SOURCE: electronic chip in key
As far as bypassing the securtiy chip, we can't tell you that one as it would assist any user on here to steal your car (or others).
When you turn the key to attempt to start it do the dash lights dim or even go out ?
Robert
SOURCE: Lost original keys
if it was me i would go to a toyota dealer with my vin number and if you look on the door it will tell you what month the car was made also take paper to the car registraton to prove you are the owner and they will get you a key you may even have to have the car tow so call the dealer ship first because the new key has to be program to work with the car
SOURCE: reprogramming remote and key
if its early 05 round heart shaped remote it needs programming into system at dealer with Tech2
later 05 to 07 had square (rectangle) shaped remote
1.2 ID Code Additional Registration
Note: This procedure will add additional remotes to the Keyless Entry Control Units memory. A total of 4 remote transmitters may be programmed into the Keyless Entry Control Units memory. When a total of registered and newly registered remotes exceed 4, the oldest one shall be erased.
Step Action
1 Note: Make sure that all the doors are closed and unlocked. Insert the ignition key into the ignition switch.
Open the driver's side door.
2 Turn the Ignition key to the “ON” position and then to the “LOCK” position three times
(The key should remain in the “LOCK” position)
Note: This step must be carried out within five seconds.
3 “CLOSE” and “OPEN” the driver’s doors once (Leaving the driver’s door in the “OPEN” position)
Note: This step must be carried out within five seconds after step 2 is completed.
4 Wait for 8 seconds (This wait time is critical)
5 Turn the Ignition key “ON” and then to the “LOCK” position once and turn key to the “ON” position (The key should remain in the “ON” position)
OR on/lock once
Note: This step must be carried out eight seconds after step 3 is completed.
6 “CLOSE” the driver’s door
The HAZARD lights should flash 3 times (This acknowledges the Keyless Entry Control Unit has entered programming mode)
7 Operate the lock or unlock button of the transmitters to be programmed; a flash of the HAZARD lights indicates the remote has been successfully programmed into the control unit
8 The HAZARD lights will flash approx 4 seconds after pressing the remote button to indicate the Keyless Entry Control Unit has exited programming mode.
SOURCE: my remote starter stopped working... the engine
check your brake switch. if high resistence it can cause override for autostart.
SOURCE: lost key need to bypass vatts without having key
here is a great write-up that will help. This system will bypass the entire security system and will take care of starter and fuel system. It was the only thing that saved my car : http://newrockies.com/vatsbypass
