Nov 05, 2009 | 1990 Nissan 300ZX
I have a 1997 Dodge Avenge and can drive it for about 2 miles and it starts sputering and dies
check the crank sensor next to or behind the main crank pulley, these are known to fail when hot and cut the engine out until it has cooled for a few minutes.
Oct 24, 2009 | 1997 Dodge Avenger
Engine dies when I engage the electric clutch for my mower
Possible short to ground in the clutch wiring
Oct 19, 2009 | Craftsman Garden
Car dies
your fuel pump could be clogged and/or going bad
Nov 30, 2008 | 1991 Chevrolet Lumina
Garden Logo
16 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
