Question about Microsoft Xbox 360 Console
Xbo 360, after 5 minutes, 2 rrod
It isn't overheating, it's cold when you touch it and I've had a fan infront of it and cool air coming into the back by having the door open abit (afterward the problem occured)
I've tried diffrent power sources, diffrent output cables (had HDMI, but tried the HD AV cable too, nothing different)
I've tried running games from the harddrive (demos) and tried 3 diffrent games with the same result, almost like clockwork after 5 minutes playing or just doing nothing ingame.
It's not dusty and it's not warm when I play for five minutes. The fans start spinning and the 2 RROD start flashing.
The error code is 4, 4, 1, 3
0013 = Memory overheating, which probably means the Graphich card.
Anyone with a solution? I've read somewhere here that it's a false overheating, then why should I remove the X-Clamps to fix it? Cause if it's a false overheating (which it probably is) then why go through all that trouble?
  • 149 Answers
Hi, the x-box may not be overheating, but the GPU thinks it is. This is caused from the x-clamps becoming warped and letting the heatsink lift off of the GPU. If you do and X-clamp replacement on it it will solve your RR problem. Ive done quite a few of these so I'm quite confident that is your problem.
Posted on Aug 11, 2009
Which way do place your Xbox 360? Vertically or horizontally? If you'e had it vertical the whole time, try placing it horizontally. Also, when you have a disk in your Xbox 360, do change the way it stands up. That's what caused your problems in the first place.
Hope it helps,
Godfatherx77
  • 51 Answers
I think it might be false orverheating too, or a dead GPU atleast. I can suggest replacing the graphics card since it sounds like you repaired the system yourself anyway. There could also be a problem with the motherboard causing the GPU error.
Posted on Jul 28, 2009
U all dont kno anything maybe just maybe its bc its a xbox hahahah
Posted on Aug 24, 2009
Xbox console three-quater red powerbutton,what can i do plse
This is called Red Ring of Death or RROD by the community, it means that the CPU or GPU or both have a bad solder joint, that is caused from rapid heating and cooling from poor cooling design of the xbox 360. To fix it is pretty simple. Follow these instructions to take apart your 360: http://www.rrodfix.com/how-to-take-apart-the-microsoft-xbox-360-game-console.html Stop once you've removed the dvd drive. Now Remove the fans from the back, and set them on the heatsink on the right the flat one, and make sure they are pointing where the air is going up. Put a peice of of carboard or plastic something non conductive in between the heatsinks to prevent airflow from the fans. Turn on the 360, and leave it til it goes from 3 rings to 2 rings, wait 3 minutes, then switch the fan over to the other side. Wait about as long as you did for the other one then turn off the 360. Wait 1 hour for the 360 to cool off. DO NOT move the 360 while it is cooling down durning this period or you will permantly ruin it, the solder is being reflowed. After an hour, put the fans back, and turn the 360 on, it should work. Once its working, I recommend doing a 12 volt mod on the fans to prevent RROD from happening again, and changing out the thermal paste with artic silver 5.
Oct 24, 2011 | Microsoft Xbox 360 Console
Three-quater red power button
My xbox always suddenlly shut down while im playing it will not reach 20 minutes its shuts down again.
If before it shutdowns it has 2 red light its a Overheating issue, if still under warrenty send it back to microsoft or... you can, open it up by following this guide: . http://www.rrodfix.com/how-to-take-apart-the-microsoft-xbox-360-game-console.html Stop once you've removed the dvd drive. Get a can of air, make sure its all aired out, and you hold the can horizontal don't tilt it, and short bursts. Once thats done. If you want to make sure it never overheats you can do whats called a 12v mod on the 360 it forces the fans to run at full speed. Now if you have a slim you just snip the grey wire. If its a older model you get the fans, and wire it up to a external 12v 1amp ac to dc adapter or solder it to this point :http://www.llamma.com/xbox360/mods/360-12V-fan-Mod.htm this link also shows what wires are postive and negative. And I would also suggest changing the thermal paste out for some better stuff like artic silver five. Now if you're getting Red Ring of Death which is 3 red lights you need to follow this guide :This is called Red Ring of Death or RROD by the community, it means that the CPU or GPU or both have a bad solder joint, that is caused from rapid heating and cooling from poor cooling design of the xbox 360. To fix it is pretty simple. Follow these instructions to take apart your 360: http://www.rrodfix.com/how-to-take-apart-the-microsoft-xbox-360-game-console.html Stop once you've removed the dvd drive. Now Remove the fans from the back, and set them on the heatsink on the right the flat one, and make sure they are pointing where the air is going up. Put a peice of of carboard or plastic something non conductive in between the heatsinks to prevent airflow from the fans. Turn on the 360, and leave it til it goes from 3 rings to 2 rings, wait 3 minutes, then switch the fan over to the other side. Wait about as long as you did for the other one then turn off the 360. Wait 1 hour for the 360 to cool off. DO NOT move the 360 while it is cooling down durning this period or you will permantly ruin it, the solder is being reflowed. After an hour, put the fans back, and turn the 360 on, it should work. Once its working, I recommend doing a 12 volt mod on the fans to prevent RROD from happening again, and changing out the thermal paste with artic silver 5.
Oct 23, 2011 | Microsoft Xbox 360 Console
Sometimes it opens and sometimes it dont , sometimes it plays discs and sometimes it dont turned it on and had the red rings of death turned it off then on and they were gone some times the fan dont start...
This is called Red Ring of Death or RROD by the community, it means that the CPU or GPU or both have a bad solder joint, that is caused from rapid heating and cooling from poor cooling design of the xbox 360. To fix it is pretty simple. Follow these instructions to take apart your 360: http://www.rrodfix.com/how-to-take-apart-the-microsoft-xbox-360-game-console.html Stop once you've removed the dvd drive. Now Remove the fans from the back, and set them on the heatsink on the right the flat one, and make sure they are pointing where the air is going up. Put a peice of of carboard or plastic something non conductive in between the heatsinks to prevent airflow from the fans. Turn on the 360, and leave it til it goes from 3 rings to 2 rings, wait 3 minutes, then switch the fan over to the other side. Wait about as long as you did for the other one then turn off the 360. Wait 1 hour for the 360 to cool off. DO NOT move the 360 while it is cooling down durning this period or you will permantly ruin it, the solder is being reflowed. After an hour, put the fans back, and turn the 360 on, it should work. Once its working, I recommend doing a 12 volt mod on the fans to prevent RROD from happening again, and changing out the thermal paste with artic silver 5. As for reading discs, open up the drive air it out, but not the laser, use a qtip and some rubbing alchol, clean it off and put it back together. Fans all you can do is replace them which I recommend just buying off of ebay or llamma.com
Sep 16, 2011 | Microsoft Xbox 360 Console
I've had my air conditioner for a few years now and it no longer cools anything. The fan works, the condenser(?) turns on when I set it to cool instead of fan, but the air coming out of it isn't...
You need to determine if the compressor is running, if it is and you have no cooling then you either have lost charge or bad compressor, these units re not worth replacement compressor
Jun 22, 2011 | Goldstar R5208 Air Conditioner
I took my 360 apart because my brother got it from an the expo center (it had no warrenty) and i got the E73 so i overheated it by unpluging the fan on the inside. i waited and then turned it on it was...
When turning on the Xbox 360, a red light would be flashing at the fouth section of the Ring of Light. You should then recieve a ghost screen indicating an error E 73.
You recieve a screen error E 73 and section 4 of the RoL flashing red. This type of error was caused by a General Hardware Error relating to the Ethernet Port not functioning correctly or became faulty and unable to operate even with or without an Ethernet Cable connected to this port. The secondary code would be identified as 1021 for faulty ethernet port. I believe that there is no fix at the moment. If you encounter this error, I would suggest call 1-800-4MY-XBOX or visit www.xbox.com/support
The specific type of hardware error can be determined by these hidden codes:
0001, 0002, 0003, 0010, 0011, 0012, 0013, 0020, 0021,0022, 0023, 0030, 0031, 0032, 0033, 0100, 0101, 0102, 0103, 0110, 0200, 0203, 1000,1001, 1002, 1003, 1010, 1011, 1012, 1013, 1020, 1021, 1022, 1023, 1030, 1031,1032, 1033, 1100, 1444 and up
More information about these codes and errors, visit this webpage:
http://forums.xbox-scene.com/index.php?showtopic=484726
  • Note: There is known to be a temporary fix for this problem but is not recommended if the device still has available warranty on it. Doing so will avoid it's warranty, thus for you will pay $100 if sent for repair.
The Sticks Method:
  • Requirements: Xbox 360 (Power Cable and Composite/Component/HDMI Cable), two sticks (Like toothpicks, swabs)
1.) Turn off your Xbox 360 and unplug everthing.
2.) Get two sticks (Something like toothpicks or something that could fit in the back of the Xbox 360.
3.) Insert each stick to jam the two fans at the back of the Xbox 360 to prevent it from spinning.
4.) Plug back cables (Power and Cable connecting to TV; the RRoD will not appear unless the cable to the TV is connected).
5.) When RRoD appears (One Red Light), wait for about 10 to 15 minutes or maybe less for the Xbox 360 to overheat.
6.) At this point, you should get two red lights (Resembles Overheating Error) so remove the two sticks so that the fans will spin in an increased speed. After a few seconds, the Xbox 360 will turn off to cool down (RRoD will still appear).
7.) Unplug only the cable connected to the TV. You can unplug the power cord if you want to. Then let it cool for about 30 minutes or so (Feel the Xbox 360 if it's cool or still warm)
8.) Replug all wires and turn your Xbox 360 on.
The Xbox 360 should now be able to boot to your Xbox Dashboard. I don't know how this fix works but it's only temporary. Note that doing this continually would cause it to now work even if you try to redo this fix again and again. Doing so would make other hardware components to fail permanently such as the GPU for example.
If this first temporary fix did not work, do the second method: The Towel Trick. You can find the tutorials in Youtube. Again, this is not recommended if you have warranty left and never do this continually. Your Xbox 360 would completely and permanently fail after that. if it doesnt help after all this....I suggest sending it to Microsoft for repairs
Jun 27, 2010 | Microsoft Xbox 360 Console
My projector will run for a time between 20 minutes and 2 hours and then it shuts down. It will start right back up (takes 3-5 minutes for it to cool and then restart) after that. What could be wrong?
It could be overheating. Can you hear a fan running? Does the projector feel hot to the touch?
Try putting a small house fan on it to cool it and see if that helps.
Jul 13, 2009 | Casio XJ-360 Multimedia Projector
2 ring of death
MS is one of the worst companies I have ever seen in reliability. If something of theres doesn't work they say woops! Buy a new one.. and they move on to steal more ideas.
I got the 2 ring of death and tried the xclamp fix- worked for 30 min. Doesn't run more than 5 mins now. There is no dust in it and the fans are working fine.
I've read that my xbox my have gotten so hot with the default config that it melted the sodder off itself. WTF
If someone finds a GOOD solution (versus the typical MS resonse given by localwonder)
Also I have run my xbox with a fan blasting air into it and this doesn't affect the 5 min uptime.
May 26, 2009 | Microsoft Xbox 360 Console
2 rrod code 0013
put your x box 360 console on a pie cooling rack or in font of a small fan
Dec 07, 2008 | Microsoft Xbox 360 Console
Ouor xbox 360 freezes while playing halo 2
Your Xbox is overheating. Its a common issue. You can do as I did and strap some fans to the bottom and help cool it off. Eventually you will probably get a RROD (Red Ring Of Death). At that point you will need to send it in to Microsoft for repair.
Sep 27, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
534 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
