SOURCE: Need to enter service mode on a Xerox 7435
The service tech should do this. The 7435 should be less than 3 months old, and Xerox should fix it. If you bought it from Global, or another company that does not actually employ Xerox technicians, try appealing to them, but I cannot tell you for sure what the outcome will be. Buying from an authorized agency ensures that you can use your "Total Satisfaction Guarantee".
SOURCE: Error code 39,003,40;61256 on a xerox workcentre
Here is the easy solution to fix the issue :
Click on the link and follow instructions to fix the issue.
http://www.pchell.com/hardware/cd_drive_error_code_39.shtml
SOURCE: LSU error in XEROX workcentre pe220. What is the
R/sir,
I have a Fax machine of Xerox make model PE220.From BSNL line connectivity is allways out of order.I want to connect FIXED CELLUR TERMINAL (FCT).After conecting machine give dial tone for outgoing calls.and other end caller received a fax tone on their machine when they want to make a call on my machine.But printer is not printing after some LCD diplayed a massage communication error.Kindly GUIDE me for change in settings.
Thanks and regards
PK Jain
(Pennywise)
SOURCE: Xerox 7435 error code 010-328 whtes the problem
it is the code for fuser heat control problem. Usually, the unit has its airflow restricted try moving the unit or cleaning it to see if the problem clears
Here is a list of all the error codes
WorkCentre 7425 style Fault Code List Part
