Question about Nokia N85 Cellular Phone
It's not shutting properly. Please help how to
Its camera cover is not shutting properly. Please help how to reassemble it.
My C875 camera shutter wont open or shut properly.
Usually, the lenswork's taken in a grain of sand or been accidentally muscled sideways (or gently touched by a vibration in a large stone, as it were.) So you have to find the right moment to nudge the lens back into the proper tracks or knock the sand out. Stripping and reassembling it is an effective but hard way compared to patience and sighting the sand. Plus if you get 30 grains out, you get a laugh.
Aug 28, 2011 | Kodak EasyShare C875 Digital Camera
Bonaire evaporative water keeps running whne the unit is turned off
I would check electric solenoid valve on water line to make sure it is shuting when power is off to blower. Some of these valves can be taken apart and cleaned if it has debris stopping valve ffrom fully closing. To do this shut power off to unit, shut main water supply to cooler. Usually there are four screws holding top cover on valve remove these,remove cover and clean valve. Reassemble making sure that cover gasket is in good condition and properly placed. Turn water and power back on and try unit. Hope this helps you. Thanks
Nov 11, 2010 | Mastercool 67471 Evaporative Cooler Air...
Lens cover shut
Please ensure that the battery of the camera is fully charged.
In case you have recently charged and installed the same please make sure that he polarity of the battery is correct.
With a properly charged battery, this issue will be resolved.
If this doesn't work for you, please comment and let me know, and I will be more than happy to assist you to further resolve your issue.
I will appreciate your feedback and positive rating.
Sep 30, 2010 | Olympus ? 1030SW Digital Camera
The cover of the battery compartment does not lock closed properly due to the fact that the front recess for the locking tab has snapped off, is it possible to replace the battery cover on this camera, the...
Hi Dear,
As described by you. Some part is snapped off. Is this part is a part of camera body or is it from the flap that opens and closes which holds the batteries.
If it is the flap, then it is possible to get it replaced. But if it is from the body, then also it is possible to get replaced the body, but in this case it will be an expensive business.
Please let us know if this suggestion was helpful in any respect.
We would love to serve you further if you require more information on it.
Have a nice day.
Nov 06, 2009 | Canon PowerShot S1 IS Digital Camera
Lens cap will not stay open
try opening your camera in front unscrew the bolts and pull the front cover.you will see a metal cover not properly align.
Apr 06, 2009 | Kodak EasyShare V570 Digital Camera
Card Cover Open
The problem you are describing is a problem with the sensor that is on the card cover door. It seems to have failed and needs to be replaced. Following are the instructions to send your camera to Olympus for service.
http://olympusamerica.com/cpg_section/cpg_servicerepair.asp
Olympus will charge a flat rate repair fee for this product if beyond the one year factory warranty or the warranty is voided. The cost is $73 plus your local sales tax. This covers parts and labor, factory cleaning and diagnostic check, 6 month warranty and the cost of shipping the product back to you is all included in that price.
Mar 28, 2009 | Olympus FE-130 Digital Camera
Reassembly
i do apologize for the inconvenience that your having with the unt. the door should open right to left. first make sure the hepa and the carbon are in properly, then the door should lock back on the left side and then swing back shut. now you will have to push on the right side to get it shut securely. it should pop right back in. If that doesn't work please let me know and i will see what else we can do.
Feb 24, 2008 | Holmes Products (BAP2000BPF15-U) Air...
Black screen, loud beeping when opened, doesn't work
The following blog outlines some simple repair options for a lens error. But please first try the listed Fix #2. I heard that fix particularly works well for a camera who's battery had run down with the lens open. Please post back here with a follow up comment if any of the fixes work:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Dec 23, 2007 | Canon PowerShot S60 Digital Camera
Camera doesn't recognize lens cover...
I rednecked the crap out of mine. I pulled off the slide cover and placed a small piece of paper clip in the area of the copper to make a permanent contact. Then duct taped it secure and then cover the whole slide mechanism. I would not recommend this method but it worked.
Apr 28, 2007 | Sony Cyber-Shot DSC-T5 Digital Camera
Repost of A70 Mode Switch Problem
Make sure that the mode switch on the cover is in the playback position. Unfortunately, I don't have a source for new switches.
Apr 24, 2007 | Canon PowerShot A70 Digital Camera
Nokia N85 Cellular Phone Logo
46 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
