Brown or burnt-looking lines seem to be radiating from the bottom of the screen. As instructed by Sandisk, I updated the software back in May. This solved the problem until now. Thanks.
Download the software after you run the link below ....Put check next to converter/firmware update/Manual download...Go to your start menu programs go to sansa choose Sansa updater follow instructions.......(http://mp3support.sandisk.com/sansa/Installer/1082/SansaUpdaterInstall.exe) here is the link
After installation connect your sansa......recovery mode lock the sansa hold center button in and push and hold the start/menu button until recovery mode....Also make sure you are connected to a 2.0 usb the back of the computer is best (the motherboard)....
USB
mode located on the sansa if asked to change to MSC goto menu press
enter scroll to settings press enter scroll to usb mode press enter
scroll to msc press enter press menu.....Connect should auto start sansa
software.....
Sansa software/driver
Updates firmware follow instructions
Downloads manual
Downloads converter
Battery and Black screen Blue ring: Remove the back and check and see if the battery isn't fully connected I put a folded peace of paper and put it on top of the battery also push softly but firmly on the Rubber rectangle above the battery (This is the Chipset For the screen, Black screen Blue ring ) and put the back on. Sansa Not Recognized: Try connecting it to another computer the back straight to the motherboard thIs should be USB 2.0 and see if it will recognize it as sansa or Drive/removable drive. if it does then download the sansa update software and install it. Make sure you disconnect the sansa and connect it when asked. This will update your sansas firmware and add the Usb Mode. Try to connect it to your computer at home it should recognize IF not try a laptop.... link for update software (http://mp3support.sandisk.com/sansa/Installer/1082/SansaUpdaterInstall.exe) download to a flash drive much easier. Make sure USB mode is MSC Recovery Mode may also allow your computer to recognize the sansa
RESET: Go into the settings and scroll down to reset all, push center button, scroll to yes, push center this will restore factory settings..... Reset All NOTE: THIS IS AN ADVANCED OPERATION AND RESTORES ALL SETTINGS TO THE FACTORY DEFAULTS. NORMAL USERS ARE NOT RECOMMENDED TO PERFORM THIS OPERATION! If your device freezes up press the Menu button and hold for 15 seconds. This is like a power down of the device. Once you perform the reset, the adjustments you made during last operation will be gone. This is what it states in the manual for the 260 sansa Page 29 Recovery Mode also resets system settings when unplugged...
Recovery Mode: download the update software and install then lock your sansa hold in the rec key on the left at the same time push the menu/power button this will take you to recovery mode then connect to the computer Start the update software if it doesn't start automatic goto /start /all programs /Sandisk/sansa updater/ sansa updater and start it up manually... follow instructions on the updater and the sansa. http://www.youtube.com/watch?v=_95hLqZxCHc&feature=related here is a link to a kid showing you how to goto recovery mode. Update software from this link.. (http://mp3support.sandisk.com/sansa/Installer/1082/SansaUpdaterInstall.exe) and install the software before you recover
Recovery Mode: download the update software and install then lock your sansa hold in the rec key on the left at the same time push the menu/power button this will take you to recovery mode then connect to the computer Start the update software if it doesn't start automatic go to /start /all programs /Sandisk/sansa updater/ sansa updater and start it up manually... follow instructions on the updater and the sansa. http://www.youtube.com/watch?v=_95hLqZxCHc&feature=related here is a link to a kid showing you how to go to recovery mode. Update software from this link.. (http://mp3support.sandisk.com/sansa/Installer/1082/SansaUpdaterInstall.exe) and install the software before you recover Usb mode in settings MSC is best, Updater recognizes it in this mode
Download the Manua; after you run the link below ....Put check next to converter/firmware update/Manual download...Go to your start menu programs go to sansa choose Sansa updater follow instructions.......(http://mp3support.sandisk.com/sansa/Installer/1082/SansaUpdaterInstall.exe) here is the link After installation connect your sansa...... Also make sure you are connected to a 2.0 usb the back of the computer is best (the motherboard).... USB mode located on the sansa if asked to change to MSC goto menu press enter scroll to settings press enter scroll to usb mode press enter scroll to msc press enter press menu.....Connect should auto start sansa software..... Sansa software/driver Updates firmware follow instructions Downloads manual Downloads converter You can make another music folder (music1)put music in this....
Download the converter after you run the link below ....Put check next to converter/firmware update/Manual download...Go to your start menu programs go to sansa choose Sansa updater follow instructions.......(http://mp3support.sandisk.com/sansa/Installer/1082/SansaUpdaterInstall.exe) here is the link After installation connect your sansa......
Recovery for the Sansa View is described on the Sandisk site in 3 steps:
1. Reset the device: http://kb.sandisk.com/app/answers/detail/a_id/188
The reset is meant for switching the player off completely, before going to the recovery mode.
2. Force recovery mode: http://kb.sandisk.com/app/answers/detail/a_id/197
Recovery mode is meant for recognizing the player on the computer and making backups of files from player to the computer, before clearing the device while updating it to the latest firmware.
3. Update to the latest firmware: http://kb.sandisk.com/app/answers/detail/a_id/304
Updating the firmware is meant for completely erasing the players' drive and putting new software on it back again.
