Laser 3115cn All-In-One Printer
Problem for Laser 3115cn All-In-One Printer
I cannot setup the scanning to file/server function
By patrik746 on Jul 27, 2009
I tried a lot of combinations in the server/computer adress book setup. But all with the same result: FTP/SMB Error.
This is my current configuration is:
Name: Server (just a random name for the adress book I guess)
Type: SMB
Adress: 192.168.159.10 (no \\ or anythinh needed I guess)
Port: 139 (also opened both ways in my firewall, even though it should not be needed due to internal traffic)
User: scanner (added to the useraccount interface in our Windows Server 2008, added as a administrator to rule out any problems with permissions)
Password: XXXX (added and checked, this is the accoutpassword for the "scanner" user I guess)
Resource name: scanner (here I've choosen the name of the shared folder. I've also tried the networkadress \\DBSRV1\scanner but without any luck.)
Serverpath: c:\scanner (also tried \\DBSRV1\scanner but with no luck)
What is actually the difference between the resource name and serverpath?
Well, with this settings the scanning starts, the document goes through the feeder and then it beeps and say "SMB/FTP error, 016-783"
I cannot figure out whats wrong and Dell support say they don't offer support for configuration (!!!!!). What to due? Where to start troubleshoot? I thing I have a couple of so called double errors, so when I fixe one problem I have change so many other values that a new appear... so many combinations and so bad documentation...
Best Solution
posted on Aug 04, 2009
Very Helpful)
Tom Tanner
Rank: Apprentice
Rating: 100%, 1 votes
i see a few thing wrong here that the dell printer does not like
First in our 3115 setup i do not see a "Resource Name" entry
we have Server Address, Share Name, Server Path
For the Server Address I put in the IP address (it would take DNS or WINS out of the picture if they are not setup on the printer) teh server address would be the PC where the shared folder resides.
The Share Name is the share that you are sending it to. my guess it appears that you created a shared folder called Scanner. if that is so then the the word scanner would go there (no "\"s)
the Server path would be if inside the Scanner folder you sectioned off like users names. then you would put in each different users the folder inside the scanner folder. such as "\Mike' or even if it was deeper "\Mike\Myscans"
but mind you the server path is not needed in your case it looks like you are dumping all the scans into the scanner folder so you can leave the Server Path line blank
Hope this helps
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
posted on Oct 20, 2009
Not Rated)
asimmm8999
Rank: Apprentice
Rating: 0%, 0 votes
Remove the Server path entry.....
In your case server path (should be empty)
Was this helpful?
Yes
No
Popular Solutions for Laser 3115cn All-In-One
Questions and Unsolved Problems for Laser 3115cn All-In-One
Do you recommend Laser 3115cn All-In-One Printer?
Answer
Answer
I am trying to get a confirmation sheet to print out on each fax, either not sent, sent. Right now... (More)
Answer
Even the Dell helpdesk wasn't able to help me.
Answer
I am getting a green veritcal line on copies?
Answer
Installed hardware and software (without cd rom) and when trying to use it just says software not... (More)
Answer
Whenever I use the mpf to copy the printer prints the copy half it's regualr size with my Dell... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Printers Experts
Top Printer Repairmen
(800) 836-9287
Celebrating 14 Years Of Outstanding Printer Repair...
Laser Repair 911
(972) 907-9771
Printronix, IBM, Tally, Genicom, TallyGenicom,...
Sinca Printers, Parts & Repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
