SOURCE: Garmin Nuvi 7700 bluetooth to LG enV-VX9900
You don't. This phone is incapible of that as it's a VZ nav. capible phone. Sorry.
SOURCE: voice not working properly on garmin nuvi 660 - very disdorted
i have been told that voice to street is not as clear as the voice just stating turns. If it really bothers you then try voice to turn. I cant remember the setting but it should work well for you.
SOURCE: no sound from Garmin nuvi 760 by any method
Sounds like your speaker went south. Since your fm transmitter is working I'll be your earphone jack is too. So you could always use an earphone. Only other option is a speaker replacement.
SOURCE: lost the voice on my garmin nuvi
Go to settings, you will see blank box for language settings (where you tell it to use TTS or normal or other spoken language etc.) select language of your choice again. You will be all set. Nuvi tends to loose its voice settings sometimes.
SOURCE: Battery does not hold charge in Garmin nuvi 770
The video on the link below shows how to replace the battery in a Garmin Nuvi:
How To Change The Battery On A Garmin Nuvi 760
See also battery_repair.
