Dishwashers
Problem for Dishwashers
Generic problem for all Dishwashers
Maytag Quietseries 200 not draining and shu...
By valeriea333 on Jul 27, 2009
My Maytag will sometimes work and sometimes not. If it does turn on it wont drain the water and shuts off (lights all off) before the cycle finishes. Lately it might turn on for a few minutes and then shuts off (lights all off) and no matter what I try I cant get it going again. Any advice???
Solution #1
posted on Jul 27, 2009
Not Rated)
localwonder
Rank: Guru
Rating: 92%, 3129 votes
HI. check the following areas for faults..
1. Air gap / Drain hoses
If there is an air gap (located in the sink, near the faucet), check to see if it is clogged. Unscrew the top cap and see if there is anything blocking inside. Note: If there is no air gap installed, the dishwasher might not drain properly.
If the drain hose is clogged, the dishwasher would not drain. If there is an air gap installed, it is very common that a hose going from the air gap into the garbage disposer is clogged. Remove and clean the hose. Make sure to reattach the hose before starting the dishwasher.
Note: If you recently had a garbage disposer installed, it is common to overlook removing the drain plug.
2. Broken belt
Some dishwasher models use a belt to drive the pump. Replace the belt if found broken.
Note: Sometimes the belt would just come off the pump. Even though it might not be broken, it is recommended that you replace the belt, because it is probably too stretched out.
3. Pump
Some models have two impellers inside the pump - one, wash impeller, takes care of the wash cycles, the other, drain impeller, drains the water out. If the drain impeller is broken (broken blades, shaft), the dishwasher would not drain. Replace any broken pump components.
4. Drain solenoid
Some models (for example most GE dishwashers) use a drain solenoid to drain water out. Sometimes the solenoid gets stuck, preventing the water from draining out. Try to free up the solenoid. If unsuccessful, you might have to replace the pump assembly.
5. Motor
If the motor is stuck, it is sometimes possible to free it up by manually spinning the motor.
Replace the motor if defective.
6. Timer
Replace if defective (note: uncommon problem).
Was this helpful?
Yes
No
Popular Solutions for Dishwashers
Questions and Unsolved Problems for Dishwashers
Answer
kitchen aid model number kudco31vbs is it good
Answer
we are about to buy new dishdrawer lookin fisher and paykel
Answer
During the last few washes whether on Regular or power wash or quick wash, the detergent cakes in... (More)
Answer
hey I got a DD603 F&P, the upper drawer locks are stuck on and there is no power to the top... (More)
Answer
I have a kleenmaid Dw29x got it as a gift from my brother in law, its all hooked up ready to go but... (More)
Describe your Dishwashers problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Dishwasher Experts
Top Dishwasher Repairmen
in Windham, ME
(423) 303-3783
Dishwasher parts delivered overnight nationwide....
 Appliance Parts Pros.com
(800) 803-6775
Manage my home, all the technicians you need at...
Manage my Home
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
