Question about Dryers
Need a wiring diagram for a maytag gas dryer dg312
Need a wiring diagram (ASAP!)  for a maytag gas dryer dg312. My guy found a motor but can't figure it out. Maytag no longer has these diagrams. Thank you!
  • marilisa3 Jul 28, 2009
    Unfortunately, when he pulled the old motor out (hoping it just need some jerry-rigging), it was hard to get it unwired, and hard to see what he was doing, and he's afraid that he messed up.
  • 76 Answers
If the old motor is still installed simply change wire for wire.
Posted on Jul 27, 2009
Wiring Diagram for washing machine
Hello, On the American made appliances, the custom is to paste a wiring diagram inside the panels of the washing machine. They figure you need to remove the panels to service the parts and the Diagram will be waiting for you when you pop the panel off. Can't say what a foreign brand does.
Being foreign-made eliminates the help you can usually get at a Library which have books about Appliances. If you do a Web search entering exactly what you have as a Model and Make, then you may get a hit.
Now some of the sites gave me detailed Diagrams for my 30 Year old Maytag dryer which allowed me to replace my gas Solenoids and to know the exact name for the part.
Servall is a Franchised International appliance parts supplier. They have been in business for over 50 Years and if you do not have a local store they are online. They will ship and probably should be your first stop. Once you have the Diagrams you will need to go somewhere for parts.
Nov 26, 2011 | Cars & Trucks
Broken wire from the igniter on a maytag dg312 gas dryer
Hello Randy,
If the wire it broken on the actual ignitor with the ceramic base and the gray filiment,you could just replace that ignitor and keep that glorious 20 year old plus dryer going for years to come.The ignitor could be purchased at your local applince parts store for under $30 the part number is 279311 it also could be ordered online at;
assuredparts.com
apdepot.com
appliancepartspros.com
repairclinic.com
Gene
Aug 09, 2011 | Maytag Atlantis MDG7400AW Gas Dryer
Maytag gas dyer model dg312 is on igniting hot surface is turning on but no flame
i am not clear on what you are saying. i think you are saying that the ignighter is comming on. if this is so then there are two coils on the gas safety valve. replace them both.
Nov 22, 2010 | Maytag Dryers
I have an old maytag dryer that wont heat. happened once before and i replaced something but cant remember what part it is a model number DG312 series & serial number 339062xa i am thinking it was one...
Hi, I have looked the model up and it shows it is a gas dryer.These round switches you are talking about are for safety reasons, You should have a wire connected to one side and going out the other.Pick you up an insulated wire with clamps on the ends at Home Depot, Radio Shack for sure and you can bypass these switches to see if the unit starts to heat. This is the best way to check a switch as we do this everyday in A/C repair. Process of elimination. Best of Luck to you and please keep me posted. Safety First.
Shastalaker7
Nov 27, 2009 | Dryers
Gas dryer is not heating now.
That unit should have a glow plug igniter. No pilot. Please be carefull lots of lent to catch fire. Good luck
Nov 09, 2009 | Heating & Cooling
Maytag Model DG312 not drying
Firstly, ascertain that you have made a positive heat selection on the control panel temperature switch, If available.
Below are some links, courtesy of www.repairclinic.com, that will assist you in diagnosing/repair of your dryer. You may have to enter your model number in the search box to access some of the information.
Below is a parts breakdown/disassembly procedure for your dryer.
http://www.repairclinic.com/Dryer-Gas-Maytag-Style-Appliance-Diagram
If your dryer doesn't heat, check these:
Igniter
Gas valve coils
Thermal fuse
Igniter http://www.repairclinic.com/SSPartDetail.aspx?s=t-dg312-%3d%3di3018&PartID=3018 Modern gas dryers use an electric igniter to ignite the gas from the gas valve. When it's working properly, the igniter glows bright orange. When it burns out, the dryer tumbles but there's no heat because the gas can't ignite. When the igniter burns out, you need to replace it. If the igniter is held by a tension bracket, you very well may need to replace the bracket too.
The igniter is inside the dryer housing, near the bottom front, usually in a cone-shaped metal tube (the force cone). It's about 2 inches long. It's mounted to the far end of the burner tube, and it has two wires attached to it--or to the tension bracket, if there is one.
Gas valve coils http://www.repairclinic.com/SSPartDetail.aspx?s=t-dg312-%3d%3di3479&PartID=3479 Watch the igniter. Does it glow bright orange, then shut off without igniting the gas? (When the gas ignites there's a large blue flame.) If so, there may be defective coils on the gas valve. Mounted on the top of modern gas valves, there are black electrical coils. The coils, when energized, open the gas valve. If one or more of the coils are defective, the valve doesn't open and the gas cannot ignite. Because it's often difficult to properly test the coils, it's usually best to replace both (all) of them at the same time.
Thermal fuse http://www.repairclinic.com/SSPartDetail.aspx?s=t-dg312-%3d%3di483890&PartID=483890 On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing.
If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse to put the dryer back into operation. (You can't re-set this type of fuse.)
Other components that could keep it from drying.
Washer not spinning dry enough
Restricted Venting
Make certain that unrestricted airflow is available.
Blower: must be tightly attached to motor shaft.
http://www.repairclinic.com/SSPartDetail.aspx?s=t-dg312-%3d%3di1245880&PartID=1245880
Cycling Thermostat
http://www.repairclinic.com/SSPartDetail.aspx?s=t-dg312-%3d%3di484074&PartID=484074
Gas Valve
http://www.repairclinic.com/SSPartDetail.aspx?s=t-dg312-%3d%3di1689&PartID=1689
Motor Centrifugal Switch
http://www.repairclinic.com/SSPartDetail.aspx?s=t-dg312-%3d%3di1245851&PartID=1245851
Sep 06, 2009 | Maytag Dryers
Maytag Atlantis MDE7400AYW timer has been replaced but the dryer won't stop drying on it's own. What is the reason? I have the same problem... the timer on mine doesn't seem to work. Any ideas?
The wire connections to the timer may have not been made correctly when it was replaced bypassing the OFF contact in the control circuit.  There should be a wiring diagram inside the front or back panel that you can check.
Jun 02, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Dryer won't work.
Ok, this is electrical motor failure. you will need to replace the motor in this case. the hum is a sign of electrical motor windings failure due to minor separation of the cooper wire windings that hold the ac current.
Replace the electric motor asap if possible.
May 31, 2009 | Maytag Dryers
Timer problem
Found on partselect.com MAYTAG
Wiring diagrams:
http://www.partselect.com/Schematics/Maytag/52485.gif
data on the whole thing:
7 diagrams
Sep 24, 2008 | Maytag PYE2300AY Electric Dryer
Dryers Logo
547 people viewed this question
Top Dryers Experts
