Question about Car Audio & Video
07 honda odyssey EX-L CD won't play
I have an 07 honda odyssey EX-L with a 6 disc CD changer. It currently has 4 CD's inside. None of them will play. The radion and DVD work fine but I cannot even choose to play the CDs. They will not load nor eject.
I have an 07 honda odyssey EX-L with a 6 disc CD07 honda odyssey EX-L CD won't play - 2_bing.gifchanger. It currently has 4 CD's inside. None of them will play. Theradion and DVD work fine but I cannot even choose to play the CDs. They will not load nor eject.
Posted on May 08, 2010
"CDC MECH ERROR" on 2009 Honda CR-V EX-L with Nav
Either the unit's motor is bad or the mechanical parts are dirty not allowing the unit to change CD's or load them.
Jan 23, 2014 | 2009 Honda CR-V
2006 Honda Accord v6 Ex 6 disc cd changer does not eject
MY 6 DISC CD CHANGER WANT EVEN SHOW THE CD MODE IN MY CAR AND I DON'T KNOW WHAT'S GOING ON
Mar 09, 2012 | OEM Systems Car Audio & Video
6 disc, will not eject or play cd's
Try tapping on the changer. Sometimes a gear gets stuck inside the changer and tapping on the changer frees the gear.
Feb 15, 2012 | Alpine CHM-S630 6-Disc CD Changer
My Honda accord Sedan car CD Player cannot eject CD .
Before connecting any cables you must set the dip switch box to the position listed for your vehicle. If you set the dip-switches after you have connected cables to the box, you must disconnect and reconnect them for the changer to operate. All 1992-2004 Honda's are compatible with the Neo Changer except the 2003 and 2004 Honda Accord and all Honda Element vehicles. Some radio models require pressing "Seek >" once to start playing after changing CD or after startup. The radios display will not show the proper disc number after disc six. You can use all 10 discs in the magazine, but the readout will be wrong. This is not a technical problem; the car stereo was designed for no more than six discs. *Due to the direct access disc system, you will not be able to directly access discs 7-10. To access these discs you will have to go to the last track on disc 6 and let it play until it loads disc #7. ( you can fast forward the track, but you must let it play the last 5 seconds of the track, for it to change to disc # 7 Switch to the Neo Changer by pressing the "CD" button. To change discs press "Disc -" and "Disc +" To change tracks simply press "Seek <" or "Seek >" S E T T I N G S F O R H O N D A 1 2 3 4 5 6 7 8 ON OFF OFF ON OFF OFF ON OFF
Dec 21, 2010 | 2000 Honda Accord
Is it possible to connect an iPod to a 2004 Odyssey EX stereo?
Yes you can connect an ipod to both stereos ..but first you willl needc the wire that allows you to hook it up to the radio or get a radio tuner that you put to a radio station and then your ipod plays on it
Mar 22, 2010 | Buck Honda Odyssey 2004 Car Stereo/radio...
Six cd changer with 6 cds stuck inside, none will play and message appears no cd, or cd error,or eject error in a 2004 ford escape
Ok this may seem barbaric but it worked on mine.......Hit the top of the stereo a couple of times and see if it corrects the problem.
May 30, 2009 | Blaupunkt IDC-A09 5-Disc CD Changer
How to enter the unlock code on the 6 disk cd changer
Look on the side of the glove compartment, there is a sticker with numbers, that is your code. In general, the number from 1 to 6, so you simply enter your code by using the existing buttons.Hope this help.
May 03, 2009 | 2006 Honda Odyssey
02 Honda Accord CD player does not work
Ive a 03 honda accord ex with a 6 disc changer the radio works but the cd player wont play the cds it just spits them out
Sep 03, 2008 | Car Audio & Video
My 6 disc changer in my Ford 500 won t Eject or play
well i don't have a 6 cd changer but i have had a few problems like that and all i can tell you is using something to unjam as soon as you hit the eject has been working just fine for me .......hope it helps a bit
Jun 27, 2008 | Car Audio & Video
How to remove the cd player from Honda odyssey EX 2002 model
The trim panel that surrounds the radio and contains the climate controls and possibly 1 or 2 other switches needs to be removed. Apply gentle, even pressure on the edges and gradually move to the other edges, and the clips should pop out.
I would advise against unplugging the climate controls or radio however other switches can be unplugged safely.
Once the panel with the climate controls is removed there should be 4 phillips head screws holding the radio in place; remove those and you should be golden.
Feb 19, 2008 | Car Audio & Video
Car Audio & Video Logo
963 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
