Question about Dryers
Dryer won't heat - Dryers
  • lallwein Jul 28, 2009
    Maytag Gas Dryer model LDG612
    Thank you.
  • jazzy6er May 11, 2010
    be more specific if it's gas or electric and brand / model would help efforts to diagnose with greater accuracy
  • 6,784 Answers
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
***If there are no blockages in the ventilation system and blower wheel assembly and, the thermal fuse is ok as well, this will confirm an issue concerning the control sector. replace the Board or timer in this case. Most common issue will be a blown thermal fuse but, a faulty control sector is possible. It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse
Posted on Jul 27, 2009
My Maytag gas dryer won't heat
Hello Todd,
Their are several things that could cause the dryer to not heat, i have posted a tip i wrote what to check whena gas dryer doesn't heat
http://www.fixya.com/support/r10293028-gas_dryer_not_heating
GENE
Nov 12, 2011 | Maytag Dryers
Whirlpool supreme lhi 5801 won't heat. The coil turns red but won't ignite anything. I'm pretty sure the gas is on. I don't know what else it could be...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Sep 03, 2011 | Dryers
Won't heat up
If it won't heat it will be either the heating element or the thermostat or the control board.
Aug 28, 2011 | Whirlpool GEW9250 Electric Dryer
2005 Whirlpool Gas Dryer. It won't heat. The coils won't glow. Had the fuses, ignitor, and coils checked and are ok. Could it be the timer? How do I check it?o
heatman101-
Jul 22, 2011 | Whirlpool LGQ9858P Gas Dryer
Maytag MDG8057 dryer won't heat. I unplugged the dryer to use the outlet for something else, plugged it back in, and now it won't heat. Any connection to unplugging it? If not, potential...
Did yall move the dryer? The ignitor is very brittle. Moving a gas dryer sometimes breaks an ignitor with a little age on it.themobilian_2344.jpg
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
May 11, 2011 | Maytag Dryers
Kenmore dryer not heating up
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Nov 15, 2010 | Electrolux AEQ8700F Electric Dryer
Dryer doesn't heat
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Jun 04, 2010 | LG DLE5932W Electric Dryer
Dryer won't heat
heatman101
May 19, 2010 | Dryers
Dryer won t heat 100 74732400 model
dryer element. Common problem easy repair.
Jun 07, 2009 | Kenmore 74732 Gas Dryer
Dryer won,t heat, put in new element and still won,t heat.
check you thermal fuse for continuity if none change it and the high-imit safety shut-off fuse(closest to heat element)
Apr 08, 2009 | Dryers
Open Questions:
Dryers Logo
105 people viewed this question
Top Dryers Experts
