Question about Kenmore 24902 Top Load Washer
Machine won't agitate or spin
My 24902 decided it doesn't want to agitate OR spin, it'll fill up, and if i hold down the lid switch during either agitate or spin modes, i can hear the motor, but no movement.It will drain during the spin cycle as well.
    Brigadier General:
  • 3,513 Answers
The reason for your Kenmore washer not to agitate or spin is due to a bad drive coupling.
Your machine has no belt. It has a direct drive coupling. The direct drive coupling between the motor and transmission must be replaced
Let me try to help you fix this on your own. First unplug the washer and turn off the water. If you have a shop vac take the drain hose out of the drain, and through the drain hose vacuum the water out of your washer. If you don't have a shop vac go to the auto parts store and buy a pair of radiator hose clamps. Then facing the washer locates the two screws. They will either be in the front or rear of the control panel or back them out far as you can. Once you have done that pull the control panel slightly forward, and tilt it back on the hinges. Now unplug the lid switch wire but don't forget to plug it back when you’re done. Next locate at the rear of the washer body the two gold clips then push forward, and take careful note of how they fit. Then pop them out with a screw driver tilt the washer body forward at 45 degree angle and walk forward with the body, and set it down. Now you will see the white pump and motor assembly. You should see two clips holding the pump to the motor pop them off, and pull the pump off the motor shaft. Now if you feel the need to remove the pump use the radiator hose clamp. Take them and clamp the hose coming from the tub but it’s not necessary for the repair. Next disconnect the wiring harness from the motor (note the position of the harness for reassembly). Remove the two 5/16 inch screws from the motor clamps and pop the clamps off. Once that is complete, remove the motor put the new coupling on the motor and transmission shaft. I use a socket and a hammer to tap it on the transmission shaft. (put the rubber piece on then the motor now you got to be patient here some are easy some you must play with). Once it slides in pop motor clamps back on replace motor clamp screws.
Thank You for using Fixya.com
Posted on Jul 27, 2009
My washer will agitate but won't spin nor drain.. what is wrong with it?
Check the lid switch. It is common for them to go bad. Check to see if it clicks when pushed down. the switch can cause the washer not to spin or drain.
Jun 23, 2014 | Kenmore 24902 Top Load Washer
Tip
How to fix a Washing Machine if it Doesn?t Agitate
If your washer fills with water but doesn’t agitate, the problem is likely to be a faulty lid switch, a broken belt, or a problem with the motor. (Note: Direct-drive washing machines do not have belts.)
1) Check the spin cycle. If this works, the motor is operating and the belt is not broken. If it doesn’t, the belt may be loose or broken. If you’re fairly handy, tighten or replace the belt; otherwise call an appliance repairperson.
2) Check the lid switch and the tab on the lid that strikes it. If the plastic tab is broken, the washer may halt during certain cycles. Press and release the switch. If it doesn’t click each time you do this, it’s probably broken. If you’re experienced at home repair, you can remove the switch, test it, and replace it if needed; otherwise, call an appliance repairperson.
3) There may be a problem with the controls, or the agitator solenoid may be broken. Call a repairperson.
on Sep 03, 2010 | Washing Machines
Whirlpool LSQ9544KQO won't spin
if it fills with water and then nothing check the lid switch,if it's bad it won't do anything but fill,some will agitate but then no drain or spin,the easiest way to check it is open the lid a few inches and close it,do this a few times,if you don't hear a clicking sound the switch is bad,or open the lid and stick a screw driver into the hole on the right side where the strike from the lid goes into,if it doesn't click when you push it down and let it up it's bad,part number 3949237 and it's around 50 dollars.watch this video,it's a different lid switch but changes out the same way.
http://www.youtube.com/watch?v=MFsvLiuTniU
you can also stick a jumper wire into the two outside wires to check it,flip up the top console,you'll see the lid switch connector on the right side plugging into the top of the frame,unplug it,stick the jumper into the connector that unplugged from the frame and it will have three holes in it,the middle is ground so stick the jumper into the two outside holes,set the timer to drain and pull out the timer,if it starts to drain and spin then you know the lid switch is bad.hope this helps.
Jun 04, 2012 | Whirlpool Ultimate Care II LSQ9549L Top...
Kenmore washer 80 series stopped draining
So it will agitate and fill but the motor won't run during drain and spin?
If so, the likely cause is a bad lid switch. The paddle that the probe hits when the lid is down moves a small switch. That switch can do two things
1. fail internally. It will look fine outside but it won't close the circuit
2. the screw holes snap and it hangs off the wires, the probe no longer hits the paddle and the switch stays open.
The lid switch is cheap and very easy to repair.
Nov 10, 2011 | Kenmore Washing Machines
HI I HAVE A KENMORE WASHER MODEL #82881100 SERIAL #C92167486 THE WASHER FILLS AND NOTHING ELSE.DOESN`T AGITATE,SPIN OR DRAIN. THANK YOU IF YOU CAN HELP. BOB
you forgot the first three 110.82881100 is the full model,you'll need that to order the right parts.it sounds like you have a broken lid switch,i looked up your machine and it takes the older cherry switch part number 279347 and it's around 35 dollars.close the lid down,then open it around an inch or two,do this a few times,you should hear a clicking sound,if it isn't clicking the lid switch is broke,i'll send you a video from utube but it's for a different lid switch but you take the machine apart the same way but it's for a 247 lid switch and you need a 279347.if you can hear the motor running and this is happening you could have broken the motor coupling and i'll send that along too.http://www.youtube.com/watch?v=MFsvLiuTniU this is for the lid switch copy and paste.this is for the motor coupling http://www.youtube.com/watch?v=9K1KHEogf3c hope this helps salde
Sep 04, 2011 | Kenmore Washing Machines
LSR6132E agitator doesn't work, won't spin?
open the lid,on the right side you'll see a hole in the top panel,stick a screw driver into the hole,you should hear a click or close the lid,lift it up an inch or two and close it down,if it doesn't make a clicking sound the lid switch is bad part number 3949247 and it's around 45 dollars.
Sep 03, 2011 | Whirlpool Washing Machines
WONT AGITATE OR SPIN
check the belt that spins the tub, you will find it at the bottom of the machine, check if its intact.
plz do not forget to vote if i solved your problem
Sep 05, 2009 | Kenmore 24902 Top Load Washer
I have a series 80 top loader. It filled and
Screws holding the lid switch was broken. Had to replace lid switch.
Jun 11, 2009 | Kenmore 24902 Top Load Washer
Agitator Not Working
check your motor coupler, lid switch
Nov 08, 2006 | Hotpoint VBXR1090D Top Load Washer
Kenmore 24902 Top Load Washer Logo
156 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
