Question about Garden
Craftsman 22 in. Electric Hedge Trimmer- blade stopped moving
After several uses, the blades on my Hedge Trimmer stopped moving. It is plugged in and I can hear the motor turn on, the blade just doesn't engage.
Please tell me if there is something I can do!!
Thanks
  • 154 Answers
Oil them or loosen bolts and try
Posted on Aug 03, 2009
Gas hedge trimmer blade locked up motor runs find
look for a bad nick in the teeth and file or grind it off smooth
Sep 16, 2014 | Poulan Pro PP2822 22-Inch 28cc 2 Cycle Gas...
Blades wont move when power connected. Stripped it down. Motor is fine. I think it must be the gears attached to the blade unit
Either the gears, OR SOME machines have a "CENTRIFUGAL CLUTCH" [a safety feature] between the engine and the blades.
IF your machine has this feature, then it's possible that the clutch has worn out and is slipping so badly that the blade won't move.
Jun 10, 2014 | Craftsman 22" Gas Hedge Trimmer
Blade on a Craftsman 20 in bushwacker electric hedge trimmer stuck on a vine and will not engage
with engine off ! use a pocket knife to whittle wood branch out of bar , do not yank it off the bush the blade will bend then will become stuck
Mar 10, 2013 | Craftsman 20 in. Hedge Trimmer
Do I need toil this Remington 22in electric hedge trimmer?
It's always a good idea to oil the blade of a hedge trimmer with WD40 or similar otherwise the sap from branches will eventually build up a coating on the blades and increase friction.
May 11, 2011 | Remington 22-Inch Dual Action Titanium...
I have a 22inch Craftsman Hedge Trimmer, Model No. 315.81591. When trimming a hedge near a chain-link fence, one of the steel links from the fence got caught between the blade guard and the cutter blade. ...
The likely issue is the gear pin has been sheared. The part is no longer available from Craftsman. (P/N from sears: 616255-001)
I had a similar issue with a similar electric trimmer. I removed the old pin and used a split pin and ground it down to the proper size. It's now worked for about 2 years just fine. This requires complete dis-assembly.
Sep 27, 2010 | Craftsman 22 in Hedge Trimmer
Trimmer starts and runs for 15 seconds and stops. won't start for a few minutes and does the same ,
Check the air filter, replace the fuel if it is last year's, clean the spark plug or replace. Also lube the blade. Good luck...Lee
Jul 14, 2010 | Craftsman 22" Gas Hedge Trimmer
I've got a craftsman 22 in. hedge trimmer (electric) and I'm looking an attachment to enable me to trim my hedges, which are approx. 8' tall, without climbing up on a ladder to trim the tops of the hedges....
Un less your trimmer is a split sharft model ie you can take of the blade by undoing a handle then the answer is no you will have to buy a diff trimmer
Jun 28, 2010 | Craftsman 22 in Hedge Trimmer
Sharpen hedge trimmer blade??
My trick is to make sure that I always lube the blades after each session with a 3/4 engine oil + 1/4 kerosene mix - making sure that every tooth gets a drops or 2, then run it for a seconds to spread the oil & leave the blades overlapping. Doing this allows the blades to self sharpen I've found. 2 stroke oil , unmixed is about the perfect viscosity aswell.
Feb 12, 2010 | Garden
Describe your Black & Decker Hedge Hog
You may have a piece of metal between the moving blade and the stationary one. Also the motor may have been at the top of the stroke when it stopped. You may be able to "force" the blade to move a little. This may free it enough to work.
Jul 14, 2009 | Black & Decker Hedge Hog 22-Inch 2.8-AMP...
Cam does not engage blade
I had this problem with mine. I ended up disassembling the two halves of the trimmer, then reseating the cam. The cam was jammed when I caught the blades on a chain link fence. Good luck and patience.
Mar 14, 2009 | Black & Decker 22" Electric Hedge Trimmer
Garden Logo
592 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
