SOURCE: Magic Chef refrigerator stop cooling
check the fan relay and the compressor to make sure it is still working...if not there is a capasiter you can replace to get it to work again
SOURCE: Freezer Noises from Refridgerator
You are hearing the defrost mode. Your unit is set up on a timer system which means that every 8 to 10 hours it sends the unit into a defrost mode. In this mode an actual heater, much like the one in your oven, is actuated to defrost the coil that has built up frost. The crackling is the heat causing the frost to melt much like when you pull ice out of the ref and it starts to crackle and pop as it heats up. The hissing is the frost water dripping onto the heating element. You have nothing to worry about. It is working as it should. And if you are wondering where all that water goes...well it goes to a drain pan on the bottom of the ref which is evaporated by the fan that blows across it and the heat that comes from the compressor and hot gas lines.
SOURCE: My Magic Chef mini fridge temperature trouble
That can be very difficult to do with a mini refrigerator. There is just not enough separation between the freezer and the refrigerator.
You will likely just have to find a compromise setting and accept the results.
SOURCE: ovens not lighting magic chef
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
wwt
