Question about Bush Televison & Video
,e: Bush Gas double oven AG56DA HI, on my small top oven/grill the igniter to the grill does not ignite. The oven on the top ignites and so do all the hobs and bottom oven. Please help, Thanks Leon
I bought my cooker from Argos and the 1 year guarantee has run out. It is about 2 years old, I live on my own so it has not had much use. Thanks again. Leon
  • 1462 Answers
SOURCE: Zannussi Gas cooker
make sure clock is set properly - refer to your instruction book. to test if clock is in fact faulty, access the clock and bypass it by shorting together the two wires to the clock relay
Posted on May 04, 2007
SOURCE: Gas Hob constant ignition clicking
Had the same problem. All five burners were continuously igniting, after my wife had given the stove a clean. Turned off the power, removed the five knobs and corresponding rubber rings, and used a hair dryer on the five holes where the knobs were for about ten minutes in total. Hey presto, when I turned the power back on, the constant igniting had stopped. Thank you all. I love the internet :-)
Posted on Jan 06, 2008
SOURCE: gas hob ignition
were do you get to refill the gas no book lost it
Posted on May 08, 2009
mgprice
  • 744 Answers
SOURCE: Gas oven ignites only intermittent
I assume you are saying the oven will not light but you can see the igniter glowing....if this is the case you will still need to replace the igniter, igniters need to be drawing a certain amperage before the will open the gas safety valve. in this case your igniter is glowing unevenly orange and is old - it is not pulling enough amps to open the valve. Replace it and you should be good to go If you have any other questions please feel free to comment. Good Luck!!! Mike
Posted on Aug 18, 2009
Testimonial: "Yep, spot on! Ignitor replaced today. Reliably informed that the glow ignitors last about 4 years (ours did 5). That brand now has spark ignition."
giel-monsieu
  • 13 Answers
SOURCE: Re: Bush Gas double oven AG56DA HI, on my small top oven/grill the igniter to the grill does not ignite. The oven on the top ignites and so do all the hobs and bottom oven. Please help, Thanks Leon
have you tried cleaning it out? if the holes where the gas comes out are clogged it's not possible to ignite
Posted on Aug 13, 2017
Why does grill ignition click when bottom oven lit
ignition probably serves both, if clicking when not lighting, fault or sticking button
Jan 04, 2016 | Stoves Premier 720GRa Gas Double Oven
Can a ES100 Frigidaire gas range oven be lighted manually when there is no electric
Yes, the majority gas ovens with mains ignition can be bye passed you ether have a grill cover at the top of oven door or the bottom on the outside and somewhere between the grill slots there should be a small shaft with a slot in the end to enable you to turn it by screwdriver to put the gas through to the burner so your can manually when there is a power cut Ect.
Good luck
Mar 03, 2015 | Cars & Trucks
The ignition continues after gas lights on new world elegance/cooker and grill
The igniter will glow orange while the oven is on. This is NORMAL. If it went out the burner would not come back on when the thermostat calls for heat .
Aug 18, 2014 | New World G90m Gas Double Oven
I have a Leisure Gourmet Classic double oven. The hobs, the grill and the upper oven all work fine, but the lower oven suddenly stopped producing any gas. I turn the knob and the austomatic ignition s
Apparently there is a bad valve for that oven , recommend calling a gas service repairman . your gas provider should be able to recommend a good one to you .
Apr 19, 2017 | Leisure Kitchen Ranges
Diplomat adp 0511 grill has no gas or ignition
Gas ovens / stovetop that use gas and not electricity. These work by igniting gas and use actual flame on the the stovetop.
Newest cook top styles, such as the induction or halogen cook tops combine the same style to produce more even heating. Some of these ovens feature thermal limiters or thermostats that regulate the burner system.
I offer free advice bcuz God is so good!
GAS OVENS
The spark igniter tip is dirty (can clean it with either a little wire brush or a piece of fine sandpaper).
2) The Pilot flame is too low, and the tip of the igniter is not in the flame good enough. (the flame acts as a circuit when it touches the tip & completes the circuit).
3) The spark module is no good and needs to be replaced.(But 1 & 2 are your best bet).
spark module does not sense the flame when it's on. The spark igniter is also the flame sensor which provides feedback to the spark module.
Make sure the igniter is properly aligned with the burner lighting holes and it is clean. All lighting holes must be clean too. You can enlarge them using a drill bit one size bigger.
If it would not fix the problem, replace the bake burner and the igniter.
There is a small chance for the spark module itself to be bad as well.
The oven safety valve
(also called the gas valve) is the part that ensures that gas is not released until the igniter has reached the correct temperature needed to ignite the gas. While this part can fail, it is uncommon. If the hot surface igniter does not glow you should first verify that you have voltage to the circuit. This is a live voltage check and should be performed by a qualified person. If voltage is lost at the valve terminals then you should verify the continuity of the bi-metal in the valve using a multi-meter.
Jan 18, 2013 | Belling XOU592 / XOU593 Electric Double...
Ignition and gas problem
because main gas supply is distributed from a single point to various components,i suspect an obstruction in the oriface of your grill(probably a spider web).as far as ignition,most grill ignition systems are powered by a AA or 9 volt battery.try changing and see if you have ignition
Sep 15, 2009 | Pentair Minimax NT Heater
Grill ignition is sparking when the oven is on
if the grill is constant sparking when the oven was on and turns off when the oven is not in use then u either have a defective pcb/ht lead or electrode if it is self lighting or if you have to push in a button then this button or control will have a problem
Aug 21, 2009 | New World G70m Gas Double Oven
Turning on grill blows fuse on Electrolux EOG7330WN
get i an accredited electrician to check the grill element and fitting
there is a dead short in that area
Apr 23, 2017 | Electrolux EOG7330WN Gas Double Oven
I HAVE A WHIRLPOOL GAS OVEN AND GRILL AKG667 MODEL NUMBER 853566715000 WHEN THE GRILL OR OVEN ARE SWITCHED ON THE FUSE CONTINUALLY BLEW. I CHECKED THAT THE CONNECTIONS WERE OK. NOW WHEN THE...
hi thanks for the question so the igniter works but no gas most of the gas stoves have the same problem if the igniter works but no gas could still be the igniter the igniter must get almost white hot to ignite the gas if id does not the gas wont lite so the ather problem is igniter lights but no gas problem is with the 2 coils on the gas valve replace those thanks the appliance doc
Sep 17, 2008 | Whirlpool Kitchen Ranges
Televison & Video Logo
Top Bush Televison & Video Experts
Joseph Hoffmann
Are you a Bush Televison and Video Expert? Answer questions, earn points and help others
