Question about Blackburn Mountain Air Mountain Bike Pump 4 Bicycle
Not working I am following all instructions and the air is not staying in the tires. The tires are new and have no problems. The gage is not saying that the tires have no pressure. Please help!!
  • 484 Answers
When you remove the tires while changing inner tubes, do you run your fingers through the inside of the tires to check for thorns, wire, nails or other debris before replacing the tubes? Also, check to make sure your rim strips are adequately covering the spoke nipple holes in the rim. Sometimes just a little bit of a hole left unprotected can damage a tube. Lastly, sometimes you will just get bad tubes. It happens.
Posted on Jul 28, 2009
How do I reset my tire pressure light when tires are fine
My Lesabre has buttons on the left side of the dash. The one called Gage Info has a number of things like oil pressure check tire pressure heat Battery. Push this button till it says check tire pressure To reset your light push the reset button and hold for fifteen or twenty second and the light on the dash should go out and it will show tire pressure ok on the gage. Before you reset check all four tires for air as one tire could be down 8 or 10 lbs and the light will come back on. they all have to be the same pressure.
When you change your oil you should reset the oil section as well and hold reset the same as above. The oil section tells you how much oil you use over an amount of time.
Apr 01, 2016 | 2004 Buick LeSabre
1999 ,4x4,454,2500suburban.airbaglight stays on,when truck is turned off something is draining the battery ,the clock doesnot work fuel gage doesnot work.
Sorry to say, but none of these are related. Fuel gauge is probably the sending unit in the tank, could be wiring. The air bag could be the module,the bag unit, the sensors, or bad wiring. The radio is probably your most likely choice for battery drain. The three main things I have found to drain batteries are the radio, the starter, and the alternator. These three will kill a new battery in 1 to 2 days, An older battery over night. Shorts in the interior lighting is 4th..
Apr 05, 2014 | Chevrolet Suburban Cars & Trucks
Tire air pressure lighr come on 2005 exepedition
Have you tried refilling the tire to the proper inflation?
Mar 04, 2014 | Vehicle Parts & Accessories
I have a buick lesabre 2000 nd my tire went flat the check tire pressure light came out.. So i went to buy a new tire nd change it. But the light is still there.. I tried to reset it how it says on the...
SWITCH IGNITION ON, REPEATEDLY PRESS GAGE INFO BUTTON UNTIL THE MESSAGE TIRE PRESSURE IS DISPLAYED IN THE MULTIFUNCTION DISPLAY, PRESS AND HOLD RESET BUTTON UNTIL THE MESSAGE TIRE PRESSURE RESET IS IN THE DISPLAYED IN THE MULTIFUNCTION DISPLAY,RELEASE THE RESET BUTTON THE MESSAGE TIRE PRESSURE NORMAL WILL BE DISPLAYED IN THE MULTIFUNCTION DISPLAY, AFTER RESETTING TPMS THE VECHICLE REQUIRE UP TO 30 MINUTES OF STRAIGHT LINE SMOOTH ROAD DRIVING IN EACH OF THE 3 SPEED RANGES 15 - 40 MPH - 40 - 70 MPH - 70 - 90 MPH. MAKE SURE ALL 4 TIRES HAS THE RIGHT AIR PRESSURE BEFORE RESETTING TIRE PRESSURE LIGHT.OR LIGHT WILL NOT TURN OFF IF ONE TIRE IS LOW.
Jul 16, 2011 | 2000 Buick LeSabre
The compressor keeps runing and will not cut out on the pressor it is set on the new switch it is electric compressor
If the pressure relief valve ( or "pop off" valve as we call it ) doesn't relieve the pressure by letting out air then your gage that you are using to determine the pressure may be faulty. Use a tire gage to double check yor pressure gage or just put another gage on.
If this is a "oilless" compressor then the rings may be bad.
Jun 06, 2011 | LG LS-L1210CL Mini Split Air Conditioner
2007 rav 4 v8 4wd light stays on and seems that 4 wheel drive is staying engaged
Make sure that all four tires are exactly the same height, (not necessarily the same name brand) using a yard stick or what ever means possible, to measure the height and make sure all four tires have the same air pressure. ( using the same tire gage on all four tires). And then go from there.
Mar 09, 2011 | Toyota RAV4 Cars & Trucks
MY COMPESSOR GAGE SHOWS 135 PSI AND 135 ON THE OUT PUT GAGE BUT I CAN,T INFLATE MY MOTORHOME TIRES TO THE REQUIRED 110#.DO I NEED A LARGER COMPRESSOR?I CAN,T FIND ANY LEAKS.
It is possible that the compressor psi as it is running drops below the tire psi creating a standoff. You must maintain air compressor psi over 110 to fill a tire to 110psi. Add air to your tire but stop when the compressor motor starts to run. When the motor stops then continue to add air until the compressor motor starts and again stop airing up the tire. Repeat as needed.
Dec 25, 2010 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
How do you reset the tire pressure light on a 2007 Rav4?
Check the pressure in all five tires-spare included. You will have to remove the spare cover, which takes some time if you have a soft cover. Once all the tires are at the same pressure, the light should go out. I did it with the car parked, so it seems driving it for reset is not required. If the pressure is off between the tires after adding air, the light may stay on. They must all be close or the same for the light to go out. Use a real tire gage rather than the one at the gas station air nozzle.
Good luck.
Nov 01, 2010 | 2007 Toyota RAV4
My check gages light come on as well. When it happens, my oil gage drops as well. When check gage light goes off, the oil gage returns to normal. Lately, the problem is getting worse. Then check light is...
I don't see the problem
You have a check light on, most of the time.
Check lights have been on vehicles for 31 model years now. Surely you know why! You have a system malfunction, get the code read, as soon as the light comes on,and have the vehicle repaired.
What has, getting tired off a vehicle and a newer one, that will develop similar issues, have to do with this. Educate yourself.
Oct 01, 2010 | 2001 Dodge Durango
My accu-gage tire gage does not hold tire pressure reading. the dial drops slowly down to zero.
If there is a button you push to release the pressure (resetting the gage to zero), this is a valve which probably has a little piece of dirt impeding the seal of that valve. The dirt would have been carried there by the air and condensation. But don't take it apart to clean it. This is a typical problem with these kinds of gages. When you have plenty of air available (a compressor nearby) hold the gage on the valve stem, while you repeatedly push the release button. That should clear the dirt, but you may need to add more air to the tire.
Jan 17, 2010 | Accu Gage Tire Pressure Guage 60 Psi Range...
Blackburn Mountain Air Mountain Bike Pump 4 Bicycle Logo
184 people viewed this question
Top Blackburn Cycling Experts
John Egan
John Egan
Donald Ayers-Marsh
Are you a Blackburn Cycling Expert? Answer questions, earn points and help others
