Dvd drive belt to open tray is broken on my insignia combo dvd/vcr
    President:
  • 563 Answers
Unless you paid a lot of money for that player, you'll want to buy a new one if you're not in warranty. I'm only vaguely familiar with that brand so I'm not sure of the price range. But if you only paid $25 to $50 for the unit, chances are the part you need isn't available from the manufacture. Companies that specialize in affordable, cheaper players no longer stock replacement parts because they save a lot of money in inventory. Most people will not spend the money necessary to repair a DVD player--they'll just buy a new one. So if a company stocks replacement parts for all of their models, they end up sitting on that stock indefinitely because few people want to spend the $50 to $75 labor for repair. If you're under warranty, call the manufacture and they will likely replace the entire unit and you won't pay any more than shipping costs depending on the company.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please post a comment if you need additional assistance so that I can help you further.
Posted on Jul 27, 2009
Anyone know how to open the dvd tray on a go video machine?
Sounds like a broken belt, you need to lift out the mech and turn the pulley wheel at the front, then fit a new belt
Aug 29, 2014 | GoVideo Go Video DVD/VCR Combo
Sony slv-350p dvd combo disc tray wont open
Might be to a broken loading belt, or damaged loading gear wheels. Check it. If gear wheel is faulty, it will be best to repalce the disc loading mechanism.
May 14, 2012 | Sony SLV-D350P DVD Player/VCR
GoVideo DVD/VCR combo has a disc in it, and it plays, but I cannot ejecti it. I tried turn off machine and restart it but it still doesn't eject. It keeps reading the disc and plays the program.
there is a belt which is driven by a motor to open or close the tray. u place the disc on the try and the try loads the dvd/cd into the mechanism. the belt is loose & needs replacement. you have to open the cover & find the belt on the mechanism & replace with slightly shorter length of belt.
Sep 26, 2011 | GoVideo Go Video DVD/VCR Combo
Magnavox ZV427MG9 DVD Recorder VCR Combo DVD tray is stuck in open position. Pressing close button results in slight jerking motion of tray followed by display of "close", then "load" ...
There is typically a small rubber belt or plastic gear that goes between the tray motor and the tray. Most modern units have the plastic gear. I would bet that it is missing a tooth or stripped its teeth or possibly fell off completely. You should be able to manually push the drawer in. To open it, there should be a small hole near the tray into which you can push a straightened-out paper clip.
Mar 05, 2011 | Magnavox ZV427MG9 DVD Recorder VCR
XBV243 DVD Player / VCR Combo: my Zen XBV243 DVD/VCR combo player won't eject the...
If it is the same problem as mine, the drive belt is old and worn and is slipping- therefor the tray will not open. I found this out after I removed the metal cover, and the screws holding the DVD assembly to reveal the motor, pulleys, and drive belt. Now the real problem is to find a replacement belt. Possibly a o-ring the proper size may work, as they are quite easy to find. The original belt has a square cross section, whereas an o-ring has a round cross section, but should work well enough.
May 05, 2010 | Zenith XBV243 DVD Player/VCR
Combo dvd vcr tray won't open
The belts are under the VCR tray and under the Disk tray.
Feb 15, 2010 | Panasonic Televison & Video
DVD player disc tray won't open
If unit has a belt drive to open and close the tray see if it has stretched or fallen off the pulley.
Aug 22, 2017 | Sony SLV-D271P DVD Player/VCR
Need to hook up dvd/vcr combo with converter box
Connect your rabbit ears to the Insignia. Connect the Insignia to the antenna input on the "cvd/vcr combo". Now turn on the television to show the "cvd/vcr combo".
The Insignia simply goes between your antenna and your television. In your case you also have a vcr so if you want the VCR to be able to play and record digital stations you will need the Insignia between the vcr and the antenna.
Dec 28, 2008 | Insignia Digital-to-Analog Converter for...
Dvd tray won't open
call the manufacturer and ask where you can obtain the belt
it will probably be through a distributor in your area.
hope this helps.
May 01, 2008 | Insignia IS-DVD1001 DVD Recorder/VCR
Televison & Video Logo
368 people viewed this question
Top Televison & Video Experts
Electro Med Services...
